Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Jan 3, 2018 at 7:13 AM
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    If you need #10 wire I have tons of it. It cost me a few bucks for wire mold, a fused link and zip ties to run power to the rear. I hard wired mine and added a switch and tank, the whole thing took a few hrs, then later added air dryer,regulator and ARB stuff in cab.
    I would never use my tow harness as I tow my boat and would not want to replace the harness. they arnt cheap.
  2. Jan 3, 2018 at 7:20 AM
    scocar
    scocar hypotenoper
    Yeah, I understand all small wire is a fire fuse stuff. Just pointing out the source. For the hot lead on a seven pin, my ass-umption would be that is is run through a 30A fuse under the hood at least, and that it is not just for lights (all the little wires do that) but instead is intended to provide power to and charge various trailer accessories, such as battery (this is the case for my camper, and runs through its own fuse block and also an inverter for shore power for lights, stereo, whatever) or even a hydraulic pump for a dump trailer and the like. When this actually becomes enough of a priority for me, it may just require a little investigation in the FSM and under the hood and in the owners manual rather than, you know, destructive testing.
    In my old house, the laundry room had a janky looking wiremold circuit running around the perimeter with an outlet or two and ending in a light switch. I dug into it and found that they had dropped down a wire gauge at one point, and gone back up a gauge farther down the circuit. Shall I even mention the scotch tape trying to hold the wire nuts on? I think I said something like "you fucking cunts" and called an electrician.
    BudMan, LTDSC and the glen like this.
  3. Jan 3, 2018 at 7:28 AM
    the glen
    the glen Well-Known Member
    Glen
    penisula
    2012 TRD Off-Road 6SP manual spruce mica Taco
    Icon 2.5 remote res. Coilovers front, icon 2.5 rem res shocks rear, deavers 10 pack leafspring rear. Light racing ouca. Cmc, avid light bar, bamf sliders weld on, grillcraft mx grill, bamf light bracket with lightforce 170's. Uws toolbox, oem bed mat, weathertechs f/r, hella airhorns, trd antenna, talegate mod, Clifford alarm, budbuilt full skid plate set. All pro rear bumper. Superbumps bumpstops. Bulldog lighting reverse led lights in bumper. Trd short throw shifter. Cobra cb, firestick 4' ant. Icon LCA skids. Bamf rear dif skid. Hi lift x-treme mounted with relentless rail mounts in bed. Full size method/bfg in bed. Crown performance ss/Kevlar brake lines. Power tank mounted in bed. Rigid d2s mounted on relentless hood mounts. H3R quick release fire extinguisher mounted to driver's seat. Redline hood struts.
    Thanks brett.
    BudMan[QUOTED] likes this.
  4. Jan 3, 2018 at 7:29 AM
    the glen
    Glen
    penisula
    Ha ha, i know i was just lazy. But look, i got the answer from brett in 2 minutes, would have taken me longer to look it up.
  5. Jan 3, 2018 at 7:43 AM
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    your source is a tundra, my point is to check your fuse box before doing this, 1st gen 2nd gen and 3 rd gen Tacoma all different then a tundra in towing. if your 30 amp to the rear go for it, I wouldn't, as 30amp on your comp is max load but its a motor and should be sized higher to handle lock rotor, but that electrical stuff that's most do not understand. I caution you in using the harness for those reasons. check your fuses first at least. Im not sure 1st gen are 30 amp nor am I sure any of the Tacoma's are. why I said to check. Not trying to argue but you seem hard headed about this
    before you do that mod ask yourself these ?s
    have you checked to see if your harness is 30amp?
    do you use yours for towing?
    what is lock rotor amp on my compressor?
    do I have time to run a dedicated wire and be worry free or am I just lazy as fuck?
  6. Jan 3, 2018 at 7:57 AM
    Whitebutler
    Whitebutler No need to compensate!
    From up in dem woods
    06 black sand Perl access cab. 99 T4R
    33s and stryker440 10 meter conversion to 11 radio
    Who's doing TW stickers? I have the equipment and ability just don't want to step on toes.
  7. Jan 3, 2018 at 8:14 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
  8. Jan 3, 2018 at 8:51 AM
    Whitebutler
    Donde?
  9. Jan 3, 2018 at 9:08 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
  10. Jan 3, 2018 at 9:09 AM
    Tee Arghhhhhh Dee
    Tee Arghhhhhh Dee is typing...
    Jay
    Bay Area
    2011 SW DCSB 4x4 4.0L V6 Manual
    Stuff
    Been working so damn much lately, haven't had time to take a day off or check my vacation time. Looks like I just hit a month of paid time off. Should be a fun Spring/Summer! Couple more weeks of slaving away and then time to start having some fun again.
    916TacoTruck, nDub, BudMan and 10 others like this.
  11. Jan 3, 2018 at 9:18 AM
    Bentrodder
    Bentrodder PeeRunner Fanboy
    Peter
    Cotati, CA.
    2015 DCLBFTMFW TRD Sport
    Kings and a TW DECAL!!!
    I have a few accrued but they never let me take it!
  12. Jan 3, 2018 at 9:19 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Boobs and beer
    BudMan and 90yota like this.
  13. Jan 3, 2018 at 9:23 AM
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
  14. Jan 3, 2018 at 9:32 AM
    Gply
    Gply Well-Known Member
    Bay Area, CA (east bay)
    2015 Tacoma DC TRD off-road
    More shit then I ever planned on doing
    New computer program at work. :annoyed::frusty:
  15. Jan 3, 2018 at 9:43 AM
    Tee Arghhhhhh Dee
    Jay
    Bay Area
    Stuff
    Time to go into business for yourself and open up Long John Peter's Fab (ULOUS) Fab Shop.
  16. Jan 3, 2018 at 10:02 AM
    siznarf
    siznarf Everyone my age is older than me...
    Francis
    Kommiefornia
    08 Taco
    91 Octane
    grdgz97[QUOTED] likes this.
  17. Jan 3, 2018 at 10:10 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Wood
    Anderson likes this.
  18. Jan 3, 2018 at 10:10 AM
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    im sure a lot of folks up there will be pissed off. Its a lot of jobs, and a nice perk to living up there.
    Holloman likes this.
  19. Jan 3, 2018 at 10:15 AM
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
  20. Jan 3, 2018 at 10:31 AM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    theres still burger flipping and cashier jobs available. Oregon will do just fine.
    Don5352 likes this.
