Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Apr 15, 2019 at 10:36 PM
    SnowB0und
    SnowB0und Well-Known Member
    4cyl 4x4
    Someone has the Meat Head book :)
  2. Apr 16, 2019 at 5:38 AM
    Whitebutler
    Whitebutler No need to compensate!
    From up in dem woods
    06 black sand Perl access cab. 99 T4R
    33s and stryker440 10 meter conversion to 11 radio
    See there you have something in common with her.
  3. Apr 16, 2019 at 6:27 AM
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    There is a video of a stock crv or jeep compass there took through during the jamboo a few yrs back. It was beat up but made it.
  4. Apr 16, 2019 at 6:59 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Those things suck. No power at all
  5. Apr 16, 2019 at 7:43 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Nice! I smoked some pork butt the other day. I only finished it in the smoker though.
    What’s this thing on your grill?
  6. Apr 16, 2019 at 7:58 AM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Half a broken pizza stone. The other half is on my gas grill...
    Poor mans griddle :D
    Also kind of acts as a heat deflector thing.
    I also added a couple of bricks as heat sinks. Works better than a bowl of water IMO.
  7. Apr 16, 2019 at 8:05 AM
    otis24
    Mark
    California
    Nice, good ideas!
    I've been thinking about building a griddle. I have access to a welder, just need to find a slab of steel for cheap. A man hole cover would be fantastic but I'm not sure where to get one legally. Also, it might be too thick and take forever to heat up.
  8. Apr 16, 2019 at 9:34 AM
    mhshark
    mhshark Well-Known Member
    Bend, Or
    Hey guys just ordered a new set of leaf springs to replace my sagging AAL. Isn’t there a member that installs for a fee on here? I installed the AAL with some help (and tools, don’t have my own) but the brake lines and possible shims have me a bit nervous.
  9. Apr 16, 2019 at 10:11 AM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    Not looking forward to my Friday off. CV boot replacement, drain and fill the diffs. :puke:
    Speedo, BudMan, Whitebutler and 4 others like this.
  10. Apr 16, 2019 at 10:45 AM
    Don5352
    Don5352 Liberty or Death
    Don
    Oakland, CA
    2014 AC TRD OR
    Some really cool shit
    I’m out of town or I’d offer to help. Sorry.
    LTDSC[QUOTED] likes this.
  11. Apr 16, 2019 at 10:49 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    What Gen is your truck and where are you located brother?
  12. Apr 16, 2019 at 10:50 AM
    mhshark
    Bend, Or
    It’s a 2017 and I’m in the east bay. Willing to drive and buy pizza and beer if some guys oil don’t mind helping but don’t want to assume things :)
    FirstTimeFirstGen likes this.
  13. Apr 16, 2019 at 10:55 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    You've got leaf packs... What kind of leaf packs? Do you have U-bolts? Are your leafs going to give additional lift over the AAL?
  14. Apr 16, 2019 at 11:05 AM
    mhshark
    Bend, Or
    Yes sorry leaf springs isn’t the best term. I got the 4+1s from this link, I’ll be adding some weight plus run a RTT and rack.
    https://www.tacomaworld.com/threads/heavy-duty-leaf-packs-for-your-heavy-truck.547497/
    I was hoping to use the U-Bolts that came with the AAL as it’s only been on around 6 months so they shouldn’t be corroded. Leafs will likely give me around 2” more than the AAL (icon 3 leaf) as my AAL sagged a bit and is only giving me around 1”
  15. Apr 16, 2019 at 11:20 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I wouldn't be concerned with corrosion of the U-bolts. I would be looking at if the new leaf pack is thicker, overall, than the current leaf pack + AAL causing the U-bolts to not be lo g enough.
    (Also, side note, U-bolts are typically recommended to be replaced, not re-used, but I think in this case we'd just be wanting to nake sure they are long enough)
    That leaf pack also appears to give a fair amount of lift. Even if you have weight that will counteract the lift (make it not lift so hi) you will be getting additional down travel from that lift. I would recommend rear brake lines to go with them, and what amount of lift are your shocks rated for? That leaf pack may over (down) travel your shocks if they aren't long enough.
  16. Apr 16, 2019 at 11:31 AM
    mhshark
    Bend, Or
    I’ll see if the member can measure the leaf pack and I’ll crawl under to measure my current leaf pack +AAL no problem
    I’m getting some brake lines for sure to cover the added travel. I’m on 5125s from wheelers currently and think they’ll cover the down travel from the new leafs. Here’s a spec on them.
    https://www.4wheelparts.com/p/bilst.../R-BBGL-33-230337?Shock+Series_PQ=5125+Series
  17. Apr 16, 2019 at 11:33 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    @mhshark... Not tryin to pepper you with questions or tryin to upsell you on a bunch of shit to overwhelm you.
    I'm good with you bringing your stuff over and we'll make it happen. I just want to make sure you have all the right parts and pieces, so you don't end up with a dead horse in my driveway :thumbsup:
  18. Apr 16, 2019 at 11:43 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Good, you're on the right track.
    New brake lines ✔
    5125s should be fine ✔
    (Looks like you already upgraded rear shocks. Just wanted to make sure. Sometimes people think they can run stock with AAL, and with what the leafs appear to lift, that wouldn't work... for very long)
  19. Apr 16, 2019 at 11:44 AM
    mhshark
    Bend, Or
    All good man!! I appreciate the help! I’ve read up on things and done some stuff on rigs so I’m not a complete beginner but still have a ton to learn!
    To summarize:
    I’ll make sure the U-Bolts are long enough, if not I’ll order new ones
    Getting brake lines
    Sticking with my 5125s, possibly upgrade to B110s in the future
    Think I’m cool? Thanks for all the help man!! I’ll hit you up once I get the stuff in! You da man!
  20. Apr 16, 2019 at 11:46 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Yep... What you're looking at doing is a workable plan. Just hit me up when you're ready and we'll knock it out.
    Hopefully @essjay will have his front shocks around the same time, and we can fix him up too.
    :boink:
    Motofox and Taco-Obsessed like this.
