Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Aug 1, 2014 at 9:37 AM
    foxhead
    foxhead Well-Known Member
    Andrew
    Colorado Springs, CO
    2016 DC Tundra
    My MT/R's are E load and they air down like a dream
  2. Aug 1, 2014 at 9:43 AM
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    Damn, I hope it's not too bad. Regardless we have enough beer and food to make up for low water levels. :D
  3. Aug 1, 2014 at 9:45 AM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Read the sidewall of the tire and start there. Under inflation will cause wear problems as well as increase the risk of tire failure. Let's not forget the impact on gas mileage. Under inflation is something like 30% lower than the sidewall pressure.
    Which is not to say you shouldn't run them at 34psi, just be aware of the pitfalls of doing it.
  4. Aug 1, 2014 at 10:04 AM
    timmytoast
    timmytoast Card-Carrying Illuminati Member
    Prison City, CA
    2013 SR5 4x4
    Black Plastiderp Front Emblem and Grille Surround, Relocated Horns, Bed Mat w/ bolt mod, Precision Fit seat covers, Anytime Fog Light Mod, Console and Glove Box Organizers, DIY Washable Cabin Air Filter, Pop N Lock Tailgate Latch, K B Voodoo Bed Brackets
    Sidewall of tire says to consult doorjamb/placard in vehicle for tire pressure. According to owners manual 265/75-16 is supposed to be run at 33-35 psi. The tire sidewall also says max psi is 80...
  5. Aug 1, 2014 at 10:07 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I thought door sticker only applied to OEM equipped tires for some reason, not just size. When I swapped to BFGs on the last truck I went off sidewall PSI.
  6. Aug 1, 2014 at 10:08 AM
    TRDrunner
    TRDrunner Well-Known Member
    Victor
    Vacaville
    2014 Tacoma TRD Offroad
    Door jam is probably the best since its from the manufacturer. Sidewall info can be useful though. And some people don't follow that. I've seen prius tires (185/65/15) come in with more than 70 psi. I don't know how in the hell the tires didn't explode on the freeway..... trying to the the BEST possible gas mileage.
  7. Aug 1, 2014 at 10:11 AM
    T4RFTMFW
    And a nice bald patch in the middle tread? All for saving gas but not at the cost of prematurely wearing your tires with a huge overfill. BFG was at least 285/16s or 295s. I run around 32-34 on my stock 245 lops
  8. Aug 1, 2014 at 10:12 AM
    YoDaddy1
    YoDaddy1 Member
    Yoda
    Brentwood Cal.
    The Green Beast285/70 R17 Good Year MTRs
    5" lift, Fixing mods from Prev owner
    A Green Beast In Livermore!!!
  9. Aug 1, 2014 at 10:15 AM
    TRDrunner
    Victor
    Vacaville
    Exactly! It was crazy. But them beeshes to spec and said don't do that again. Lol my 285s I have 33-35 psi. I love how they ride and havent have an premature wear. Especially with a 65k mile warranty sign me up for my next set when I need em!
  10. Aug 1, 2014 at 10:15 AM
    timmytoast
    Prison City, CA
    2013 SR5 4x4
    Door sticker on my truck does only apply to the stock tires. I was just replying to the post that said to read the sidewall of the tire.
    The owners manual has psi specs based on tire size. They spec 33 psi in 265/70s so I figure around there would be good for my 265/75s
    I was running the recommended 30 psi in the stock 245/75s that just came off my truck.
  11. Aug 1, 2014 at 10:19 AM
    T4RFTMFW
    How many miles on them Timmy? Kept at 30 for all the miles?
  12. Aug 1, 2014 at 10:24 AM
    timmytoast
    Prison City, CA
    2013 SR5 4x4
    About 53k miles. And 30 psi after the first 15k miles. I got the truck with 15k on it and can't verify that the tires were at 30 psi before I got it. I swapped them out for a more aggressive tire due to my going to be in the desert for the next few months for work.
  13. Aug 1, 2014 at 10:31 AM
    T4RFTMFW
    Good longevity. And.you wemt to 265 Toyo's in E? Pretty good leap. You have 2.7 AC?
  14. Aug 1, 2014 at 10:31 AM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    How can Toyota tell what the correct tire pressure for a tire that may not be what was installed on the truck to begin with? The door jamb sticker is for what was installed when it left the factory. What is printed on the side of the tire is the tire's maximum pressure, not the pressure that you should run it at.
    My Goodyear tires say something like 65PSI on the side. If I use the 30% rule I mentioned earlier, I shouldn't go lower than about 45PSI to keep the tire operating within it's design parameters. If I read the door sticker and it said 32PSI, that's 50% less than the tire's rated capacity. Which is fine for wheeling but not so good for driving on the road-if you follow the guideline most tire mfg recommend.
    BTW, over inflating a tire has consequences too.
  15. Aug 1, 2014 at 10:35 AM
    T4RFTMFW
    34 lbs with 30 recommended technically is overinflated, but is it really? Wear so far is good no unusual wear pattern. Personally I don't like how they feel with 30.
  16. Aug 1, 2014 at 10:35 AM
    TRDrunner
    Victor
    Vacaville
    Who knows what kind of witch craft toyota has going on with all the tire manufacturers... underinflating and over inflating hace the consequences yes.
  17. Aug 1, 2014 at 10:38 AM
    timmytoast
    Prison City, CA
    2013 SR5 4x4
    I didn't necessarily want E tires on my truck. My company has an account with Les Schwab and that's the offroad tire they sell.
    If I use the 30% rule, my tires would be at 56 psi. The truck was riding VERY rough at 65 psi and was "skating" on the freeway at speed. I have the fronts at 36 psi and the rears at 37 psi. And I'm not saying that I'm using the door sticker. Someone said consult the sidewall. I did. It said consult the door sticker...
  18. Aug 1, 2014 at 10:39 AM
    TRDrunner
    Victor
    Vacaville
    Im Pretty syre 4 pounds won't make a huge difference. Just keep an eye out for them. Rotate every 5k miles and you'll be good to go.
  19. Aug 1, 2014 at 10:40 AM
    T4RFTMFW
    Thanks man! Good info here and learning new things
  20. Aug 1, 2014 at 10:46 AM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    There's no witchcraft.
    The door sticker tells you tire size and cold inflation pressures. It also gives some loading information for the vehicle. In an ideal world, those are the best conditions for those tires to run.
    If you're running your tires at 34PSI instead of the recommended 30, no harm in that.
