Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Aug 18, 2013 at 8:31 AM
    IbeamsFTW
    IbeamsFTW Well-Known Member
    What size tire were you running?^^
    And I guess while we're at it, it's a long shot! But does any one have a pic of their truck with a 1.5" in front, stock rear, 17s and over sized tires?
  2. Aug 18, 2013 at 8:35 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    See edit. Please note mine is stock height 4.4
  3. Aug 18, 2013 at 8:41 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    275 is probably the widest you can go without hitting the UCA's but in all reality, 265 is plenty. Each truck is a little different but doing a little trimming of mudflaps and plastic is not a bad thing!
  4. Aug 18, 2013 at 8:46 AM
    IbeamsFTW
    It's on 17x8.5 method double standards. Not sure of the offset on them... But depending on that, it may help clear the uca as compared to a stock alloy?ImageUploadedByTapatalk1376840757.051892.jpg
  5. Aug 18, 2013 at 9:03 AM
    babytruck
    NorCal
    But it still might hit the inside of the wheel well where the flaps mount. It happened on a turn. That was my issue.
    Here is the pic of the front with the larger tires. You can't really tell by here but it rubbed the wheel well on the inside, on a turn even after I took off the flaps.
    And if you are concerned with the stance, this is how it looks from the rear with the smaller tires. Mine are also 17x9 with -12 offset. Yes, I have a wider wheel and that most likely is the issue. I had to be sure that the tires were approved for that width as well because you don't want the tire to be too narrow for the wheel.
  6. Aug 18, 2013 at 9:12 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yep, mine currently rub a smidge on hard turns right where the mudfap covers the cab mount. Beforehand it was also rubbing the front flap, I just pulled that crap off.
  7. Aug 18, 2013 at 9:47 AM
    babytruck
    NorCal
    Here is what it looks like with the smaller tires all the way around. Doesn't look TOO out of proportion. LOL!
    With your 1.5 lift and narrower wheels, you may be able to get away with the larger tires. I was able to return mine for the smaller ones with no penalty and I put maybe 200 miles on them. You can always test fit them, right?
  8. Aug 18, 2013 at 9:54 AM
    IbeamsFTW
    Right on. I guess the general census is that is should go with a 265/70r17. Aprox. 31x10.5 witch is what I will try. Thanks!
  9. Aug 18, 2013 at 9:57 AM
    babytruck
    NorCal
    What size are you?
  10. Aug 18, 2013 at 10:01 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Thumbs down Siu! Lol
  11. Aug 18, 2013 at 10:02 AM
    babytruck
    NorCal
    Why?
  12. Aug 18, 2013 at 10:03 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    265/75/16 like I said, rubs just a smidge. I figure the tires will rub off any excess plastic on the guards it needs to eventually. Haha or if it starts to irritate me enough I may just trim it a little myself.
  13. Aug 18, 2013 at 10:27 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I was just giving you crap :p
  14. Aug 18, 2013 at 10:35 AM
    DangerTaco
    DangerTaco The older the bear, the sweeter the juice
    Max
    Peninsula and the Delta
    '03 Tacoma TRD
    OME shocks/springs, Dakar leafs, Brembo Blanks, Hawk LTS pads, FJ steelies
    Haha that is Vin, looks like Emeryville too
  15. Aug 18, 2013 at 11:52 AM
    IbeamsFTW
    Yeah, and his truck is built exactly how I plan on doing mine. But it will be a while..
  16. Aug 18, 2013 at 12:13 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    Jay, you running a HAM or CB antenna on the FJ already?
    Bumpers, sliders, wheels, tires, radio.. your build is 90% done in 3 weeks! haha what's left? suspension?
  17. Aug 18, 2013 at 12:19 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    Right on, I think it'll be okay. It's not a full plate bumper all the way around so you're saving some weight. Eric, (ortlie09) is running his brute force hybrid off 5100's @1.75. and he's doing fine.
    I'm still debating that wheel offer. I just wanna find out how much of a hassle painting them would be, and trying to picture them all black. haha.
  18. Aug 18, 2013 at 1:30 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    with the cerekote? I wonder how that would look... hmmm. haha would my 16's fit on your fj?
  19. Aug 18, 2013 at 1:39 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    haha yea, of course they would
  20. Aug 18, 2013 at 4:01 PM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    They would look Sick!!!!!!!
