Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Jul 14, 2021 at 9:05 PM
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    Yeah
  2. Jul 14, 2021 at 10:09 PM
    TOP TACO
    TOP TACO Well-Known Member
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    :devil::bananadead:
  3. Jul 14, 2021 at 11:12 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I wonder how this effects a piggyback ecu like a 7th injector kit
  4. Jul 14, 2021 at 11:36 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    If it’s smog legal, it has a carb Sticker, all good. If not, disconnect it.
  5. Jul 14, 2021 at 11:47 PM
    otis24
    Mark
    California
    Yeah, they’re not smog legal.
    I’ve read of people passing smog with them connected/hidden.
    Probably best bet would be to remove it like you said.
    Edit: what I’d like to know is if the smog obd2 connection will detect a piggyback ecu on a 1st gen. The stock ecu’s software isn’t modified at all. It’s just tricked.
  6. Jul 15, 2021 at 12:23 AM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    I’m going to guess “yes”. I do think the piggy back just reads and sets to match.
    The thing is, most manufacturers already know when the car is tuned. Even when you revert to stock, how many times the ECU has been flashed, what the checksum is for the current software is.
    No doubt CARB has learned all the tricks.
    otis24[QUOTED] likes this.
  7. Jul 15, 2021 at 12:29 AM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Removing or even just unplugging and going back to stock wiring on piggyback is enough. Don't do it day of test, You may have to wait and run back through the setup checks in ECU. I'd remove and hide any evidence of 7th. shouldn't take too long and not worth hassle of getting flagged.
    I got flagged for no sticker under hood 4 years ago for s/c and they ask me about it every time so its in the paperwork that you failed before and they look closer for anything shiny.
    On the ECU My understanding is there is a Tune ID that is added in at factory. Some ECU tuners copy over that ID so in theory the OBDII info isn't changed. I don't know if there is something more advanced added in last year but I doubt it. This regulation has always existed AFAIK not sure why it's news now.
  8. Jul 15, 2021 at 1:02 AM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    The legislation may have existed but they have only recently decided to enforce it.
    Everybody thinks of OBDII as some standard and to a degree, it is. Only a
    Small portion is accessible by your average reader. However, the manufacturers portion is far more complex and allows for a lot more features and information. For example, if Toyota connects, they can query portions of the ECU-the tuners have reverse engineered this to do their thing. There’s even diagnostic functions like Tech Stream uses. Except the piggy back stuff (unless it modifies the ECU).
    When the ECU is written by a third party, it’s possible tags are left around. It’s also possible the ECU can only be written x times. In the later case, what ever is left behind can be accessed. Software has checksums. Those can be checked. They could also run a diagnostic where the result is known (like moving an exhaust valve).
    I’m guessing there will be more than a few mistakes made where people are screwed.
    otis24 likes this.
  9. Jul 15, 2021 at 1:11 AM
    otis24
    Mark
    California
    Yeah, this sounds right. CARB has enough data collected they can probably pick out outliers.
    All the articles I’ve read today say as of
    July 19, 2021 smog will detect ecu flashes. That doesn’t mean they wouldn’t know before I suppose.
    The 1st gen 5vzfe ecu can’t be reflashed or tuned.
    No one has ever been able to crack it.
    Hence piggyback is the only option.
    I have 20 months until my next smog check anyway. The plan is remove the 7th well before then..like 1-2 months. My evap monitor takes forever to be ready. It’s not required for smog but I still want it ready.
    This past spring my evap monitor took around 2,000 miles to be ready.
    It passed smog with the evap not ready but I’d rather just have all the monitors ready for next time.
  10. Jul 15, 2021 at 7:03 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    When you say CHEAP what kinda prices we talking?
  11. Jul 15, 2021 at 7:06 AM
    FortuneFavorstheBruin
    FortuneFavorstheBruin Well-Known Member
    Zack
    Austin, Texas
    2018 Tacoma Off-Road
    In today’s environment? Depends on the round.
    Anything $0.33 and under for 7.62x39 I am buying.
    I have thousands of rounds of .223, so that’s not in my sights.
    Whatever 9 I can find, I usually just buy unless it’s absolutely outrageous.
  12. Jul 15, 2021 at 7:07 AM
    Dan8906
    Daniel
    Concord, California
    Are you running a piggyback? It’s one of the main reason I haven’t wanted to add a supercharger to my truck. CA takes all the fun out of it and I have no idea how to set up a 7th injector haha
  13. Jul 15, 2021 at 7:08 AM
    Dan8906
    Daniel
    Concord, California
    Gees any round under .33 is a steal these days hahah I went to buy some .22 and they wanted .20 a round and I just said nope
  14. Jul 15, 2021 at 7:08 AM
    otis24
    Mark
    California
    Yeah, I just installed it about 3 weeks ago too.
    I posted in the supercharger thread over in the 1st gen forum too.
    Edit: setting it up was pretty easy. It took a few hours but I would say it was easy.
    FirstTimeFirstGen likes this.
  15. Jul 15, 2021 at 7:46 AM
    Zack
    Austin, Texas
    The entire reason I went from being an AR guy to an AK guy was the cost of feeding it.
    Also I am way way way into old Soviet era stuff now. Bakelite is lyfe comrade
    Motofox likes this.
  16. Jul 15, 2021 at 7:56 AM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    I am heading to Medford this weekend... I might be able to stop by a store and see what they have in stock/how much it is if I have time.
    Blue Machine likes this.
  17. Jul 15, 2021 at 10:22 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    techfinsoup likes this.
  18. Jul 15, 2021 at 4:07 PM
    ebsoria
    ebsoria Well-Known Member
    Ville of the Rose, NorCal
    '18 D-Cab 4WD TRD Sport
    Anyone know if the meet at Denio's will have vendors selling stuff, aside from the giveaways?
  19. Jul 15, 2021 at 4:12 PM
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Mostly just bottle openers, beer coozies and stickers I'm sure.
    ebsoria[QUOTED] likes this.
  20. Jul 15, 2021 at 4:13 PM
    ebsoria
    Oh well, it was a hope. CHEERS!
    TOP TACO[QUOTED] likes this.
