Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Jul 25, 2013 at 9:59 PM
    Razgriz
    Razgriz wtf am i reading
    San Jose, CA
    2013 White TRD 4x4
    Neat! Ill go take it off this weekend. No use for it since i went to 285's.
  2. Jul 25, 2013 at 10:04 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Yeah, in April it's still covered in deep snow. And unless you like walking through ice cold water, you want to wait for the snow to finish melting in the spring before hitting the upper falls. There's a stretch where the runoff floods across the gravel road (mid calf deep). That should be dry by now. This time of year, the falls are already slowing down (they'll still be running around 50% of peak).
    As far as being crowded, you should be able to find parking. Lower falls just depends on timing. People don't stay there long so spots open up (and if you're in the Taco then you have more places to "park" :D ). Upper falls parking lot will depend on the desolation hikers.
  3. Jul 25, 2013 at 10:07 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Awesome! Just Let Me Know when AndWhere.
  4. Jul 25, 2013 at 11:18 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
  5. Jul 25, 2013 at 11:25 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
  6. Jul 26, 2013 at 5:29 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    This is one wild truck. The guys in it were pretty nice, they smiled and waved when I gave them a thumbs up. The even more wilder thing was that the driver had on some sort of crazy brass knuckle contraption with spikes sticking out. Long hair flowing, they kept making the truck have that diesel sound. But no smoke was coming out. I wanted to get a pic of the front because there were vents on the hood, hella lights all over the place and some kind of sharks fin. Straight out of Thunderdome.
  7. Jul 26, 2013 at 7:58 AM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    I think to roll coal, you need some mods to the tune. Seems like such a waste too-pouring money out that 'exhaust' (the smoke is unburned fuel).
  8. Jul 26, 2013 at 9:27 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Bare metal just spray with paint. Half my frame is rustoleum. I normally spray with primer and coat over it with rustoleum bed liner. Thinks like shock bodies can be coated with fluid film.
  9. Jul 26, 2013 at 12:35 PM
    TheKid
    TheKid Well-Known Member
    Bay Area, Ca
    2011 Tacoma
    Hey, do any of you guys know how to get this bolt out on the upper control arm ?
  10. Jul 26, 2013 at 12:37 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Get out your biggest pair of channel locks and bend the sheet metal a little bit so the bolt can clear.
    Yes, that's how the dealer service manual recommends to do it. You're not doing anything a shop mechanic wouldn't do if he needed to replace it.
  11. Jul 26, 2013 at 12:38 PM
    HIYota
    HIYota Well-Known Member
    Angel
    Las Vegas, NV originally Kauai, HI
    09 Silver 6 spd TRD Sport DCSB 4x4
    Check my build thread...too much to list.
    Pry the inner fender away from the bolt
  12. Jul 26, 2013 at 12:44 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I stripped my axle down to bare metal.
    It has nothing but a coat of primer and bedliner on it...still running strong and I live in Tahoe.
  13. Jul 26, 2013 at 12:48 PM
    acdronin
    acdronin Well-Known Member
    Jumped the truck (a little), in Nevada, snapped one of the bolts that holds the airbag onto the leaf, broke a weld on the fire extinguisher mount, got new carriage bolts for the bags, gonna go to a welder up here in Florence in a little while, right after I do the ABS disable mod on my truck, ABS in sand sux
  14. Jul 26, 2013 at 12:53 PM
    kalieaire
    kalieaire i didn't know they stacked sh*t that high.
    Santa Clara County
    '12 TRD Off-Road 4x4 AC V6 6MT
    Adventure Trailers Atlas, Demello Sliders, BAMF Skids, PelfreyBilt Bumpers, SCS Ray 10
    I read somewhere you could cut the nub that sticks out, remove the rest of it and replace it with a new one from the dealership by putting it in from the other side.
    Well anyway, that's what she said.. ;)
  15. Jul 26, 2013 at 3:07 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Don't put it in from the other side. The logic is that if the bolt goes in from the top and you lose the nut, you'll be OK. Put the bolt in from the bottom and the nut falls off, you run a good chance of losing the bolt as well-in which case you're screwed.
  16. Jul 26, 2013 at 4:14 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I would say over half of the people put them back in the opposite way, mine have been that way for 3 years on LT and no issues
  17. Jul 26, 2013 at 4:20 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    It's whole lot easier to do it that way. I can see why.
  18. Jul 26, 2013 at 5:39 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    ooops...i coated mine. hope it isnt an issue :confused:
  19. Jul 26, 2013 at 6:28 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Pictures of carnage is what I want to see!
  20. Jul 26, 2013 at 9:43 PM
    acdronin
    Nothing much to look at I'm afraid, got the mount welded and replaced the bolts and bought some spares.
