Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Oct 5, 2020 at 2:55 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    There's an admin feature that's even cooler. It's called forced ignore with the option to put someone on ignore for all users...
  2. Oct 5, 2020 at 2:57 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
  3. Oct 5, 2020 at 3:05 PM
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    Anderson likes this.
  4. Oct 5, 2020 at 4:47 PM
    techfinsoup
    techfinsoup Well-Known Member
    Sacramento
    1996 Tacoma 4x4
    Anyone have a 1st Gen tow receiver hitch laying around? Looking to buy, 1996. Thanks!
  5. Oct 5, 2020 at 5:46 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    I enjoy sports.
    I don’t plan my day around it but if I’m loading I’ll watch.
    Unless it’s Michigan football... my wife swam there so die hard. She was there when Michael Phelps swam there too. He gave her freshman year roommate an std. haha. He was apparently a little wild back then.
  6. Oct 5, 2020 at 5:55 PM
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    :rofl:
    nDub[QUOTED] and Fernando like this.
  7. Oct 5, 2020 at 7:20 PM
    thebaker
    thebaker Well-Known Member
    Byron
    NorCal
    Upgraded to a 3rd gen
    Never ending......$$$
    Looking for help....i started a thread in the audio threads but thought to ask local also.
    https://www.tacomaworld.com/threads/need-rear-camera-steering-wheel-controls-help.688609/
    Im having problems with my steering wheel controls and rear view camera ony 3rd gen. In short, i have stock jbl system. Switched out head unit to aftermarket android head unit and everything worked great.
    Installed a full stereo system and now the rear view camera doesn't trigger when shifting into reverse and steering wheel controls dont work. FYI, i can manually turn on the rear view camera, it just doesnt trogger when shifting into reverse.
    I even hooked up the stock jbl radio and the rear view camera and steering controls still dont work.
    Not sure what to look for to try and fix this problem.
    K_Sandhu likes this.
  8. Oct 5, 2020 at 7:31 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    You need something like Maestro for the steering wheel controls. You probably also need to check your wiring.
    thebaker[QUOTED] likes this.
  9. Oct 5, 2020 at 7:37 PM
    Whitebutler
    Whitebutler No need to compensate!
    From up in dem woods
    06 black sand Perl access cab. 99 T4R
    33s and stryker440 10 meter conversion to 11 radio
    I still love to watch MST3000. Now thats tv that makes sense!!!
  10. Oct 5, 2020 at 7:38 PM
    thebaker
    Byron
    NorCal
    Everything was working fine before. When i added the stereo system all i added to the stereo waa plugging in the rca cables and the remote amp turn on wire.
    The andriod stereo was working fine with the stock jbl system.
  11. Oct 5, 2020 at 8:49 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Check your work then.
  12. Oct 5, 2020 at 10:41 PM
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    when you switched from the stock JBL to the android HU did you have to use a new harness?
  13. Oct 5, 2020 at 10:49 PM
    thebaker
    Byron
    NorCal
    Yes, used a new harness for the android HU which included a canbus. When i switched over the the android HU everything worked fine. However, after adding the amps and speakers for the audio install, i cant get the reverse camera to trigger on or my steering wheel controls to work. My rear view camera will work if manually turn it on.
  14. Oct 5, 2020 at 11:08 PM
    roguegs
    Angelo
    V8 T4R
    I’ve never done an audio install myself but I feel like there might be somewhere where a wire got spliced on accident that turns on your reverse trigger wire for the backup since it doesn’t work only when going into reverse. Steering wheel controls might also be a doozy. Is there a fuse that is only for steering wheel controls?
  15. Oct 5, 2020 at 11:15 PM
    thebaker
    Byron
    NorCal
    Im researching right now on what fuses to check....so frustrating....
  16. Oct 5, 2020 at 11:29 PM
    roguegs
    Angelo
    V8 T4R
    I have a feeling there might be some loose wires on the back of a harness somewhere...I hate electrical
  17. Oct 6, 2020 at 12:00 AM
    thebaker
    Byron
    NorCal
    Ive triple checked everything. I even put to stock radio back in and still no reverse camera vis the trigger or steering controls.
    Im thinking it has to be a fuse but not sure what fuses to check.
  18. Oct 6, 2020 at 4:50 AM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    It will take less time to test them all. Use the holes in the top of the fuse and you don’t have to pull them.
  19. Oct 6, 2020 at 5:46 AM
    Don5352
    Don5352 Liberty or Death
    Don
    Oakland, CA
    2014 AC TRD OR
    Some really cool shit
    I think it's been that way for at least a year. That's been my experience, anyway.
    Twizted likes this.
  20. Oct 6, 2020 at 5:54 AM
    Don5352
    Don
    Oakland, CA
    2014 AC TRD OR
    Drove right by your office Satruday. I know, you don't work Saturday. Are you still in the same building? I was on my way to VA for a flu shot. Got me thinking about Tacos. And Kinders. Mmmmmm
