Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Sep 19, 2023 at 6:13 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    The shop just sent me these pics.
    Flanges, perches, and truss = done ✔️
    CalPoppy, essjay, Fernando and 7 others like this.
  2. Sep 20, 2023 at 7:27 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Here's an odd question.
    Anyone have a 4th Gen 4 Runner that can take pictures of how the ebrake cables are running on the rear axle?
    My rear axle build will have 4th gen 4 Runner rear disc with ebrake. I'm trying to figure out what I need to do to run the cables across the axle.
    5th Gen 4 Runner may be the same, but I'm not sure. All of the brake parts I have are for 4th Gen.
  3. Sep 20, 2023 at 7:46 PM
    silvertep
    silvertep Well-Known Member
    Luke
    Sacramento, CA
    2018 4Runner TRD-Off Road
    The usual
    @SwagThor has a 4th gen, I can get some pics tomorrow of my 5th
  4. Sep 20, 2023 at 7:55 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I'm not sure 5th gen is the same. If @SwagThor could take some pictures of his rear axle I'd truely appreciate it.
    silvertep[QUOTED] likes this.
  5. Sep 20, 2023 at 9:46 PM
    techfinsoup
    techfinsoup Well-Known Member
    Sacramento
    1996 Tacoma 4x4
    Passing through your area on 99 Saturday. Can swing by if you want to take a look for yourself on my 4th Gen
    Dawdaw808 and silvertep like this.
  6. Sep 21, 2023 at 6:38 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    That would be even better!
    techfinsoup[QUOTED] likes this.
  7. Sep 21, 2023 at 8:39 AM
    HAVING FUN
    HAVING FUN Old Man
    Leonard
    Sacramento
    08 4runner
    they run down the frame and trailing arm to backing plate.
  8. Sep 21, 2023 at 9:05 AM
    techfinsoup
    Sacramento
    1996 Tacoma 4x4
    I’ll send you a text when I’m on 99 and near.
  9. Sep 21, 2023 at 9:28 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    :thumbsup:
  10. Sep 21, 2023 at 10:46 AM
    silvertep
    Luke
    Sacramento, CA
    The usual
    What's a trailing arm :rofl:
  11. Sep 23, 2023 at 9:57 AM
    HAVING FUN
    HAVING FUN Old Man
    Leonard
    Sacramento
    08 4runner
    If you don't know, you could have problems.
    silvertep[QUOTED] and nDub like this.
  12. Sep 23, 2023 at 1:47 PM
    silvertep
    Luke
    Sacramento, CA
    The usual
    If you wheel a runner you learn that it’s the second weak spot after IFS. @MyWyfsRnnr helped beef my up tho, both my arms were bent.
    MyWyfsRnnr and ssd_dan like this.
  13. Sep 24, 2023 at 12:03 AM
    smokey_yota
    smokey_yota #FNGFTMFL
    Travis
    Bakersfield
    99 tacoma
    Prinsu Roof Rack Trail Gear Front Bumper Raceline Wheels Toyo AT3 Tires Fiberwerx Fiberglass Fenders And +4" Bedsides HELLA HID Bumper/Ditch Lights Rago Fabrication Ditch Light Brackets Bilstien Front Suspension Energy Suspension Bushings/Sway Bar End Links
    Looking for some help or advice. 99 Tacoma. Stock headlights. Nothing fancy.
    passenger side headlight is SUPER dim when on. Like basically a running light. Driver side is fine though. New bulbs, no change. Cleaned connector. No change. Where do I look next?
  14. Sep 24, 2023 at 12:32 AM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Measure the voltage. Then measure resistance between the headlight ground and chassis. You could have a wire with corrosion or that’s been chewed by an animal.
    smokey_yota[QUOTED] likes this.
  15. Sep 24, 2023 at 1:33 AM
    techfinsoup
    Sacramento
    1996 Tacoma 4x4
    My apologies, I left so cal late and just got back into town. Figured it was too late to swing or message you. Poor time management on my part.
  16. Sep 25, 2023 at 12:27 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Could be the relay? Switch with the drivers side and see if the problem follows suit.
  17. Sep 25, 2023 at 10:13 AM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    This is another possibility. You might also hear it "howl" or see the headlight flicker.
  18. Oct 3, 2023 at 1:49 PM
    Yavin4
    Yavin4 Well-Known Member
    2023 Lunar rock DCLB OR Tacoma
    Hoping someone on here may have some trip insights. Hoping to head out to Lassen since it's an area we have never been before. Anyone have any spot or trail recommendations? We've taken tons of fire roads around the PNW but would say we are still newbies, and camp with dogs so national parks a a no go. I saw a decent amount (for cali) first come first serve camp spots around that area so worse case we can always crash there.
  19. Oct 3, 2023 at 1:52 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    We did a trip to Lassen last summer. Was a great route.
    Lassen National Forest Discovery Trail (Jul 2022) – ADVENTURETACO
  20. Oct 3, 2023 at 10:36 PM
    Yavin4
    Awesome trip summary BTW. We only have 1.5-2 days. Any part you recommend to hit? Really digging the radio satalites.
