Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Nov 1, 2022 at 9:33 AM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    I would think your glass bedsides would be the correct dimension only because they hang on the composite bed. If the utility rail were off by much, a different length "J" hook would be all you needed? The "C" clamps are usually large enough to accommodate the difference. The shell sits on the bed edge and I would be more concerned about the edge to edge and front to back measurements. As long as the rail is there, you should be fine as that's how the shell is secured to the bed.
    erok81[QUOTED] likes this.
  2. Nov 1, 2022 at 10:30 AM
    erok81
    erok81 Well-Known Member
    Imposter
    Yeah but there is the issue, we are just guessing. I have to build a platform for the shell to fit on since fiberglass won’t hold the shell and mine are way too wide for the shell to sit on.
    The bedsides flare up some in the middle (not a lot - less than an inch) so I know some of the height isn’t the same.
  3. Nov 1, 2022 at 10:40 AM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    On the outside, you'd want to be more concerned. For example, my SnugTop overlaps the bed rail by between a 1/4 and 1/2 inch.
    Good luck.
  4. Nov 1, 2022 at 10:52 AM
    erok81
    Imposter
    Yep. That’s designed into my platform thing.
    We’ll see how it goes. If my bedsides are much higher than stock I’m going to have to cut that outer lip off. :sawzall:
  5. Nov 1, 2022 at 11:20 AM
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    Yeah no problem, I'll grab those measurements for you later today.
  6. Nov 1, 2022 at 12:20 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Anybody know what’s falling from the sky?
  7. Nov 1, 2022 at 3:27 PM
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    Looks like there's going to be a Badlands version of the ProEagle jacks
  8. Nov 1, 2022 at 8:38 PM
    Desert Dog
    Desert Dog Well-Known Member
    Los Gatos
    2007 DCSB
    Work in progress
    I’ll be about and around in Santa Cruz on Friday and Saturday if you want to take more measurements. Mine is a 2022 Access cab with the 6’ bed for reference
  9. Nov 2, 2022 at 8:10 AM
    tacomarin
    Bay Area
    2018 DCLB TRD OR
    For real this evening... sorry!
  10. Nov 2, 2022 at 9:55 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Was just going to post something about this.
    Harbor Freight pretty much gives middle finger to Pro Eagle (good for them)
    I'll probably be buying one of these soon lol
    zerotimeouts and Drtgrl like this.
  11. Nov 2, 2022 at 2:51 PM
    erok81
    Imposter
    I might hit you up for it. There’s a chance I’ll be out town though. I’ll let you know.
    Haha. No problem. I’m not in a huge rush and you are doing the favor. So I’m good whenever. :)
    tacomarin[QUOTED] likes this.
  12. Nov 5, 2022 at 11:13 AM
    Toki
    Toki Don’t get killed by Theta.
    Jon
    San Jose, Ca
    2018 Tacoma 4x4
    Little bit of this and a little bit of that but stock af.
    nDub likes this.
  13. Nov 5, 2022 at 2:38 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Sounds like your cabin air fan. Pull the filter out and see if there’s a leaf in there or something. If your not sure how to do that, look in the owners manual for cabin air filter replacement.
  14. Nov 5, 2022 at 3:14 PM
    Desert Dog
    Los Gatos
    2007 DCSB
    Work in progress
    "or somthing" :eek:
    numerous postings about mice building nests on the cabin filter or sometimes chewing through it and taking a merry-go-round ride in the fan
    Silver02Taco and nDub[QUOTED] like this.
  15. Nov 5, 2022 at 3:28 PM
    nDub
    Lead Free Gasoline
    Yikes. Mine was super loud so I opened it up and found a handful of leaves. Cleaned them out and good to go.
  16. Nov 5, 2022 at 4:57 PM
    Toki
    Jon
    San Jose, Ca
    2018 Tacoma 4x4
    You were right! It was a bunch of leaves and debris. Good to go now, thank you
  17. Nov 5, 2022 at 9:50 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
  18. Nov 5, 2022 at 10:00 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Holy cow! At least the fragment or what ever hit his home will be worth something...
    MyWyfsRnnr likes this.
  19. Nov 6, 2022 at 9:04 AM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    I drilled a couple small holes and used zip ties and some stainless mesh (had some left over from gutters) to cover the gigantic hole under cowl that lets leaves in. So far so good.
    Toki[QUOTED] likes this.
  20. Nov 6, 2022 at 12:28 PM
    tacomarin
    Bay Area
    2018 DCLB TRD OR
    I kept finding myself with the truck but no tape measure. Here’s what I got for measurements, though the distance from the t-slot to the bed cap was a little tricky to know for sure since I have a shell mounted. I measured that in a couple locations and it appears to be 2 5/8” - 2 3/4”.
    For the width I got 57 1/4”. I took the measurements in front of the wheel wells.
    Sorry for the delay!
