Norcal Spotted and BS Thread
Discussion in 'Northern California' started by PreRunnerSeth, Sep 23, 2009.
  1. Jul 20, 2025 at 9:41 PM
    waldeeeeen
    waldeeeeen Well-Known Member
    Walden
    Mosquito CA
    01 Tacoma 4x4 SR5 TRD 5sp
    Yea i have an 01, fb marketplace guy has a 96 4R with Mc and booster.
    I have an issue where I swapped (and bench bled) the Mc, Tundra Calipers (oriented correctly) and bled the system multiple times. I know I missed the bpv but we ran a ton of fluid through, amd beforeni commit to a purchase, i need to bleed again. The issue is that with the motor off, pedal is firm and holds strong. With the motor on, pedal drops to the floor and there is no feel to it. Like beyond spongy. Old mc did it too but no nearly as noticeable, and i changed it because pedal that drops slowly=bad mc typically. Even with some air id expect the soft feel but a bit of resistance. If the mc was bad, it would drop slowly with the engine off. This is unsafe to drive. And im trying to figure out my options
  2. Jul 20, 2025 at 9:42 PM
    waldeeeeen
    Walden
    Mosquito CA
    Is there a benefit to the dual diaphragm? And any info on the bpv dial?
  3. Jul 20, 2025 at 9:50 PM
    02hilux
    Planet: EARTH
    IDK if it’s a coincidence but 2 guys I know personally did the TBU and hate it. Brake worst than the Tacoma. Yes, I know, the Tacoma brakes are smaller but somehow it brake better. I drove both and can confirm.
  4. Jul 20, 2025 at 9:51 PM
    02hilux
    Planet: EARTH
    A dual diaphragm will generate more force vs a single.
  5. Jul 20, 2025 at 9:56 PM
    02hilux
    Planet: EARTH
    If you don’t want to modify, you need to source a single. They typically go for 50-70 buck on marketplace. A dual from a 4R or pre00 Tacoma, you will need to modify the push rod and brake pedal setup to engage the push rod. Simple to do IMO but that depends on your skill level and comfort.
  6. Jul 21, 2025 at 6:51 AM
    waldeeeeen
    Walden
    Mosquito CA
    Is there a write Up on this? Im pretty handy but would like to know more
  7. Jul 21, 2025 at 7:06 AM
    waldeeeeen
    Walden
    Mosquito CA
    And idk, I didn't really have any issues with the tbu. I felt like I had a noticeable improvement on 33s and I can lock up the 35s. Idk whats wrong in my system right now but i need to figure something out... the only things left oe are the booster and wheel cylinders. Everything else has been touched.
  8. Jul 21, 2025 at 10:46 AM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Do the 1Gs have a proportioning valve? My pickup had one and the brakes were super goofy after upgrading the booster. I ended up pinching the return line from the rear with some vice grips and it definitely helped.
    I did something with the valve on my jeep too but I don’t recall right off the bat what I did. Need to look at it again. I think I bypassed it when I went to disk in the rear.
    Good luck!
  9. Jul 23, 2025 at 2:26 PM
    waldeeeeen
    Walden
    Mosquito CA
    Yea we have one. Its up on the driver side frame above the rear axle. Kind of a strange design but I know I need to bleed that too. I sourced a booster, and I should have it in a week or two so I'll get back eventually with more answers as to how this project of mine is going...
    nDub[QUOTED] likes this.
