Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Aug 4, 2015 at 3:23 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Still bolt on, you retain the bolt holes, but you can have the skid tuck in higher and go down towards your IFS. That's how DTF does his, what i'm getting from him...
  2. Aug 4, 2015 at 3:25 PM
    Snowhite
    Snowhite Well-Known Member
    Orangevale
    2010 DC White 6-Speed
    That does look like good way too go. I might build one just like that after I finish with this bumper. They are pretty cheap to build yourself if you got a welder and a tube bender.
  3. Aug 4, 2015 at 3:27 PM
    VolcomTacoma
    Jeff
    NorCal
    Yea I need to pick up a welder one of these days, If I'm gonna be going LT on the truck, I need to be able to fix my shit lol. Can't be running over to Jerry or wherever every time something breaks or I need something else welded lol
  4. Aug 4, 2015 at 3:30 PM
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Miller welders FTW
    Bentrodder likes this.
  5. Aug 4, 2015 at 3:32 PM
    Snowhite
    Orangevale
    Bought our welder back in November and finally using for a some what of a big project. Paid $500 for it at Tractor Supply. Pretty sweet set up. We got it hooked up to Argon mix gas and it welds really nice.
  6. Aug 4, 2015 at 3:32 PM
    Snowhite
    Orangevale
    I got a Hobart 140 MIG welder
  7. Aug 4, 2015 at 3:34 PM
    VolcomTacoma
    Jeff
    NorCal
    I was recommended to get the Miller 190. I was told to just go 220 now lol. I think the 190 you can switch between 110 and 220? But yea, I've got a random 220 breaker I need to figure out and see if I can turn it into a dedicated weld circuit.
  8. Aug 4, 2015 at 3:39 PM
    Iggy
    Northern CA
    Check out the build
    Is it for a washer dryer?
  9. Aug 4, 2015 at 3:43 PM
    VolcomTacoma
    Jeff
    NorCal
    Bro, I've turned it on and off randomly and nothing in the house turns on or turns off lol. It might be for the dryer though...I've got a gas dryer though
  10. Aug 4, 2015 at 3:47 PM
    Iggy
    Northern CA
    Check out the build
    I think it might be, it's usually the only thing in a house that has 220 unless you have a huge electric stove.
    I've run a welder off the dryer 220 befo.
  11. Aug 4, 2015 at 3:49 PM
    VolcomTacoma
    Jeff
    NorCal
    nice...new weld circuit! booya!
  12. Aug 4, 2015 at 3:55 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Depends on the machine. All the 180's I've used didn't pull more than 30 amps.
    30 amp dryer circuit you can make an adapter cable for the welder 50 amp plug. Anything more than a 180 you should be wiring a 50 amp plug up with 8 gauge (or 6 gauge if it's a long run).
    Anderson likes this.
  13. Aug 4, 2015 at 5:19 PM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    This needed rain is nice!!!
  14. Aug 4, 2015 at 5:20 PM
    rmarqu2
    rmarqu2 YES... i am a murse....
    Roger
    Baton Rouge
    09 Black 4x4
    FOX 2.5 coilovers, FOX 14" rears, AP expos, AP front plate bumper and skid, lightforce 240 blitz, warn m8000, 3/8 amsteel, BAMF sliders, cheap Chinese rock lights, ARB lockers all around
    Yea I don't exactly fit in with traffic. Lol
  15. Aug 4, 2015 at 6:07 PM
    VolcomTacoma
    Jeff
    NorCal
    I won't be pulling off the dryer plug, I'd be disconnecting the wiring from the circuit in the garage and running new wiring for a Weld plug in the garage...
  16. Aug 4, 2015 at 6:18 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Cool! May as well do it right and run a 50 amp circuit.
    You probably already know this, but make sure you match your breaker to your wiring and receptacle.
  17. Aug 4, 2015 at 6:28 PM
    VolcomTacoma
    Jeff
    NorCal
    wut? I do not know that, I just know I have an unused breaker that says 200 that I was going to change to a weld circuit :D
  18. Aug 4, 2015 at 7:02 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Ummm. With that comment I would suggest hiring an electrician.
  19. Aug 4, 2015 at 7:33 PM
    VolcomTacoma
    Jeff
    NorCal
    That's pretty much the plan lol. I try to leave most electrical work to professionals..I hate doing it.
  20. Aug 4, 2015 at 8:44 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    It rained? :notsure:
