Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. May 23, 2019 at 6:52 AM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
  2. May 23, 2019 at 7:00 AM
    Twizted
    Twizted 1GR FE
    Rob
    America
    '15 DCLB TRD Locked 4WD & '17 Tundra DC SR5 TRD Offroad
    stock af, but hover if you think you disagree... RV living: Vagabond Drifter (6' bed) Custom bed cabinet buildout 175w Renogy solar panel 40a Rich Solar MPPT solar controller 1000w Wagan Pure Line inverter Lavaner Pro 2kw diesel heat exchanger Suspension/wheels: Toytec Aluma 2.5 front shocks with resis 13x700 coils (soon 14x700) Toytec Aluma 2.5 rear shocks SPC UCAs Deaver Stage 3 rear leaf springs Wheeler's 3 degree axle shims Wheeler's U-bolt flip Wheeler's Super Bumpstops 18"x9" XD Monster (x5) 275/75/18 Cooper ST MAXX (x5) EBC Stage 3 pads/rotors Electronics: Kenwood DNX773S iDatalink - Maestro RR Stubby Antenna No-name Switchback LEDs Hella Sharptone horns (no relay) Relocated backup camera w/DIY bracket Armor/recovery: BruteForceFab Rear HC w/swingout BAMF Sliders (DOM, 10 degree w/kick out, rattle-canned) BAMF IFS Skid (BAMF powder-coated) BAMF Mid Skid (BAMF powder-coated) BAMF TC Skid (BAMF powder-coated) BAMF LCA Skids (BAMF powder-coated) BAMF Rear Diff Skid (early model, powder-coated) BAMF CMC Plates US Offroad Winch Bumper Smittybilt X20 10k synthetic rope winch Total Chaos Bed Stiffeners ARB compressor w/air-up kit DIY cowl snorkel ARB rear air-locker Interior: Husky Floor Liners (F&R) Rear 40% seat-delete Hinged fridge platform in place of rear seat Exterior: CaliRaised Low-profile Ditch Light Brackets CaliRaised Side-projecting LED pods CaliRaised Faux TRD Pro Grille Morimoto amber LED fog lights One-of-a-kind 1GRFE plate (second iteration) Removed: OEM Bed Mat CaliRaised bed molle panels
  3. May 23, 2019 at 7:16 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Justin
    Elk Grove, Ca
    I can't get to the vid here at work, bear with me lol...
    I'd doubt AutoZone's starter bench-test process too. Got an amp clamp handy? You could measure the actual starter draw while it's trying to crank the engine over.
    Was that 11.6v on the battery how far it dropped under a load test, or was that the surface charge amount? Less than 12.5v surface charge, and that battery isn't fully charged. If that 11.6v is under load (like from a carbon-pile load tester, e.g. VAT40), that battery's in great shape. How did you test it?
    Resistance testing cables/circuits is nice & all, but I'd recommend to voltage-drop test those battery cables. You could only have one strand of copper still connected and pass a resistance test. Load testing or voltage-drop testing is much more reliable.
    How's the starter relay? Any fretting on the terminals?
    Also, didn't see it in the post (might've missed it), but how's the negative battery cable where it connects to the block? Not familiar with a SC install on the 3RZ, so curious if any ground cable locations were moved as a result? (and admittedly when I worked at Toyota 20 years ago, these new Tacomas never showed up for anything but oil changes and tire rotations - I left for Chevy before the first Tacos were out of warranty lol)
    FirstTimeFirstGen, nDub and Anderson like this.
  4. May 23, 2019 at 7:21 AM
    Whitebutler
    Whitebutler No need to compensate!
    From up in dem woods
    06 black sand Perl access cab. 99 T4R
    33s and stryker440 10 meter conversion to 11 radio
    Damnit!!!!
    I need tailgate protection. Who has a tailgate plate or cover or stiffener? I need to get one very soon.
  5. May 23, 2019 at 8:55 AM
    waldeeeeen
    waldeeeeen Well-Known Member
    Walden
    Mosquito CA
    01 Tacoma 4x4 SR5 TRD 5sp
    Folsom over by Datons point where during the summer there's some rock outcroppings and areas to explore around
  6. May 23, 2019 at 9:08 AM
    drewhaus
    drewhaus Well-Known Member
    Andrew
    El Granada, CA
    2018 Tacoma
  7. May 23, 2019 at 9:37 AM
    Red18Taco707
    Red18Taco707 Well-Known Member
    Richi
    Nor Cal
    Red 18 TRD POOR
    Carrying some hard wood... oak for days.
