Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Aug 18, 2013 at 10:47 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    Yup, right now its 885x on my 5100 with a top plate spacer. Its super rough. Its at like 3.25" of lift. I'm not liking it at all. I'm gonna lookin into UCA's and maxtrac spindles. use my stock springs on the 5100s. Thinkin about all pro standard leaf in the back. overall 4" lift. hence, my need/want for 285s my 265/70R16 look sooo tiny right now.
  2. Aug 19, 2013 at 12:21 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    went down deer valley trail from blue lakes and this happened
    no clue how.
    and this guy helped me out, even offered to let me use his driveway/tools.
  3. Aug 19, 2013 at 6:00 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Wow that's crazy.
  4. Aug 19, 2013 at 6:05 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Check your motor mounts That's the only thing I can think of unless you had a branch come up and hit it.
  5. Aug 19, 2013 at 9:32 AM
    acdronin
    acdronin Well-Known Member
    Anyone know any smog shops in central CoCo county that aren't too picky with what they see under the hood :)
  6. Aug 19, 2013 at 9:42 AM
    nagorb
    Alabama
    2001 dbl cab 4x4
    that's what i was thinking, but haven't been able to pull the skids to check. weird thing is i didn't hear anything, I've had friends break mounts and usually you hear the fan. I'll be checking today.
  7. Aug 19, 2013 at 3:57 PM
    kalieaire
    kalieaire i didn't know they stacked sh*t that high.
    Santa Clara County
    '12 TRD Off-Road 4x4 AC V6 6MT
    Adventure Trailers Atlas, Demello Sliders, BAMF Skids, PelfreyBilt Bumpers, SCS Ray 10
    That's half right. ;)
    Cerakote C186Q is a ceramic based thermal barrier for piston tops, if it gets on the sides of a piston, it doesn't matter since the piston itself isn't in contact with the engine's cylinder walls. It's also very good at dispersion of heat in an even manner for aluminum pistons which do not tolerate uneven thermal expansion compared to iron pistons. Reducing hot spots also makes it a must for forced induction setups.
    With regards to Valves, as long as they make a decent enough seal against the ports, it doesn't really matter either. But with ceramic coatings in general, they clean up super easy on engine teardowns.
    However, if it were truly a lubricant, people wouldn't have a problem w/ using it on say rod bearings. Nobody recommends using Ceramic coatings on bearings since they're fine as is.
    Beyond that, Cerakote makes a lot of other tough high temp coatings for use on things like firearms, plastic parts, and other neat stuff. @Nat, but be sure to understand the actual application limitations before assuming it's unobtanium.
  8. Aug 19, 2013 at 5:26 PM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    And you are getting technically. Lol ;)
    you know there's more then just the piston coating, like micro slick film at are made for the Engine internals that helps with fiction?!?!?
    Edit: but I am only Certified in the Firearms coatings, so I don't know much about the high temp stuff. I am thinking about getting my cert in it. Might get into Powder Coating as well.
  9. Aug 19, 2013 at 6:35 PM
    whiteboy
    whiteboy Well-Known Member
    Cody
    Glendale, AZ
    '06 TRD sport
    Kings, alcans, 33's blah blah read my build thread in sig
  10. Aug 19, 2013 at 7:19 PM
    CaliAsh
    CaliAsh Well-Known Member
    Jesse
    Left Coast
    2012 Taco TRD Sport DCLB
    Trail Limo
  11. Aug 19, 2013 at 7:27 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
  12. Aug 19, 2013 at 7:34 PM
    DangerTaco
    DangerTaco The older the bear, the sweeter the juice
    Max
    Peninsula and the Delta
    '03 Tacoma TRD
    OME shocks/springs, Dakar leafs, Brembo Blanks, Hawk LTS pads, FJ steelies
    Went from a clear 108f scorching day to a 100f thunder storm.
    Awesome awesome.
  13. Aug 19, 2013 at 8:32 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Today? I"m not much further north from you and it was 80ish and clear here. Where were you at?
  14. Aug 19, 2013 at 8:51 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Check the WX. There's stuff moving through his hood now.
  15. Aug 19, 2013 at 9:12 PM
    RustyNuts
    RustyNuts Member
    Wayne
    Northern, CA
    2013 Super White TRD Sport
    Fabtech 6 inch lift 17 Inch Toyota TRD Pro Wheels 35x12.50xR17 BFG All-Terrain T/A KO2 Fab Fours Vengeance Series Front and Rear Bumpers 20 inch 120W Double Row LED Light Bar BHLM De-Badged.
    Black double cab with black wheels and bright red large TRD decals on the side driving in Fairfield today.
  16. Aug 19, 2013 at 9:29 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    saw a flat black double cab in the Clayton shopping center today.
  17. Aug 19, 2013 at 9:35 PM
    babytruck
    NorCal
    You're still here?
  18. Aug 19, 2013 at 9:59 PM
    whiteboy
    Cody
    Glendale, AZ
    '06 TRD sport
    Lol close enough to a truck that I figured I'd post it.
    Spotted a SWB taco today. Had a color matched ARB bumper and he gave me that Obama not bad meme face as he passed me. I hope I at least smiled at him but for some reason I was mesmerized by that shiny blue bumper.
  19. Aug 19, 2013 at 9:59 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Greg! Answer my PM
  20. Aug 19, 2013 at 10:02 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Yes.
