Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Nov 12, 2019 at 9:30 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    happy birthday to you too
    Holloman[QUOTED] likes this.
  2. Nov 12, 2019 at 10:02 AM
    TOP TACO
    TOP TACO Well-Known Member
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Mademan925 and Holloman like this.
  3. Nov 12, 2019 at 10:58 AM
    kalieaire
    kalieaire i didn't know they stacked sh*t that high.
    Santa Clara County
    '12 TRD Off-Road 4x4 AC V6 6MT
    Adventure Trailers Atlas, Demello Sliders, BAMF Skids, PelfreyBilt Bumpers, SCS Ray 10
    PWM is best in terms of price for us folks. They're an amazing value when the solar systems are small and you're running single or double panels in parallel. Also fantastic when the solar cells are above 113 degrees fahrenheit.
    MPPT begins to show its value at 10x times the cost when you have larger arrays configured in series (think 4+ panels) because it can boost the voltage to take advantage of long and, relatively, thin wire runs from panels to battery banks.
    MPPT does have one really important advantage, it's being able to pull more power out of the panels when they're cold. So if you're camping a lot in the winter and the panels don't have a high surface temp (above 113 degrees fahrenheit) then this is where you'll want an MPPT in place.
    Damn, wish I knew about that. I would've posted the one my friend took of my truck. lol
    69648291_10100384361224168_2244214355979_bf7c260a19f16c630b53a4937e7bec9fe46f665a.jpg
  4. Nov 12, 2019 at 11:46 AM
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    Am I safe in assuming you will still get some (enough..?) charge out of sub 113 degree solar cells? I'm not so much as worried about winter camping, since I'll be able to start my car on a somewhat regular occurrence, as I am just leaving it parked out front for a week or two at a time without starting.
  5. Nov 12, 2019 at 12:06 PM
    kalieaire
    Santa Clara County
    It's just a question of efficiency. Maximum Power Point Tracking chargers have an automated voltage booster.
    The voltage output of Solar Panels/Cells fluctuate depending on strength of the sun against the panels. This can be changed by angle, clouds, atmospheric issues etc. MPPT Controllers can boost or buck the voltage. Pulse Width Modulating controllers can only buck the voltage when it approaches the maximum.
    If you want to compare PWM to an every day thing you encounter, think of a gas pump at the service station. You can hold it open to fill up the tank or pull the trigger successively to slow down so the gas doesn't flow out over your fuel inlet.
    With MPPT, the size of the nozzle can be opened up to allow even more flow out at a higher volume depending on the changing conditions.
    PWM gets the job done and is 10x cheaper.
    While MPPT as a whole are more efficient, I've seen a lot of 1-star Amazon reviews talking about how their MPPTs didn't last and returning them was a hassle. The Victron boxes are a lot better in terms of quality, but they're not invincible either.
    tyfoon11, otis24 and Gunshot-6A like this.
  6. Nov 12, 2019 at 12:12 PM
    2BeersPlease
    2BeersPlease Well-Known Member
    Mademan925 likes this.
  7. Nov 12, 2019 at 12:17 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Lookup AntiShanty trailers. Looks like he was the OG concept.
    Fernando[QUOTED] likes this.
  8. Nov 12, 2019 at 12:33 PM
    tyfoon11
    tyfoon11 Raguel
    J
    Where bald eagles roam, Ca
    garden shed
    Awesome info Stan, thanks! This is the kinda stuff I need.... solar for dumbasses tutorials!
    https://youtu.be/kF_cVEYxj3E
    Not the most in depth review but watched this video, one takeaway was that the Victons are good but the wiring clamp thingies are flimsy. Any thoughts? I need an MPPT controller for a 220 panel, still trying to find a good option that doesn't break the bank, but buy once cry once
  9. Nov 12, 2019 at 1:36 PM
    kalieaire
    Santa Clara County
    The additional takeaways from the video worth noting.
    • PWM can outperform MPPT in certain conditions
    • MPPT is maybe 3% more efficient in a single panel configs in the real world
    • Fast tracking MPPT in the victron doesn't really account for a whole lot in the course of an entire day, maybe like 10 watt-hours total?
    • Using Lead Acid, get a model with a temp sensor
    • Running lithium, you might need a fancy MPPT because most (if not all) pwm controllers don't have lithium specific features (exception for batteries that are direct swap meaning they have Battery Management Systems [BMS] that can convert 12v to 11.1v lithium)
    • Run pigtails with Victron to a junction box or learn how to solder Surface Mount BS.
  10. Nov 12, 2019 at 2:35 PM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
  11. Nov 12, 2019 at 3:22 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    @Uphillshunter sorry broe. just saw your tag. I didn't see it till just now. Not sure i have a pic with a wreath? I think they have to be high res pics too. Most off mine are with cell. I got lucky felipe snapped that one last year. I need to snag more from the guys with legit cameras. I love this one
  12. Nov 12, 2019 at 4:26 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    That's a good pic brotha. You should have submitted that one!
    But you could always vote for one of these... to help a 1st gen local brotha out :rolleyes:
    https://www.tacomaworld.com/threads...eneration-tacomas.637016/page-3#post-21986845
    https://www.tacomaworld.com/threads...eneration-tacomas.637016/page-3#post-21986816
  13. Nov 12, 2019 at 5:02 PM
    MattJakobs
    Matthew
    NorCal
  14. Nov 12, 2019 at 5:15 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Blue Canary likes this.
  15. Nov 12, 2019 at 5:51 PM
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    CalTacoma09, Holloman and rob1208 like this.
  16. Nov 12, 2019 at 6:08 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Already did brothers.
  17. Nov 12, 2019 at 6:10 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Holy edit batman. I need to lay off the drugs
  18. Nov 12, 2019 at 6:15 PM
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
  19. Nov 13, 2019 at 8:08 AM
    DannyBFresco
    Danny
    Anderson[QUOTED] likes this.
  20. Nov 13, 2019 at 2:22 PM
    K_Sandhu
    K_Sandhu Well-Known Member
    Karan
    Castro Valley, CA
    2017 Double cab TRD off-road 4x4 long bed
    Anyone has experience with front wheel hub assembly? It looks like pick inside the bearing is causing issues with ABS/traction. I found a guy on TW that sells pre-assembled hubs with koyo bearings. Has anyone used him?Not sure if rest of the assembly is OEM. Or should I buy the press and bearing from stealership?
