NorCal Craigslist finds
Discussion in 'Northern California' started by seksilumpia, Sep 25, 2011.
  1. Aug 23, 2018 at 2:37 PM
    CalTacoma09
    CalTacoma09 Well-Known Member
    Manteca, CA
    09 TRD Sport DCLB 4x4 Barcelona Red
    A lot of crap and too much money spent
    :D
  2. Aug 23, 2018 at 2:37 PM
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    I do be wheeling tho
  3. Aug 23, 2018 at 5:12 PM
    CrashN'Burn
    CrashN'Burn I used to have a life
    Joshua
    Union City, CA
    '13 TRD Sport MGM
    During the break in of my new gears, is there any point in changing the front diff fluids after 500 mi if I haven't driven in 4WD?
    :boink:@ECGS @jberry813
  4. Aug 23, 2018 at 5:30 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    not with me
    I was told I dint have too by jaws gear and axle. I changed it shortly after tho. My OCD was driving me nuts
  5. Aug 23, 2018 at 5:39 PM
    DannyBFresco
    Danny
    Us AF right now
  6. Aug 23, 2018 at 5:47 PM
    CrashN'Burn
    Joshua
    Union City, CA
    '13 TRD Sport MGM
    Yeah I was thinking along the same lines, changing the oil wouldn't make sense since the gears aren't under load.
  7. Aug 23, 2018 at 5:57 PM
    Longboard1110
    Longboard1110 ...................
    San Jose
    A few things
    But they are turning and causing friction.
    CrashN'Burn[QUOTED] likes this.
  8. Aug 23, 2018 at 6:00 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    :anonymous:
    msfit and Fernando like this.
  9. Aug 23, 2018 at 10:06 PM
    CrashN'Burn
    Joshua
    Union City, CA
    '13 TRD Sport MGM
    This is true .
  10. Aug 23, 2018 at 10:10 PM
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Thats the guy selling the bumper and OME setup with TC. He probably dealt with someone else as I didnt want to do the bumper swap...
  11. Aug 23, 2018 at 10:11 PM
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Hey guys, I have 2018 Tacoma OR suspension take-offs (UCA, front shock/coil, rear shock, leafs).
    How much do these usually go for? They got around 7k miles.
  12. Aug 23, 2018 at 10:14 PM
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    Market is so saturated with this I'd say no more than 250
    FortuneFavorstheBruin likes this.
  13. Aug 23, 2018 at 10:15 PM
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Ah gotcha. Looks like my pricing was spot on!
  14. Aug 23, 2018 at 10:23 PM
    ruffridha9
    ruffridha9 Well-Known Member
    West Coast
    2012 Tacoma base
    stock ish
  15. Aug 23, 2018 at 10:23 PM
    wtfpenguin
    wtfpenguin Well-Known Member
    Menlo Park, CA
    2010 + 2013 MGM Taco 4x4 OR
    2010 Stock OR Suspension 59k miles F/R with UCA and LCA - $100
    2010 TSB Leaf Pack + 2.0 AAL - $80
    2010 Trail Hitch w/ mounting hardware - $100
    Bilstein 5100 rear shocks, used temporarily, bought with 10k miles, used for a month - $100
    Icon Remote Resi Rear shocks 12k miles, one with fresh rebuild - $300
    (2) Brand New SCS F5 16x8 3.5 BS, Gunmetal Never mounted - $150/each
    Rough Country 1 inch front spacer, used 100 miles, was told not to stack coilovers with spacers. Who knew? $50
  16. Aug 23, 2018 at 10:24 PM
    roguegs
    Angelo
    V8 T4R
    So 40 psi total? I'd say maybe 45 seconds to 1.5 minutes per tire. I would air up from 22-40ish and it took me about 8 minutes for all 4.
    ruffridha9[QUOTED] likes this.
  17. Aug 24, 2018 at 6:55 AM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    I would so buy. But firstgen...
    Area51Runner, Fuergrissa and Dan8906 like this.
  18. Aug 24, 2018 at 6:59 AM
    FirstTimeFirstGen
    David
    Pacifica
    I dont believe they turn unless you're in 4wd. At least on a first gen with ADD. not quite sure how the whole system works but I really doubt the ring and pinion turn unless you're in 4wd. The side gears might when you turn. But nothing else.
  19. Aug 24, 2018 at 7:01 AM
    FirstTimeFirstGen
    David
    Pacifica
    Depends largely on tire size
  20. Aug 24, 2018 at 7:02 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    This /\
    Axles spin. But not internals
