Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Jan 19, 2020 at 1:07 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Sperrunner
    Area51Runner likes this.
  2. Jan 19, 2020 at 1:08 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    It was a sea of red and gold this morning as peeps were eating breakfast. One or two Green Bay fans walked in and a few people suggested they might spit in their food :D
  3. Jan 19, 2020 at 1:36 PM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    i need some advise to get the breather line attached to my front diff housing. this is the 3rd (last?) issue i need to fix from gear/locker install.
    1st: shop (bastards) nipped the inner cv boot on driver's side so it was leaking. replaced it with a Duralast axle (not impressed). i'm going to rebuild the OEM axle if i can ever get the bearings off. this is another story.
    2nd: shop (bastards) shredded the 10mm hex on the front diff drain plug. i tried to jb weld a hex socket on there - total failure. paid a muffler shop $10 to tack it on. problem solved. oil was metallic colored and there was a fair bit of metal on the magnet after 1,500 miles. happy to have fresh oil in there.
    3rd: breather tube came off front diff
    i read some threads about 3rd gen issues with diff oil spouting out of the breather which is located in the engine bay. it appears the heat and pressure in the diff causes oil to go up and out the breather tube. this is likely to occur after filling with oil as oil level is normalized by purging excess oil out the breather. in my case the oil that would be cruising up and down the breather tube with hot/cold cycles is landing on the driveway because the breather tube was not attached by the shop.
    here's the problem: i can't seem to get a hand or tool in there to attach the breather tube.
    truck is on jacks. i feel like if it was on a lift it may be possible to reach up and around the diff housing to get a hand on the breather tube and attach. anyone able to confirm this? how do i get this bitch on?
  4. Jan 19, 2020 at 1:37 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    DarthPow likes this.
  5. Jan 19, 2020 at 1:49 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Let’s go niners! Getting ready and rooting for Tennessee.
  6. Jan 19, 2020 at 2:50 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Monika! Ceviche is done. And chicken is going on.
    I perfected my ceviche recipe. Fucken fire!!!
  7. Jan 19, 2020 at 3:06 PM
    techfinsoup
    techfinsoup Well-Known Member
    Sacramento
    1996 Tacoma 4x4
    Go Niners!! been up since yesterday at 3pm! git sum!
    rob1208, MyWyfsRnnr, essjay and 9 others like this.
  8. Jan 19, 2020 at 3:11 PM
    nDub
    Lead Free Gasoline
    Nuts. I think KC is the harder team to beat in the Super Bowl.
    You know, after the niners win today.
    SUMOTNK and Whitebutler like this.
  9. Jan 19, 2020 at 3:11 PM
    techfinsoup
    Sacramento
    1996 Tacoma 4x4
    Gonna be a great matchup
    nDub[QUOTED] likes this.
  10. Jan 19, 2020 at 3:14 PM
    lawless
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    quoting myself because finally figured this out.
    needed to go at it from the front, not the back. i didn't even need to jack up the truck or remove the wheel. take the front skid plate off and i could reach the breather with some long articulating pliers.
    looks like the shop may have cut the hose that connects the breather on the diff to the breather tube that goes up into the engine bay. it was about an inch short. of course it's 3/8" id rubber hose and i only have 1/4". off to the store to get 3 inches of rubber hose. i wonder if it's supposed to be clamped on there? seems like it should be.
    Taco-Obsessed likes this.
  11. Jan 19, 2020 at 3:50 PM
    Rmoreno1
    Rmoreno1 Well-Known Member
    Chico
    Reno Nv
    93 Runner
    training wheels
    Too late to smoke turned on the Webber.
  12. Jan 19, 2020 at 3:55 PM
    Twizted
    Twizted 1GR FE
    Rob
    America
    '15 DCLB TRD Locked 4WD & '17 Tundra DC SR5 TRD Offroad
    stock af, but hover if you think you disagree... RV living: Vagabond Drifter (6' bed) Custom bed cabinet buildout 175w Renogy solar panel 40a Rich Solar MPPT solar controller 1000w Wagan Pure Line inverter Lavaner Pro 2kw diesel heat exchanger Suspension/wheels: Toytec Aluma 2.5 front shocks with resis 13x700 coils (soon 14x700) Toytec Aluma 2.5 rear shocks SPC UCAs Deaver Stage 3 rear leaf springs Wheeler's 3 degree axle shims Wheeler's U-bolt flip Wheeler's Super Bumpstops 18"x9" XD Monster (x5) 275/75/18 Cooper ST MAXX (x5) EBC Stage 3 pads/rotors Electronics: Kenwood DNX773S iDatalink - Maestro RR Stubby Antenna No-name Switchback LEDs Hella Sharptone horns (no relay) Relocated backup camera w/DIY bracket Armor/recovery: BruteForceFab Rear HC w/swingout BAMF Sliders (DOM, 10 degree w/kick out, rattle-canned) BAMF IFS Skid (BAMF powder-coated) BAMF Mid Skid (BAMF powder-coated) BAMF TC Skid (BAMF powder-coated) BAMF LCA Skids (BAMF powder-coated) BAMF Rear Diff Skid (early model, powder-coated) BAMF CMC Plates US Offroad Winch Bumper Smittybilt X20 10k synthetic rope winch Total Chaos Bed Stiffeners ARB compressor w/air-up kit DIY cowl snorkel ARB rear air-locker Interior: Husky Floor Liners (F&R) Rear 40% seat-delete Hinged fridge platform in place of rear seat Exterior: CaliRaised Low-profile Ditch Light Brackets CaliRaised Side-projecting LED pods CaliRaised Faux TRD Pro Grille Morimoto amber LED fog lights One-of-a-kind 1GRFE plate (second iteration) Removed: OEM Bed Mat CaliRaised bed molle panels
    Gonna heat some meat in a bit myself...
  13. Jan 19, 2020 at 4:13 PM
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    Downtown Walnut Creek
  14. Jan 19, 2020 at 4:54 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    I think Aaron would probably rather eat ceviche than words :D
  15. Jan 19, 2020 at 5:14 PM
    Whitebutler
    Whitebutler No need to compensate!
    From up in dem woods
    06 black sand Perl access cab. 99 T4R
    33s and stryker440 10 meter conversion to 11 radio
    Ok first half. One more to go.
    Don5352, Rmoreno1, nDub and 1 other person like this.
  16. Jan 19, 2020 at 5:18 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    That fucker dont deserve my recipe!
    Rmoreno1 and ian408[QUOTED] like this.
  17. Jan 19, 2020 at 5:20 PM
    MattJakobs
    Matthew
    NorCal
  18. Jan 19, 2020 at 5:26 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    I'm just sure he regrets what he said when asked about the 49'ers.
  19. Jan 19, 2020 at 5:27 PM
    Whitebutler
    What the hell?
  20. Jan 19, 2020 at 5:28 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I would have loved a shut out. But its ok
    Don5352, Rmoreno1, Haslefre and 2 others like this.
