Normal oil fill cap condensation?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Satchmo!, Jan 21, 2024.
  1. Jan 21, 2024 at 2:37 PM
    gdr
    gdr Well-Known Member
    Bill
    Temescal Valley, Ca.
    2016 Inferno Tacoma TRD OR 4x4
    I have it but it's a darker rust color.
    160k mile Socal truck. 90 miles a day daily driver. 10k oci and parked outside. I didn't even know i had it until I saw another thread about it. My guess is it's due to the long oil fill neck. Never had a car with one like that. What ever condensation or oil burn off collects in there.
    I'm not worried at all about.
  2. Jan 21, 2024 at 3:04 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It is not related to the oil change interval. It is moisture content in the air of the crank case.
    Seriously, don’t worry about it.
    Just keep doing what you’re doing.
    Monitoring and maintaining your truck. :thumbsup:
    33yrsoftoys and Tnc like this.
  3. Jan 21, 2024 at 3:07 PM
    Squirt
    Squirt Pepsi > Coke
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    Completely normal! These threads pop up every winter!
  4. Jan 21, 2024 at 4:59 PM
    MGMDesertTaco
    I do mine every 2500 -3k. :crapstorm:
    TwistedOmYoga and Squirt like this.
  5. Jan 22, 2024 at 7:40 AM
    gasganofj60
    gasganofj60 Well-Known Member
    87 FJ60 & 21 TRDOR
    Concensus seems to be that it's normal. I take it yall who experience this do a lot of short trips?
    I don't live in the cold but rather down south near the humid coast and have yet to see this. My old job had me doing 30 miles to and from work. Current jib has me just 7 miles each way. I reckon I'll have to keep an eye on it.
    On a similar note, where is the oil temp gauge probe located on 3rd gens?
    I have a scan gauge that now a permanent resident on my dash and while the water temp will hit 180-200 in half the drive, with these recent weeks colder Temps the engine oil temp will maybe hit 140 before i reach destination.
    I wonder if I'll start to see it.
    Those worried about a little condensate ever get paranoid about fuel dilution? Especially those who do 10k OCI?
  6. Jan 22, 2024 at 8:06 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Condensation is completely normal in an internal combustion engine. As the engine heat cycles it will draw in cool moist air and water is a by-product of combustion. Both contribute to condensation in the oil.
    Also, to add, an engine will heat cycle naturally even without running. As temperatures rise in the day and cool in the night, so does the engine and air in it. This heat cycling is sort of like breathing, hot air expands and pushes out, cool air contracts and breathes in drawing in moisture with it. This is way engines that sit need oil changes as much as engines that are driven.
    Also, a part of coolant is water, this will evaporate over time, especially when hot, reducing the level in the reservoir. ( the glycol evaporates too ). This is also completely normal.
    I would suggest base lining your coolant level and your oil level under the same conditions with over a couple weeks. So temperature and time since last run. If you notice a loss in coolant and gain in oil level then maybe you have an issue. Although you day your oil looks fine... and coolant and oil mixed in an engine is milky so I think you should be fine.
    TwistedOmYoga likes this.
  7. Jan 28, 2024 at 5:38 PM
    Satchmo!
    Satchmo! [OP] Well-Known Member
    2019 Tacoma TRD Off-Road
    Well, monitored all week long under same conditions after driving it. Coolant and oil level stayed the same, no rusty/contaminated oil in the cap or tube. Conclusion; Since I changed oil back in July and it is now January, had to of been condensation build up within that time frame. Going to keep on, keeping on. Thanks for the input guys.
    Speedfreak likes this.
  8. Jan 28, 2024 at 6:37 PM
    lavrishevo
    lavrishevo Well-Known Member
    2023 Trail Edition
    Lots of short trips? Change the oil every 6 months regardless of mileage. Short trips are the worst as it allows the oil to breakdown prematurely and become acidic. Water and fuel in your oil breakdown additives quickly. Oil is cheap, your engine is not.
  9. Jan 28, 2024 at 6:49 PM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    That ain't normal. Heck, my '97 Civic daily driver has never shown a spec of moisture under the oil filler cap, and it does mostly short trips.
    faawrenchbndr likes this.
