Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Apr 16, 2017 at 6:29 PM
    logcabinwc
    logcabinwc Well-Known Member
    Micah
    SF East Bay
    08 4d 4x4 White V6 TRD
    Old Man Emu 885s with Nitrocharged 90000, Bilstein 5100 in the back with AllPro 3 spring progressive AAL, 16 inch Baja Black 6-spoke alloy wheels, Flow Master exhaust, bed lights, Pioneer HD radio, Uniden CB Radio, K&N Air filter, BAMF Sliders w/kickout, Relentless Aluminum IFS Skid, 24 LED light bar, custom/homebuilt expedition style bed rack and basket combo, and Body Armor rear plate bumper.
    So I could use some mechanical expertise here...
    Battery died on me this afternoon, AAA came out and gave me a jump and I picked up a new one.
    But just got it home (having installed the new battery already) and the truck is idling lower than normal. I think it idles around 800-900rpm if I remember correctly...?
    Now its idling at 500-550rpm. Its not coughing or sputtering but it sounds like its just above where that would happen.
    I am not mechanically inclined at all, so any thoughts? Could it be the alternator starting to go?
    2008, stick shift, 4x4, 6-speed, 4.0l.
    Any help is appreciated!
  2. Apr 16, 2017 at 6:33 PM
    batshitcrazy
    batshitcrazy Probably drunk
    Ievacado
    Scsb 3x2 Honda fit
    Clutch.
    T4RFTMFW[QUOTED] likes this.
  3. Apr 16, 2017 at 6:34 PM
    batshitcrazy
    Ievacado
    Scsb 3x2 Honda fit
    How many miles?
  4. Apr 16, 2017 at 6:35 PM
    batshitcrazy
    Ievacado
    Scsb 3x2 Honda fit
    I'm retarded don't listen to me.
  5. Apr 16, 2017 at 6:39 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Didn't somebody in here just have this with a car replacement battery? Think the advice was don't worry about it. It'll adjust itself in time.
    Silver02Taco and nDub like this.
  6. Apr 16, 2017 at 6:39 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Has this happened before? Does the idle speed jump around or stay steady?
    If steady then the computer typically has to relearn after losing power. This includes idle speed. Has to do with the throttle plate position sensor.
    Easy to check alternator with an volt meter. At the battery it should be around 12.5 - 14 volt. Edit: at idle.
    If you want to force the learning curve just let your truck idle for 10-15 minutes.
    If it's jumping around like when the fan kicks on etc then might be a vacuum leak etc etc. Go from there.
    Edit: I'm dealing with something similar with my wife's car. Lots of google-fu...
    Overlanerd, EDDO and batshitcrazy like this.
  7. Apr 16, 2017 at 6:48 PM
    logcabinwc
    Micah
    SF East Bay
    Doesnt jump around so shouldn't be a vacuum leak. I'll go sit in it for a little bit with the idle on and see if it corrects the problem. Didn't know the computer had to relearn the power curve. Thanks for the idea
  8. Apr 16, 2017 at 6:50 PM
    logcabinwc
    Micah
    SF East Bay
    What was wrong with the clutch? Out of curiosity.
    batshitcrazy[QUOTED] likes this.
  9. Apr 16, 2017 at 6:51 PM
    nDub
    Lead Free Gasoline
    My wife's car does the opposite. It idles super high for awhile. I'm chasing an electrical gremlin so I keep diconnecting the battery. Also her idle is rough but not enough to stall, yet. Good times.
    Holloman and batshitcrazy like this.
  10. Apr 16, 2017 at 6:52 PM
    batshitcrazy
    Ievacado
    Scsb 3x2 Honda fit
    It was out.
  11. Apr 16, 2017 at 7:09 PM
    Sccafire
    Sccafire KMG 365
    Cleburne, Texas
    2023 Jeep Gladiator Rubicon
    Nothing is wrong. Your PCM looses its memory when replacing a battery. It needs to relearn idle speed and all the other stuff for it to run correctly. Just go drive for 20mins or so and will be back to normal.
    nDub and EDDO like this.
  12. Apr 16, 2017 at 7:16 PM
    Don5352
    Don5352 Liberty or Death
    Don
    Oakland, CA
    2014 AC TRD OR
    Some really cool shit
    Got my Cueto Shimmy Bobble, as well. He's now on the shelf next to my Juan Marichal statue.IMG_2348.jpg
    ffdawson, ian408 and Quakes15[QUOTED] like this.
  13. Apr 16, 2017 at 7:29 PM
    Quakes15
    Quakes15 Well-Known Member
    Peninsula (BAY AREA)
    TRD Sport Toyota Tacoma X DCSB 4WD
    ICON Stage 3/ Stealth 6's/ Nitto Trail Grapplers
    Sweet!! Mine is next to Timmy and a few others.
    ffdawson likes this.
  14. Apr 16, 2017 at 7:32 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Idles high all the time or just at startup? Spark plugs all clean?
  15. Apr 16, 2017 at 7:34 PM
    Quakes15
    Go Sharks! :cheers:
    ian408 and Silver02Taco like this.
  16. Apr 16, 2017 at 7:46 PM
    nDub
    Lead Free Gasoline
    Just after I disconnect the battery and only until the computer figures it out.
    Then it idles normally until the electric fan kicks on then the idle gets rough.
    I've replaced the spark plugs, battery, alternator, cleaned the throttle plate and a bunch of other vacuum related stuff. I don't think they're all related but the rough idle bothers me.
    It might be the throttle plate sensor itself but I'm not super stoked on throwing parts at it until it stops. It hasn't stalled yet so I'm just keeping an eye on it at this point.
    Also get sparadic CEL lights that seem to be temp sensitive. ABS wheel sensor maybe...
    Just for refrence this is an '07 Acura RDX.
  17. Apr 16, 2017 at 9:06 PM
    Holloman
    Holloman Well-Known Member
    chris
    nor cal Cloverdale
    2016 dcsbTRD OR
    Things and stuff
    nDub, ffdawson, Overlanerd and 8 others like this.
  18. Apr 16, 2017 at 9:11 PM
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    Holloman[QUOTED] likes this.
  19. Apr 16, 2017 at 9:23 PM
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    I hate when people do engine swaps but don't post pics of the engine in the CL ad. Typically that's their biggest selling point.
    Looks pretty cool, although I do love the simplistic interior of the 60's, so that's kind of a bummer but I'm sure it's super comfortable now.
  20. Apr 16, 2017 at 9:42 PM
    Trikster
    Trikster Well-Known Member
    Kevin
    2008 Tacoma 4x4 Double Cab
    But diffs are designed to rotate at different speeds, inside and out. When 4wd is engaged, does something lock the diff so it doesn't vary the speeds of inner/outer tires?
    Not trying to be difficult, just trying to understand what is happening between 2wd and 4wd.
