Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Apr 1, 2015 at 9:36 PM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    Classic
  2. Apr 1, 2015 at 9:40 PM
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    sick MJ, nice setup
  3. Apr 1, 2015 at 9:52 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    thanks guys!
  4. Apr 1, 2015 at 9:57 PM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Brian and MJ, did either of you add a moisture trap in the system to prevent moisture from getting into the locker lines? I think I heard about that in this thread, actually, and have been trying to figure out how best to add a moisture trap ever since, but I'm not sure if it's worth it, anyways.
  5. Apr 1, 2015 at 10:11 PM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    No but ive heard of that. I asked the guys who installed it for me and they said they've never heard anyone use one
  6. Apr 1, 2015 at 10:52 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    No moisture trap, but I leak out my tank every now and then. I barely have any liquid in the system.
  7. Apr 2, 2015 at 7:07 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    If you purge the system before hand, like when you air down, you should be fine
  8. Apr 2, 2015 at 8:27 AM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    X2. I think I figure out what I'm doing! Looks good. Is the T junction somewhere under the cab for your air lines? You still running one front/rear?
  9. Apr 2, 2015 at 8:44 AM
    MJonaGS32
    MJ
    SF Bay Area (East)
    Everything is actually coming off of the tank - which has like 5 ports.
    IIRC the ports are:
    1: in from compressor
    2: release valve
    3: rear coupler
    4: blocked off
    5: air pressure switch/pressure regulator for ARB locker which then tees off to the air gauge in a-pilar and the front coupler. Did it this way to save the amount of air line going from the tank (under bed) to the front of the truck.
    air gauge
    btw - if anyone ever goes this route, make sure you get at least the 450c model since it has a 100% duty cycle
  10. Apr 2, 2015 at 5:18 PM
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Yeah, that's kinda what I've heard, too. The lame thing about the arb single compressor is that you would have to remove an attachment to drain any water out of the little tank, which is why I'm thinking I'll try to add a trap in the air locker line so at least no water goes in there. I don't really care if water comes out the tire filling hose while airing up.
  11. Apr 2, 2015 at 10:24 PM
    Shaggs
    NorCal
    I want a setup like that, with air lockers, tank, and remote control of my RideRite Bags to level on the go while hauling toys.
  12. Apr 2, 2015 at 11:31 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    The only downside to my set up is that the locker requires ~85 psi, and I usually don't keep any air in the tank. So I usually turn the switch on at the trailhead (it then turns off/on on its own bc of the pressure switch). But if I forget to turn it on, and I need it on an obstacle, I have to wait until it builds up to 85 psi.
  13. Apr 2, 2015 at 11:59 PM
    916TacoTruck
    916TacoTruck BallzDeep is how I go
    Inyo mom
    2019 Rapturd
    Former 2013 TRD OR. Sickass edition
    CO2 that bad boy.
  14. Apr 3, 2015 at 5:29 AM
    VolcomTacoma
    Jeff
    NorCal
    Is that a constant ~85 psi or just a one time to shift the locker?
  15. Apr 3, 2015 at 8:41 AM
    MJonaGS32
    MJ
    SF Bay Area (East)
    Constant. But turning the locker on/off doesn't use up any psi. The only time you may have an issue is if you have any air leaks in your system. Sadly, I have a very slow leak, but my pressure switch automatically turns the compressor on when psi hits 90 psi (then turns off at 120 psi) so it's not really a problem. In a whole day of wheeling, my compressor will turn on once, maybe twice because it dipped down to 90 psi.
  16. Apr 3, 2015 at 9:51 AM
    VolcomTacoma
    Jeff
    NorCal
    I'm looking at the ARB dual one. I'm thinking dual lockers and 1-2 tire fill hook up ports at the edges of the bed. Just wanna make sure I don't run out of air lol
  17. Apr 3, 2015 at 10:11 AM
    MJonaGS32
    MJ
    SF Bay Area (East)
    You'll be fine
  18. Apr 3, 2015 at 11:08 AM
    VolcomTacoma
    Jeff
    NorCal
    :fist pump:
  19. Apr 3, 2015 at 10:35 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    :woot: diff breather parts came today, along with my rock/courtesy light #prerunnerproblems. Also got a UPS update that my prinsu rack has been shipped. It'll be here Tuesday. :yes:
  20. Apr 4, 2015 at 6:02 PM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Anyone on here with the Dakar pack WITH AAL have a u bolt flip? Im looking to see what length u bolts Ill need for when I do the u bolt flip. Im wondering if my local hardware store has them and would be cheaper to get those separately and get relentless plates.
