Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Jun 10, 2018 at 4:08 PM
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    Spotted in uc/Fremont on Alvarado. Went into the Safeway parking lot. Never seen it before in the area, nice truck
    thebaker likes this.
  2. Jun 10, 2018 at 4:22 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    Camping/truck buddy is gonna be a boy!!!!!
    Holloman, tacomgee, Rmoreno1 and 31 others like this.
  3. Jun 10, 2018 at 4:23 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    You had to see the road to get there though.
  4. Jun 10, 2018 at 4:23 PM
    T4RFTMFW
    Congrats bro!
  5. Jun 10, 2018 at 4:32 PM
    KMFDM_V
    KMFDM_V Well-Known Member
    Ken
    Sacramento, CA
    09 Timberland Mica 2.7L 5MT 4x2 Access
    I may have tweaked a few things...
    Yeah I have to remember to retighten in a week or two just to make sure I don’t end up like that either.
    AAL install went super smooth, I really enjoyed that one! @little squirt these are the AALs you tagged me on a while back. I scooped them up and have been sitting on them for a bit.
    Got my rake back. Also reduced the forward/backward movement when shifting and the side to side wobbling when going over bumps unevenly with left/right tires. Guess my tail was even squishier than I had realized, i’ve been so focused on the front suspension.
    * autocorrect corrections
    TOP TACO, 2BeersPlease, nDub and 2 others like this.
  6. Jun 10, 2018 at 4:33 PM
    thebaker
    thebaker Well-Known Member
    Byron
    NorCal
    Upgraded to a 3rd gen
    Never ending......$$$
    New some help....I'm running a temporary 12v out to the bed of my truck to power my whynter frig. I'm running the wire from my blue sea fuse block under the hood and am going to ground the 12v in the rear of the truck. What size fuse should I use?
  7. Jun 10, 2018 at 4:55 PM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    Is there any info on the fridge as to how many watts or amps it is?
  8. Jun 10, 2018 at 5:22 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Outstanding! Congratulations to you both!
  9. Jun 10, 2018 at 5:39 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    Would sell a nut for Jimmys SAS rig. Having a kid and 5 more embryos on ice. No need for nuts anymore!
  10. Jun 10, 2018 at 6:10 PM
    thebaker
    Byron
    NorCal
  11. Jun 10, 2018 at 6:14 PM
    FirstTimeFirstGen
    David
    Pacifica
    It says it only pulls 5.5 Amps to run. Not sure if there's an initial startup amp spike. What gauge wire did you run?
    Just based off this info, assuming the wire can carry the load, I'd suggest 20 amps and see how that works. You really only need the fuse to prevent a wire fire in case of a short. So you want a fuse that will handle enough current for the fridge but will handle less than the max current for thr wire. I think I explained that right.
    Care to chime in @Iggy and @EDDO?
    thebaker[QUOTED], Speedo and nDub like this.
  12. Jun 10, 2018 at 6:15 PM
    thebaker
    Byron
    NorCal
    I ran 12guage
    EDDO likes this.
  13. Jun 10, 2018 at 6:20 PM
    FirstTimeFirstGen
    David
    Pacifica
    I'd say a 20 amp fuse should be fine as long as it holds up to the initial kick on amp spike of the fridge. It should definitely blow in case of a short before the wire catches fire.
    thebaker[QUOTED] likes this.
  14. Jun 10, 2018 at 6:23 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I am losing my faith in humanity
    I can’t believe how tiny that 5-lug next to it is in comparison.
    E313F6BD-E08F-46B1-B9D1-2D5C87E4569F.jpg 0E120D81-D262-49B1-A891-6BB0E3E0CCB2.jpg
    IronPeak likes this.
  15. Jun 10, 2018 at 7:47 PM
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    Woot! 2018 year of the boys. When’s he due? My boy is due September.
    MJonaGS32 and thebaker like this.
  16. Jun 10, 2018 at 8:17 PM
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    I 3rd this. My wife bought an elipticle machine that became a cloths rack and my son broke his leg on it play around. Well worth the money. Said no one ever. Lol
  17. Jun 10, 2018 at 8:26 PM
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Correct, but remember DC has a huge voltage drop on lenght of run. So over size the wire fuse to max rating on device but keep it under wire size rating. Voltage drop on lenght of run for 12v dc/ amps needed can be found online.
  18. Jun 10, 2018 at 8:31 PM
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    20180610_192554.jpg making progress, Just need some aluminum to skin the bumper.
    And some small rivits for the hood pins. And she will be ready to wheel.
    The list is still long to finish, but at least she wheeling soon.
  19. Jun 10, 2018 at 9:02 PM
    FirstTimeFirstGen
    David
    Pacifica
    I dont believe (although I am a much less trained electrician than you) that his 8-10 ft of wire will be significant in voltage drop. Especially since he used 12 GA for a 5.5 amp circuit. I mean, some fuel pump wires are 14 GA and I'm sure a fuel pump pulls more current than 5.5 amps.
    At least pretty sure. Watch, Jason's gonna make me eat my words, then take a victory shot.
  20. Jun 10, 2018 at 9:13 PM
    Moogle
    Moogle Dyslexic Stanist
    Glen
    Alameda, CA
    07 Silver TRD Sport DCSB 4x4 6-speed
    Blood of virgins
    Thank Jesus it works.