    ED823417-8A40-4793-9A55-C0CE5CEDBC40.jpg 749A2FD3-B8A4-4169-A468-3607A8843C0A.jpg
    nDub, IronPeak, essjay and 8 others like this.
  8. May 23, 2019 at 11:32 AM
    Taco-Obsessed
    Spotted in San Jose off of Blossom Hill. Dood slowed down and threw up a peace sign to me as I was getting out of my truck at subway. White lifted second gen. Any of you knuckleheads?
    TOP TACO likes this.
  9. May 23, 2019 at 11:56 AM
    Longboard1110
    Longboard1110 ...................
    San Jose
    A few things
    Sounds like me and in my hood but not me
    Taco-Obsessed[QUOTED] likes this.
  10. May 23, 2019 at 12:07 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I’m pretty sure the are, but getting it to start is one thing - right now the starter isn’t spinning fast enough to even get it started.
    FirstTimeFirstGen likes this.
  11. May 23, 2019 at 12:13 PM
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    Yeah that was my issue, but the V6 wires are easy to mix up.
    nDub and BartMaster1234[QUOTED] like this.
  12. May 23, 2019 at 12:15 PM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    Try to find out how many amps that starters drawing. Probably needs a starter - assuming all connections are good and battery is good. Quick check to isolate the starter. Do a voltage drop test. Check your source (battery voltage) voltage. Then have someone crank the engine while you check the voltage difference between the starter terminal that gets power only when cranking and the starter case (ground). If you drop source voltage (or really close to) across the starter, either you have an engine drag concern or it's the starter. Have you rotated the engine by hand to make sure there isnt an issue with the supercharger not rotating smooth? A locked up belt pulley can cause a slow crank and no start issue.
  13. May 23, 2019 at 12:27 PM
    Longboard1110
    San Jose
    A few things
    X2, I have his one and it’s on there, no problems does it’s thing
    Whitebutler likes this.
  14. May 23, 2019 at 12:50 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Gotta give the guy props.... Nothing like going out your way to make a web site to officially announce to the world that you're a whining douchebag.
    CalTacoma09, nDub, SR-71A and 10 others like this.
  15. May 23, 2019 at 12:55 PM
    FirstTimeFirstGen
    David
    Pacifica
    That hydrolocked engine through that small amount of water is pretty concerning though in my opinion...
    CalTacoma09, Don5352 and LTDSC like this.
  16. May 23, 2019 at 12:59 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    after seeing how many 3rd gen motors my friend is replacing for stupid stuff, no chance i'd trust nor own a 3rd gen.
  17. May 23, 2019 at 1:01 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Ya, but well I am willing to bet you a dollar we aren't getting the whole story on that.
    I have personally witnessed multiple 3rd, 2nd, and 1st Gens doing water crossings with no issues.
    I'll talk shit about 3rd Gens all day long. They do have their quirks, (but so does every other vehicle). I personally wouldn't buy one, but that has more to do with I haven't had a truck payment in about 8 years and I kinda like it that way. But I would put the 3rd Gen Tacoma and it's capabilities up against pretty much any other truck or SUV currently on the market and be comfortable with it's performance. (Not saying it's better than anything else out there, but that I would be comfortable with they way it performed vs any of the other options).
    CalTacoma09, nDub, Anderson and 4 others like this.
  18. May 23, 2019 at 1:08 PM
    FirstTimeFirstGen
    David
    Pacifica
    Same here at @Fernando's second home last year. When I saw the water over the hood, I thought, "well, I just bought a motor." But kept plowing through. Got over to the other side, pulled the air filter and let it dry a little bit (bottom was minorly wet), and went on my merry way.
  19. May 23, 2019 at 1:09 PM
    FirstTimeFirstGen
    David
    Pacifica
    I'd take it over the Colorado with their "side airbags randomly deploying" issues
  20. May 23, 2019 at 1:19 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    same. I I don't pussy foot thru water crossings. Love my old (best gen) truck
