Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Mar 20, 2018 at 2:00 PM
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    Dumbass. :cool:
    (Said like Red from that 70s show)
  2. Mar 20, 2018 at 2:14 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Yessir.
    Remote resi only serves two purposes:
    1) Larger oil & nitrogen cavities = More cooling, less shock fade
    2) Attract bros so that they bend over and hunch down in front of your tire to stare at the bling leaving them open for surprise buttsex.
  3. Mar 20, 2018 at 2:16 PM
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    Saved the best benefit for last. Only reason I upgraded :evil:
    Anderson, MJonaGS32, IronPeak and 4 others like this.
  4. Mar 20, 2018 at 2:20 PM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    Last question - if i get the standard travel, can they be upgraded to extended travel later? If i remember right, there's a shim you remove or something like that
  5. Mar 20, 2018 at 2:21 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I can't swear to it on the first gens.
    Typically speaking there's a 1/4" top out spacer you remove to make them extended travel. Equates to about 1/2" of additional droop travel.
  6. Mar 20, 2018 at 2:24 PM
    Tee Arghhhhhh Dee
    Tee Arghhhhhh Dee is typing...
    Jay
    Bay Area
    2011 SW DCSB 4x4 4.0L V6 Manual
    Stuff
    LP is always my go to, Super Famoso Burritto followed by tears and regret, then a nap.
    rob1208, MJonaGS32, nDub and 3 others like this.
  7. Mar 20, 2018 at 2:24 PM
    FirstTimeFirstGen
    David
    Pacifica
    i guess ill call DSM and make sure
    DSM said they believe that this is the case. But this makes me question, is the difference between the extended travel and standard travel really only 1/2"? Or am i better off waiting and ordering the real extended travel versions later (since they're backordered 4-6 weeks and not on ebay)?
  8. Mar 20, 2018 at 2:40 PM
    tacomgee
    Blake
    NorCal - Ukiah
    Is the small bit of travel worth passing up on a deal? Especially considering you might be able to make them extended travel by removing said spacer later
    2BeersPlease, Fernando and BudMan like this.
  9. Mar 20, 2018 at 2:45 PM
    FirstTimeFirstGen
    David
    Pacifica
    That's what I'm wondering. Does the extended travel version have significantly more travel than the standard after removing the shim/ spacer? To the point of, is buying the standard travel (even at a deal) a waste of money since the extended travels have significantly more travel?
  10. Mar 20, 2018 at 2:48 PM
    BudMan
    BudMan knee scooters R us
    Bret
    Alameda, CA, (Bay Area)
    06 TRD Sport DC 4x4
    stuff
  11. Mar 20, 2018 at 2:50 PM
    DannyBFresco
    Danny
    "And who couldn't use another half inch?"
    - Any NorCal TW member
    Speedo, Anderson, Holloman and 7 others like this.
  12. Mar 20, 2018 at 2:51 PM
    tacomgee
    Blake
    NorCal - Ukiah
    Im just gonna quote what Jason said a few minutes ago. Doesn’t seem to be much difference.
    Then again, I’d happily take the 1/2”
    Need all the help i can get:(
    Anderson, rob1208, Gply and 1 other person like this.
  13. Mar 20, 2018 at 2:53 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Can't speak to the ebay seller. But King fulfills their orders to their vendors. They sell what they sell. Anything ordered separate from what's in stock at a vendor goes into a specific order which will built to order by King (which is normally 1-2 month wait).
    And yes, the extended travel is just a tiny bit more travel (and only droop travel). It's not long travel by any means. You are still going to be limited by ball joints/uniballs and CV binding.
  14. Mar 20, 2018 at 2:59 PM
    FirstTimeFirstGen
    David
    Pacifica
    No i understand what Jason said, my question is how does this extra 1/2" compare to the actual extended travels, like when you order the extended travels from king, do they have more than just +1/2" over standard? Or is that all king does for the extended travel - remove the shim/spacer?
  15. Mar 20, 2018 at 3:01 PM
    FirstTimeFirstGen
    David
    Pacifica
    Thank you for clarifying, this was the whole bit of info I was wondering about.
    Me :spending:Ebay
  16. Mar 20, 2018 at 3:01 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
  17. Mar 20, 2018 at 3:04 PM
    tacomgee
    Blake
    NorCal - Ukiah
    My understanding is its the same shock just without the spacer :notsure:
  18. Mar 20, 2018 at 3:05 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    See below. Obviously a larger shock, but part 17 gets removed. Typically an integral part of shocks to keep the shaft leverage to a minimum. But with shorter body shocks that are coil carriers, the shaft spacer is very small and the coil keeps the shaft from deflecting.
  19. Mar 20, 2018 at 3:06 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    cute GFC camper...
    too soon?
  20. Mar 20, 2018 at 3:08 PM
    DannyBFresco
    Danny
