Normal idle speed for 3RZ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by IFGD, Nov 16, 2017.
  1. Nov 16, 2017 at 3:03 PM
    IFGD
    IFGD [OP] Well-Known Member
    Ian
    Raleigh, NC
    2001 Regular Cab 2.7L
    For those of you with scanguage/ultragauges, what's your idle speed at a stop, in gear, at normal operating temps?
    My truck has started to idle a little rough. It'll drop down to about 630 at stoplights and that's where it starts to vibrate. If I gently raise the rpm to 690-700, the vibration goes away.
    Is there a way to adjust this?
  2. Nov 16, 2017 at 3:29 PM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    750 after she's warmed up. It may be a little higher if running a/c, headlights, etc..
    I run 740-750.
  3. Nov 16, 2017 at 3:44 PM
    Taco302
    Greenbow, Alabama
    Is it throwing a CEL? How is acceleration, sluggish? Difficulty starting? Could be a number of things like spark plugs, o2 sensor, maf, fuel pump, dirty air filter, dirty fuel filter, etc...
    I'd start cheap with some of that fuel injector cleaner stuff that you dump in the gas tank when you fill up and go from there. I hate throwing parts at it when not necessary.
  4. Nov 16, 2017 at 3:47 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    I had this problem when I swapped my motor in, Id clean the throttle body and MAF and see if that helps. I wanna say my idle hangs around 800 ill have to double check.
  5. Nov 16, 2017 at 4:54 PM
    Slickster
    Slickster greentaco
    2002 pre
    Check your throttle cable sometimes it disengages causing it to loose rpms.
  6. Nov 16, 2017 at 5:35 PM
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    There is no idle adjustment, but I would start at the sensor that controls the idle. The IAC on these trucks gets dirty and can hang or get stuck. The good thing is they are fairly easy to clean and only require a $5 gasket and some carb cleaner. This does require removing the throttle body, but this is where I would start.
  7. Nov 16, 2017 at 5:38 PM
    Glamisman
    Glamisman Well-Known Member
    In addition to all of the above I would check the air tube after the MAF for cracks leaks etc.
