Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. May 3, 2016 at 12:46 PM
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Same here no vibes at all with the new diff.
  2. May 3, 2016 at 12:47 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    That sounds like a good idea. I had some play and I removed my 1 inch block lift so I'm at 3 inches of lift now. Hoping this carrier last longer. I probably could have gotten another 10,000 out of it but with driving to Arizona and back this month and moab and back its not worth dealing with it later.
  3. May 3, 2016 at 12:48 PM
    Mademan925
    Nick
    Discovery Bay, CA
    I did it and I still have a vibe. I am going to replace my passenger wheeling bearing because its werring and see if that's it this weekend.
  4. May 3, 2016 at 12:49 PM
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    I was having a little vibes at take off before the re gear and locker install. I wonder if the solid pinion spacer got rid of the vibes. I always thought it was the carrier bearing but its still sloppy and vibrs are gone.
  5. May 3, 2016 at 12:51 PM
    Mademan925
    Nick
    Discovery Bay, CA
    I have a low speed vibe.... Its not bad and its been around for awhile. I don't mid doing the maintenance on my vehicle a little early for peace of mind.
  6. May 3, 2016 at 12:53 PM
    BudMan
    BudMan knee scooters R us
    Bret
    Alameda, CA, (Bay Area)
    06 TRD Sport DC 4x4
    stuff
  7. May 3, 2016 at 12:55 PM
    BudMan
    Bret
    06 TRD Sport DC 4x4
    stuff
    Looking at this, I can't stop an old habit of Beavis and Butthead laugh...:D
    Nirvana, Overlanerd, Fernando and 4 others like this.
  8. May 3, 2016 at 1:07 PM
    Mademan925
    Nick
    Discovery Bay, CA
    yep
  9. May 3, 2016 at 1:35 PM
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Is the vibes still there?
  10. May 3, 2016 at 1:37 PM
    Mademan925
    Nick
    Discovery Bay, CA
    yep. That's why im going to do my wheel bearing or maybe even bearings. If its not that then im done. Ill just say its the tires.
  11. May 3, 2016 at 1:39 PM
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Rear bearings
  12. May 3, 2016 at 1:44 PM
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    You can easily test the rear wheel bearings. Lift the rear and check for play.. your vibes might be from axel wrap. If its durring acceleration. Wheel bearings woukd be more high speed vibes. But im no pro.
  13. May 3, 2016 at 1:46 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    im chasing a rear vibe as well. random and not RPM/speed related. So annoying.
  14. May 3, 2016 at 1:53 PM
    ffdawson
    ffdawson Dirt Head
    Penngrove
    08 Tacoma Rugged Trail 6spd
    Kings, Armor, big taaaarrrs
    Thanks MJ. You might have missed it but I posted it a few days back, turns out it was my rear wheel bearings, not the CB. Had em both replaced. Vibes all gone...
  15. May 3, 2016 at 2:02 PM
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Nick when you re geared did you get tge solid pinion spacer put in.?
    Just curious if its something that is over looked when chasing the low speed vibe we all seem to have,or had and can't figure the exactly what it is. The only thing that i have found that completely got rid of it for others was a custom drive shaft that eliminates the carrier bearing.the vibes i had were minor but now gone. The only change has been the rear diff. I kinda think that the stock gears with 285s was causing minor axel wrap at take off after 20mph it was no longer there. Now with the new gears less torque is being applied to the diff, equals no axel wrap. I would think with softer leafs it would be worse. But with the heavy springs we have , its minimal. Anyone else have any thoughts on this? .
  16. May 3, 2016 at 2:13 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Ahh nice!
  17. May 3, 2016 at 2:17 PM
    Mademan925
    Nick
    Discovery Bay, CA
    Not from axle wrap. Its a vibe at rolling speeds between 3 and 10 mph with and without acceleration. Felt like its coming center to front. Though it might be the carrier but guess its coming from the front somewhere. Im not to worried about it. I don't drive that slow often. I wouldnt have even noticed it if I didn't drive my truck to work in traffic a couple days once and a while.
  18. May 3, 2016 at 2:27 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Mine had about a quarter of an inch I any direction. When I removed it just came off, no jaw puller. The bearing itself was cooked and the rubber was pretty bad.
  19. May 3, 2016 at 2:41 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    spotted Felipe by my job. Of course I didn't drive my rig today. Looking good @Nightstr
  20. May 3, 2016 at 2:45 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Well, thats fun, went out to the bike today, noticed the metal banding showing through. Checked it a few week ago and had a bit of tread left. Emergency tire replacement for $325, yay. Only shop in Fairfield with my size tire. It looks a little ragged so I'm guessing earlier this week when some dude cut me off and I had lay in the rear a little bit, must have caught in some gravel or something. So thats my day.
    otis24 likes this.
