Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Nov 23, 2016 at 12:22 PM
    tyfoon11
    tyfoon11 Raguel
    J
    Where bald eagles roam, Ca
    garden shed
    Don't recall if there were other obstacles to 26th but I can do that day
  2. Nov 23, 2016 at 12:26 PM
    tyfoon11
    tyfoon11 Raguel
    J
    garden shed
    I wonder if it would fit my S7. was considering one of those
  3. Nov 23, 2016 at 12:36 PM
    scocar
    scocar Patron of the Farts
    I strongly doubt it. He takes specs from the manufacturer's sites and 3D prints them accordingly. For example, my Turbo would not fit in the Turbo 2 version because mine has a curved back, and the Turbo 2 has a flat back.
    In fact, he will also account for any case you may have on your phone.
  4. Nov 23, 2016 at 12:53 PM
    Goobersbro
    Goobersbro Well-Known Member
    Jon
    North of Sacramento
    2015 dcsb o.r
    Locker anytime mod Pelfrey armor Warn recovery
    Well it mostly works I'm gonna massage the v cut a little more so that the exhaust isn't resting on the skid. Also not sure how concerned I should be with how close the exhaust is to the plastic on the t-case
  5. Nov 23, 2016 at 1:07 PM
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    at a minimum, I'd wrap some of that exhaust shield stuff with the foil surface around that plastic module on the transfer case. those pipes can get HOT when you're going slow under heavy load, like climbing a dirt grade in low gear. ditto that shifter? cable above the transverse pipe...
    EDDO, scocar and the glen like this.
  6. Nov 23, 2016 at 1:23 PM
    scocar
    Agreed. The version of this mod I like most has the straight pipe coming back farther toward the rear, then bending horizontal 90 well behind the transfer actuator, also keeping decent access to fill and drain plugs. Look into the heat shield options. That gap is pretty dam damn small. You may need to consider heat tape.
    You'll be able to bake biscuits on that skid on a hot day going slow.
  7. Nov 23, 2016 at 1:53 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Dcsleeper408, scocar and DVexile like this.
  8. Nov 23, 2016 at 1:55 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Oh, and the brown truck showed up at work...
  9. Nov 23, 2016 at 2:06 PM
    the glen
    the glen Well-Known Member
    Glen
    penisula
    2012 TRD Off-Road 6SP manual spruce mica Taco
    Icon 2.5 remote res. Coilovers front, icon 2.5 rem res shocks rear, deavers 10 pack leafspring rear. Light racing ouca. Cmc, avid light bar, bamf sliders weld on, grillcraft mx grill, bamf light bracket with lightforce 170's. Uws toolbox, oem bed mat, weathertechs f/r, hella airhorns, trd antenna, talegate mod, Clifford alarm, budbuilt full skid plate set. All pro rear bumper. Superbumps bumpstops. Bulldog lighting reverse led lights in bumper. Trd short throw shifter. Cobra cb, firestick 4' ant. Icon LCA skids. Bamf rear dif skid. Hi lift x-treme mounted with relentless rail mounts in bed. Full size method/bfg in bed. Crown performance ss/Kevlar brake lines. Power tank mounted in bed. Rigid d2s mounted on relentless hood mounts. H3R quick release fire extinguisher mounted to driver's seat. Redline hood struts.
    Hope thats a big box of rigids!
    2015whitetaco and EDDO[QUOTED] like this.
  10. Nov 23, 2016 at 2:09 PM
    scocar
    EDDO[QUOTED] likes this.
  11. Nov 23, 2016 at 2:10 PM
    scocar
  12. Nov 23, 2016 at 2:29 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    No, I'll not be posting that horror again. This is supposed to be a family show.
    BudMan and tacomgee like this.
  13. Nov 23, 2016 at 2:30 PM
    scocar
    Eaux. Boogerfest?
  14. Nov 23, 2016 at 2:34 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    At the time someone in here asked "You paid for that?". :anonymous:
    Overlanerd and tacomgee like this.
  15. Nov 23, 2016 at 2:37 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Just some not-1/4"-steel skidplates. Nobody here will approve. :thumbsup:
    tyfoon11 and Dcsleeper408 like this.
  16. Nov 23, 2016 at 2:38 PM
    Longboard1110
    Longboard1110 ...................
    San Jose
    A few things
    Don't worry, your icons will break long before you need those skid plates.
  17. Nov 23, 2016 at 2:43 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    I'm a planner. Thanks for noticing. :p
    2015whitetaco and Overlanerd like this.
  18. Nov 23, 2016 at 2:59 PM
    Goobersbro
    Jon
    North of Sacramento
    2015 dcsb o.r
    I'm gonna make a heat shield and wrap the exhaust and gen see what temperatures I get in the back side and take some temp readings at idle if I don't like it I'll have them redo it
    IronPeak likes this.
  19. Nov 23, 2016 at 3:00 PM
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    What did you get? I malled too hard and need some too. I wanted aluminum, but that's frowned up too. :anonymous:
    Overlanerd and EDDO[QUOTED] like this.
  20. Nov 23, 2016 at 3:04 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    3/16" steel IFS and transmission. All-Pro. There, I said it.
    Iggy[QUOTED] likes this.
