Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Aug 9, 2021 at 8:45 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Scs key?
  2. Aug 9, 2021 at 8:47 PM
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    The lug key that specific to gorilla lugs. Its a 6 spline if I remember correctly.
  3. Aug 9, 2021 at 8:49 PM
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    8 spline
    90yota[QUOTED] likes this.
  4. Aug 9, 2021 at 9:01 PM
    Just_Tombo
    Just_Tombo Well-Known Member
    2003 prerunner TRD DC 3.4
    I bled them myself, and I'm pretty confident I did a solid bleed, but you think that's worth a look? I have years of experience bleeding, but I'm also human so anything is possible. Worth noting that I don't notice any change in performance or drag when the pulsing begins, and "pulsing" is not describing "shuddering", or pulsing in brake power; but an audible pulse only. Thanks
  5. Aug 9, 2021 at 9:04 PM
    Motofox
    Motofox Well known hermit
    Stephen
    Northern California
    2014 DCLB
    custom pin-striping and dirt
    You aint working at the livermore spot anymore i figure?
    I got a spare key because "one is none" but im not really north enough to conveniently hand it off to you
  6. Aug 9, 2021 at 9:32 PM
    CruisD64
    CruisD64 Well-Known Member
    Andrei
    Truckee, CA
    2003 Tacoma TRD 4x4
    Line-X, LED Gauges, Bluetooth Stereo, TracRac, OME 2.5 Lift, Relentless Fab rear bumper, Shrockworks front. Bleh. So much good stuff.
    Sounds like a warped rotor to me. Even though you said there is decent life it's possible the rotor overheated and warped.
    Just_Tombo[QUOTED] likes this.
  7. Aug 9, 2021 at 9:45 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Being a 2003, I'm pretty sure you have ABS. Early Toyota ABS does wierd shit. lol
    Also, being a 2003, I'm not sure if you are aware there is a brake proportioning valve up near the back end of the gas tank. That needs to be part of the bleed.
    Early ABS, with air in the line does really wierd stuff.
    Some say to bleed the proportioning valve before the rear brakes, some say after... working from farthest to closest the prop valve would go after the rear brakes... I bleed it first, then bleed it again between the rear and the front brakes.
    Don't misunderstand. I'm not saying you don't know how to bleed the brakes. Just wasn't sure if you did it or if you were relying on the word of the previous owner. And there are quite a few 1st Gen owners that are unaware the proportioning valve needs to be bled when bleeding the system.
    Also, this may not even be the source of your problem, but it's where I would start.
    Just_Tombo[QUOTED] and Motofox like this.
  8. Aug 9, 2021 at 10:14 PM
    Just_Tombo
    My last taco did not have the proportioning valve, so no, I did not bleed it! Good to know, and definitely worth a look, of I remember to do it, I'll follow up, thanks again.
  9. Aug 10, 2021 at 1:06 AM
    thebaker
    thebaker Well-Known Member
    Byron
    NorCal
    Upgraded to a 3rd gen
    Never ending......$$$
    If any of you have a 2gal rotopax mount laying around you don't need, hit me up, im looking for one. Also looking for an extension.
    Thx!!!!
  10. Aug 10, 2021 at 4:06 AM
    notlefty
    notlefty Probably Wrong
    Dixon
    2019 TRD Sport Access Cab M/T
    I've got one in Dixon ...let me know..
  11. Aug 10, 2021 at 5:23 AM
    Drtgrl
    Drtgrl Minus member
    Alana
    Foothills
    2015 MGM Tacoma DCLB
    BAMF sliders with kick up. BAMF all skids. Icons w/ CDC up front. Icon UCA's. All pro expos with 12” kings in rear. Wheelers superbumps. 285 stt pros on black 16" fj wheels. 1" Bora wheel spacers. Relentless tailgate reinforcement. Ditch lights front and rear. Aironboard switches. Aux. bussman box.Center console vault. Esp locking storage. Tuffy bed box. Rear seat molle system. Color matched grill.Rear diff breather mod. ABS switch. PrInSu cab rack. Gusseted spindles.
    Just based off sound I would be looking at your brake booster for a vacuum leak
  12. Aug 10, 2021 at 6:57 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Let me check the runner. They aint gorilla lugs but as long as the splines match we should be good. Im home all day today too
  13. Aug 10, 2021 at 6:57 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Also, why didnt i get lug nuts with my wheels? What the heck. Lol
    90yota likes this.
  14. Aug 10, 2021 at 7:31 AM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    i have a whole extra set of black gorilla lugs for yota if you needs.
    Motofox and Fernando[QUOTED] like this.
  15. Aug 10, 2021 at 7:46 AM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    If you can find a IR thermometer, drive the truck for a bit then measure the brake temperature. If the left is sticking or dragging, it will be hotter. It also help explain the poor brake performance.
    I would take it apart and inspect for correct assembly, lose bolts, pad thickness, etc.
    If that sound you are hearing sounds like grinding, it is probably worn pads.
    You mention bleeding. As others have said, the proportioning valve needs to be bleed and depending on how long it’s been, the ABS pump does as well. Usually, the pump is bled with a special tool that opens and closes the valves in the pump. You can damage the pump if you’re not careful. The poor man’s method is to go find a place you can activate the pump a few times by mashing the brakes hard enough to activate the ABS-that should push any air out into the brake line. Then bleed as normal. Don’t forget the proportioning valve and don’t forget order is important.
  16. Aug 10, 2021 at 7:53 AM
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    My gorilla key has 7 splines.
    GL
  17. Aug 10, 2021 at 8:20 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I might have to take you up on that. For the tank. I hate the chrome lugs
  18. Aug 10, 2021 at 8:28 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
  19. Aug 10, 2021 at 8:30 AM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    you should be a hand model pretty boy! HA!
  20. Aug 10, 2021 at 8:32 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    :luvya:
    :rofl::rofl:
    I did not see that one coming. Haha
    SACTOWN[QUOTED] likes this.
