Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Mar 15, 2013 at 3:51 PM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Is replacing an oxygen sensor as easy as I think it is? Just pull the old one out, put the new one in, and you're on your way?
    Does the check engine light go away automatically or do you have to reset it after you fix the problem?
    In addition to my water pump leak, I took my truck to Toyota to investigate the check engine light and they said that it was the front oxygen sensor that was bad. They've already ordered the part, but I'm wondering if it would be easy enough for me to just replace that to avoid their labor cost. I looked it up in the FSM for my truck but it just said to replace it...didn't really say how.
  2. Mar 15, 2013 at 4:02 PM
    DangerTaco
    DangerTaco The older the bear, the sweeter the juice
    Max
    Peninsula and the Delta
    '03 Tacoma TRD
    OME shocks/springs, Dakar leafs, Brembo Blanks, Hawk LTS pads, FJ steelies
    Im assuming all youd have to do is undo it, clean the area, then put the new one in.
    Also unplug the battery to reset the check engine light.
    Then again ive never done it.
  3. Mar 15, 2013 at 4:18 PM
    downpour11
    downpour11 Well-Known Member
    Rob
    Chico, CA
    96 4runner
    1996 4runner SR5 4x4 - 419,000 miles, 14" Spacer Lift
    ^^^ correct. unplug your negative cable, swap the new o2 sensor in (1 bolt, 1 plug) and hook the battery back up and it's all gravy
  4. Mar 15, 2013 at 4:24 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    I mean, it depends on what kind of wheeling you do, but doing a shackle flip like that you'll gain droop, but at the sacrifice of uptravel.
    And from what I saw, you'll end up with less overall travel. To me that's a lose lose situation.
  5. Mar 15, 2013 at 5:10 PM
    t4r4life
    t4r4life poptard and protein farts
    Eric
    East Bay Area
    1998 Toyota 4runner
    panty dropping mod
    I'd help.................for food :D
  6. Mar 15, 2013 at 5:23 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    i don't know If I'll be cutting tomorrow but the crawl box is going in.
    You would do anything for food.
  7. Mar 15, 2013 at 7:00 PM
    PreRunnerSeth
    PreRunnerSeth [OP] Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Just make sure to put anti-seize on the threads of the new one or you will never get it out again.
  8. Mar 15, 2013 at 7:49 PM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Ooh, I didn't know that that's all you had to do to reset the check engine light. Thanks!
    Thank you!
    Any particular kind? I did a quick search on Napa's online store and they have 17 different kinds.
  9. Mar 15, 2013 at 8:58 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Antisieze is all the same. NevrSeez if you can find it tho
  10. Mar 15, 2013 at 9:10 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    What time you getting to it?
  11. Mar 15, 2013 at 10:29 PM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Cool, thanks! I'll look for it.
  12. Mar 15, 2013 at 10:32 PM
    Jbcm12
    Jbcm12 Well-Known Member
    Joshua
    Bay Area
    So I fixed my camper...
  13. Mar 15, 2013 at 10:40 PM
    JLee
    Jerry
    Grass valley CA
    I dont know i have to go down to the irace center in the morning so i guess around lunch time.
  14. Mar 15, 2013 at 10:49 PM
    Jbcm12
    Joshua
    Bay Area
    For what?
    We stopped by around there today...
  15. Mar 15, 2013 at 10:58 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    I'll try and swing by around then. Pretty sure I can make it.
  16. Mar 16, 2013 at 12:14 AM
    Razgriz
    Razgriz wtf am i reading
    San Jose, CA
    2013 White TRD 4x4
    aww yiss
  17. Mar 16, 2013 at 6:07 AM
    JLee
    Jerry
    Grass valley CA
    Dropping stuff off , install a few parts and race some sims :D
    Sounds good
  18. Mar 16, 2013 at 7:49 AM
    916 YATES
    916 YATES Well-Known Member
    Brian
    Sacramento
    2010 DCLB Grey TRD Sport
    emblems and decals removed, added TRD special edition badges, Sway A Way's front and rear, SCS stealth 6's, Toyo A/T II 265/70/17
    Getting ready to purchase lift. Was thinking of going 2.5 sway a ways in front, 2.0 sway a ways rear with OME Dakars. I commute freeway 40 miles a day(like today:mad:). Anyone used this set up?? Suggestions??
  19. Mar 16, 2013 at 8:28 AM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    They need to open on in Sacramento!! I would be there once a week!!
  20. Mar 16, 2013 at 9:19 AM
    JLee
    Jerry
    Grass valley CA
    Who says there not :spy:
