Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Aug 29, 2013 at 3:00 PM
    Jbcm12
    Jbcm12 Well-Known Member
    Joshua
    Bay Area
    Just pickup the cans, its cheaper and you only need maybe 2-3. I sprayed my roof to hide the fading with 2 and the second can was only to make it super thick. Fj roofs are larger so I would say 3 would be perfect with extra. Then again I spray different than the instrauctions, I stay a lot lighter and use less coats. Holds up the same or better imo.
    Thanks guys, I knew Aaron used electric sprayers and had to thin it out which kinda scared me because he said something about running into issues because of it but he made it work. I'll probably shoot with my compressor, now just a matter of do I thin it out to save cash
  2. Aug 29, 2013 at 4:36 PM
    kalieaire
    kalieaire i didn't know they stacked sh*t that high.
    Santa Clara County
    '12 TRD Off-Road 4x4 AC V6 6MT
    Adventure Trailers Atlas, Demello Sliders, BAMF Skids, PelfreyBilt Bumpers, SCS Ray 10
    which time are you referring to?? :p
  3. Aug 29, 2013 at 4:47 PM
    kalieaire
    Santa Clara County
    If you can spring for it, get an Iwata LPH-400/500 w/ 1 3.mm nozzle. These have been reviewed as the best for consistent spray pattern but they're a pretty penny, around 350-500.
    Iwata also just released a cheaper model w/ a plastic cup called the "Air Gunsa" for ~120. They're recommended for primers, but they work just as well as with base coats and clears from what I've read.
  4. Aug 29, 2013 at 4:51 PM
    SportyHeretic
    SportyHeretic Well-Known Member
    Jeremy
    Wyoming/South Carolina
    2010 Sport
    Icon Stage 3 Suspension, Diff Drop, MagnaFlow Cat-Back Exhaust, Tonneau Cover
    Today is the derp day i think. Im doing my emblems now to see if i like the look.
  5. Aug 29, 2013 at 5:09 PM
    kalieaire
    Santa Clara County
    Scratch that. I'm reading the Air Gunsa sucks a bit since it oversprays.
    you'll also need to properly thin it 50/50 with either naptha or xylene.
  6. Aug 29, 2013 at 5:26 PM
    Jbcm12
    Joshua
    Bay Area
    Yeah thinning must be done, doesnt seem too bad. Ima see where Aaron ran into issues. Just something temporary so I can do some motorwork without looking too bad
  7. Aug 29, 2013 at 8:06 PM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    Came home to home made Banana Bread!! You know what I am having for Breakfast!!!
  8. Aug 29, 2013 at 8:10 PM
    SACTOWN
    Greg
    Came home to dinner!!! Steak salad
  9. Aug 29, 2013 at 8:14 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Bread and steak salad? Hmmm....yer be'n buttered up....:D
  10. Aug 29, 2013 at 8:17 PM
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    HVLP coats best, even Harbor freight has them cheap
  11. Aug 29, 2013 at 8:24 PM
    Shaggs
    NorCal
    Exactly what I said, front looks like a stang...rear like a camaro, so you spend 3 mil making a 200k dollar car into two 40k dollar cars
  12. Aug 29, 2013 at 8:37 PM
    SACTOWN
    Greg
    Naw!!!! She loves to cook. Plus she got a new range. So she is in heaven
  13. Aug 29, 2013 at 9:23 PM
    Jbcm12
    Joshua
    Bay Area
    Yeah they're cheap as is, confidence is back up haha.
    Is there any difference?
  14. Aug 29, 2013 at 9:45 PM
    CaliAsh
    CaliAsh Well-Known Member
    Jesse
    Left Coast
    2012 Taco TRD Sport DCLB
    Trail Limo
    Calaveras would be a dice roll. It is pretty close and it would all depend on wind direction/weather the day you went.
    Was out there today. Google map Calaveras and look south east for Cherry lake. Lots of smoke in that area and it was pushing up north along the mountain range (have fun Tahoe/Reno folks).
    I'd play it safe and head up highway 12/101 towards thru Napa towards Humboldt. Lots of cool stuff up that way as well.
  15. Aug 29, 2013 at 9:48 PM
    Jbcm12
    Joshua
    Bay Area
    I meant in the move, weren't you already from the Sacramento area? I just ask because I moved too far away from Fremont :(
  16. Aug 29, 2013 at 10:03 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    Took the spacers out of my lift. Now just running the 885x's on 5100s. Sitting at 24-24.25 Hub to fender. MUCH softer ride. I was maxed out before and the ride sucked.
    Not anymore
    :woot:
  17. Aug 29, 2013 at 10:19 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Flew right over the rim fire earlier. You could actually see the red from the flames peaking thru the smoke.
    This picture you can see both fires. Off in the distance is the American fire.
  18. Aug 29, 2013 at 10:22 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Did you actually take the spacer out and replace the long bolts? Or did you cheat like me and just move them outside of the strut :D
  19. Aug 29, 2013 at 10:29 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    Nope, I didn't wanna mess with my janky Mcpherson strut compressors.. lol
    I actually was able to get the nuts down close enough to only need a small washer on each bolt instead of the huge lift spacer. Looks stock now ;)
    Now just time to get new tires and fill this gap:D
  20. Aug 29, 2013 at 10:31 PM
    Lil'Taco
    Lil'Taco Well-Known Member
    Scotty
    Wilsonville
    2010 PreRunner Sport DCSB
    Total Chaos +2" Long Travel, Coil Bucket Gussets, Spindle Gussets, LCA Cam Gussets, Glassworks 4" fenders, B.A.M.F. rock sliders with fill plates, Decked Drawer system, aFe CAI, Borla Cat-back exhaust, Blitzpro 21S LED light bar w/ B.A.M.F. behind the grill light bar mount, Red Label Off-road tube bumper, Redline hood struts, Grillcraft grill, Weather Tech floor mats, HID headlights and fog lights... It has more stuff done to it now.
    Thanks for all the recommendations, we ended up going to Armstrong Redwoods, pretty nice little area then stopped at the Korbel Cellars (50% off Champagne and Wine for military and 25% off merchandise), got 3 different Brandys which I think I convinced the person to give me their employee discount since the military one didn't cover brandy.
    I think I will end up going and checking out Big Basin on my own sometime though.
