Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Aug 25, 2021 at 8:02 PM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    Stay SAfe!!
  2. Aug 25, 2021 at 8:05 PM
    TOP TACO
    TOP TACO Well-Known Member
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Ya, I had quite a bit of weight with the shell and decked system fully loaded.
  3. Aug 25, 2021 at 8:06 PM
    CalTacoma09
    CalTacoma09 Well-Known Member
    Manteca, CA
    09 TRD Sport DCLB 4x4 Barcelona Red
    A lot of crap and too much money spent
    Yeah, I'm thinking maybe stage 2 for the rear if I go that route. I'm leaning more towards HD Dakar's
    roguegs and TOP TACO[QUOTED] like this.
  4. Aug 25, 2021 at 8:13 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Fires? How’s about a gas leak in San Jose. It’s around Race and Park. PG&E says midnight before you’re cooking with gas again.
    nDub likes this.
  5. Aug 25, 2021 at 8:15 PM
    Taco-Obsessed
    Towards the end my dakars started to flatten out, and squeeked for the years I had them. My deavers don't squeek. I like the multiple thinner leaves of deavers compared to the fewer thicker leaves of the dakars. Their not that much more money, and its worth it in my opinion. That said, I'm guessing you know all this and have run dakars as you have been at this a lot longer than I have.
    FirstTimeFirstGen and TOP TACO like this.
  6. Aug 25, 2021 at 8:20 PM
    CalTacoma09
    Manteca, CA
    This is the reason I'm asking around. I have only had the Dakar's but mine are the old version not the HD version. I have heard a lot of good things about deavers and wanted to ask the opinion of people that have a similar build to me. How is the ride with the deavers?
  7. Aug 25, 2021 at 8:28 PM
    Taco-Obsessed
    Plush. Never looking back. I read some article on the physics of using several skinnier leaves, compared to less thicker leaves, that really sold me on them and other higher end leaf packs from other companies. I'll see if I can find it.
    Dakars do the job, but I'm seeing more and more people ditch them for flattening out (plus going nuts from the squeeking) and wishing they would've paid a bit more from the get go.
    FirstTimeFirstGen and Motofox like this.
  8. Aug 25, 2021 at 8:31 PM
    CalTacoma09
    Manteca, CA
    Yeah, I think I'm going to get the stage two. Just going to bite the bullet.
  9. Aug 25, 2021 at 8:37 PM
    Taco-Obsessed
    There is also Alcan? There is another "a" company too that I always confuse it with, one is comparable to Deavers and other sucks (what I've read). I read a lot good things about them back when I was researching leaf packs.
    More recently I've seen good reviews of Icon RXT packs, but already had my Deavers so didn't look into them.
    nDub and CalTacoma09[QUOTED] like this.
  10. Aug 25, 2021 at 8:48 PM
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Stage 2 is probably about right for you. My vote is deaver over Dakar. I've had both.
  11. Aug 25, 2021 at 8:52 PM
    Taco-Obsessed
    @CalTacoma09 I can't find the in-depth article with all the figures, but here is copy and paste from a few articles on thinner leaves.
    Leaf springs with a multitude of thin leaves are more expensive to produce, but thinner leaves are more flexible than thicker ones and move more freely. This means a spring with multiple thin leaves can have more arch, but still produce a nice ride. Extra arch not only provides some lift, but it also yields more bump travel. And, lots of thin leaves stacked on top of each other makes the spring a lot more progressive. This allows it to absorb both smaller hits and larger ones for a much better ride and control in the dirt.
    What Are The Benefits Of Using Multiple Thinner Leaves Instead Of A Few Thick Leaves?
    Deaver: High leaf counts of thinner material using quality high-carbon rate steel allows you to utilize that thinner material without compromise of sag or fatigue. In the simplest of terms, take 10 pieces of notebook paper and see how they can flex and move compared to four pieces of cardboard. The staggered leaf lengths allow us to get a much more progressive spring rate that increases as each leaf is engaged. This allows a smoother cycling of the suspension that doesn’t get the bucking reaction or rebounding.
    comes down to this: try to bend a 1/2" thick leaf. its hard. it barely wants to bend. now you put it with 4-5 others that are even shorter, meaning much stiffer. and the bottom leafs of the spring hardly come in to play. it puts all of the strain on the first 1-2 leafs.
    with a 10 leaf pack: try to bend a leaf that is 1/5" thick. its real soft. it will move very easily. now put it with 9 other shorter leafs. it doesnt mind moving. and those bottom leafs actually come into play. they carry a lot of the load. it becomes progressive. another advantage is that instead of having leafs with as much as 8" between leafs (graduation), our way puts around 3 inches, meaning less chance of breakage, bending, and sagging.
  12. Aug 25, 2021 at 8:59 PM
    CalTacoma09
    Manteca, CA
    Not sure if I should say thanks since you guys talked me into spending more money. I think, I will be happier in the long run. I appreciate the info and the advice from people that have or had the product.
  13. Aug 25, 2021 at 9:18 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Blue Machine and ian408[QUOTED] like this.
  14. Aug 25, 2021 at 9:18 PM
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Cmon, it's really only a little bit more than you were already going to spend. You'll definitely be happier in the long run!
  15. Aug 25, 2021 at 9:21 PM
    nDub
    Lead Free Gasoline
    All pro? My ‘85 had a rear 10 leaf pack from all pro (circa 2006) they flexed like crazy. Terrible on holding weight though. I’m still a fan of the company but I don’t know their reputation anymore since trail gear bought them. I heard they kept the same leaf manufacture.
  16. Aug 25, 2021 at 9:29 PM
    Taco-Obsessed
    I think that was the other company I was confusing them with. Alcan is the good ones comparable to Deavers, and "all poo" as I see them referred to by others, is the not so good ones? Should say I've never had either, and this is just from my online reading.
  17. Aug 25, 2021 at 9:33 PM
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    Since we are on the topic of leaf packs. Anyone have experience with Icon RXT? I also hear a few people liking this setup for heavy loads.
  18. Aug 25, 2021 at 9:40 PM
    Taco-Obsessed
    @EatSleepTacos runs them and has had favorable reviews. I already had my deavers when I heard about them, but one thing I really like about them is you can remove or add leaves if you change the weight you're carrying, just like with dakars. I can't do that with Deavers. The difference between the U402 Stage 1 and Stage 2 is not 1-2 leaves that I can add or remove.
    EatSleepTacos and TOP TACO like this.
  19. Aug 25, 2021 at 10:45 PM
    CalTacoma09
    Manteca, CA
    the Dakar's HD are 650 to my door, deavers are going to be around 1200+ to my door.
  20. Aug 25, 2021 at 10:57 PM
    thebaker
    thebaker Well-Known Member
    Byron
    NorCal
    Upgraded to a 3rd gen
    Never ending......$$$
    Im running the stage 3 icon rxt leaf pack. Rides great but im going to upgrade to a heavier leaf pack since my truck is just getting heavier on a daily basis.
    BalutTaco, Toki and TOP TACO like this.
