normal operating temperature
Discussion in '1st Gen. Tacomas (1995-2004)' started by dustinclm, Feb 27, 2011.
  1. Mar 2, 2011 at 3:23 PM
    tacopyro
    tacopyro Forever learning...
    SoCal
    01 Taco Pre SR5 V6 - 4WD
    Roll n Lock Cover and Stainless Step sides. New Mods. AFE Air Filter, PS Mag-Filter, Bilstein HD rear and 5100s Front. Michelins LTX MS2. Taurus E-Fan with FK50. Tundra Brake Upgrade. External Tranny Cooler. HO-Alt CS144 Mod, OMD Leaf Springs. Bull Bar. 4WD VF3AM Transfer Case, ADD/Manual Hubs. Supercharger with URD 7th injector. 4wd conversion complete Future Mods. rear sway bar, box the rear frame. I Love my Taco!
    Hi dustinclm,
    I have a 2000 Prerunner 2.7L. I also have a scanguage and i watched it for 2 years settling between 198 - 202F. even on winters. On real hot days even as high as 207F. The needle would be just at the exact middle or a hair below. Recently, my head gasket blew while coming off the fwy and i had the cylinder head inspected and valves adjusted at the same time.
    Since then, after replacing the fluid from green to red. (toyota long life?) My temps have been at 190 to 195F. I did replace my Thermostat too. After all that, I figure that once my temps get to 202F, its time to change the Thermostat and replace my Coolant so i can avert blown headgaskets.
    the one good thing is i gained 2mpg from this event...
    Hope that helps.
    CK
  2. Mar 2, 2011 at 3:44 PM
    dustinclm
    dustinclm [OP] Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    I just replaced a valve cover and changed radiator fluid and it's stil right in the same spot. I don't think it's running hot bc it's always been like this. Sooner it later I'll buy a scanguage and get an exact temp. Is ther any other way to get the temp?
  3. Mar 2, 2011 at 3:50 PM
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    It really depends on what temp of tstat you have in your rig... most common is 190-195 although I ran a 165 when I was in SoCal.
  4. Mar 2, 2011 at 3:58 PM
    ywen
    ywen Well-Known Member
    3400 w/ 97k.. its been 195 all winter..
  5. Mar 2, 2011 at 9:45 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I've not used one but I've read that an Ultra Gauge will also read the water temps (among other things). I think it is less expensive that the SG too.
  6. Mar 3, 2011 at 10:31 AM
    dustinclm
    Thibodaux, La
    thanks, ill look into it when i stop buying other things for my truck and rifle....damn mods are running me broke haha
  7. Mar 6, 2011 at 2:03 PM
    pt law
    pt law Well-Known Member
    Concord, NH
    04 xtracab 4x4 TRD
    Hey. So I took my truck to my local mechanic who has diagnostic equipment and he checked the coolant temp. I had driven it there to get it to running temperature and left it running while he checked the temp.
    This is what 190 looks like in my truck:
    Currygoat likes this.
  8. Oct 18, 2013 at 6:04 PM
    baggedcrewcoma
    baggedcrewcoma Well-Known Member
    bakersfield
    02 dc sc 5 lug
    I just got a electric fan that turns on at 185 would this be ok or do I need a diff thurmostat?
  9. Oct 18, 2013 at 6:36 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
  10. Oct 18, 2013 at 7:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    How do you know the fan turns on a 185*? Is that what is written in the documentation or is that the actual temp it turns on at?
    Do you have an ultragauge or a scangauge or are you using the dash gauge?
  11. Oct 18, 2013 at 8:42 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    The app for android phones and tablets called "torque pro". It cost $5 bucks, then go to Amazon and buy the Elm 327 bluetooth adabter for $25. For 30 bucks you have way more info then the SGII can give you. It plugs into your OBDII port and wirelessly send data to your phone or tablet.
    I have both, the SGII and the Torque app. I like Torque a little bit better. Torque is pretty damn good for only 30 bucks. They have a free version, but don't waste your time. Just buy the paid version.
    KO
  12. Oct 18, 2013 at 8:44 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    My ultra gauge shows that it usually stays around 192. The highest I've seen it is 198.
  13. Oct 18, 2013 at 9:20 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    Mine looks like the pic. I made a thread about this a couple years ago and the general consensus was that its normal. I think the issue is not the actual temperature, but a slightly inaccurate (and inconsistent amongst tacomas) needle.
  14. Oct 18, 2013 at 9:26 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The gauge apparently is just a three position indicator: cold, normal and hot.
    What Toyota should've done is replace the gauge with two idiot lights like Subaru did with the Impreza: blue light = cold, red light = hot, no light = normal.
  15. Oct 19, 2013 at 9:43 AM
    #35
    baggedcrewcoma
    bakersfield
    02 dc sc 5 lug
    Yea that's what is says on the package for the thurmostat I got w the electric fan.
  16. Oct 19, 2013 at 12:15 PM
    #36
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    I just switched my thermostat from the little valve thing from 12 o clock to 6 o clock. Went from 202 to 188 with scanguage....my guage looks like the pic also.
  17. Oct 19, 2013 at 11:39 PM
    #37
    Digiratus
    Roaming the PNW
    The RedHead
    If the fan does actually come on at 185, that would be OK as long as it isn't on all the time. It seems like you would want it to cycle.
  18. Oct 20, 2013 at 10:09 AM
    #38
    2k4Taco
    2k4Taco IG: Swannybruh
    Swanny
    Fleming Island, Fl
    16 DC TRD Offroad 4x4
    Icon 2.5s / 2.0's / //Dakar HD Pack//CBI T3 Front/ ATH HC Rear//SPC UCAs/ Camburg LCAs// MR312s w/ 34in Yoko GeoLndrs
    Slim, whats that A/T P and A/T Oil Temp indicators? I don't have those on my truck... Auto Transmission oil temp?
  19. Oct 20, 2013 at 10:15 AM
    #39
    Digiratus
    Roaming the PNW
    The RedHead
    That is an overheat warning lndicator for AT fluid temp. I have read it goes off a 250* and higher. :eek:
    The highesest I have ever seen mine get to is 235* on the SG.
  20. Oct 20, 2013 at 12:47 PM
    #40
    grovestreet
    grovestreet Well-Known Member
    it's 80~81C on my truck
    it's so steady that I set the ultragauge to send an alarm at 85C
    it's a 2004 2.4L
