Normal sounds?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brohan, Nov 10, 2015.
  1. Nov 10, 2015 at 3:34 PM
    Brohan
    Brohan [OP] New Member
    Brian
    15 Tacoma Prerunner
    I have a 2015 Taco 6 cylinder. I have a few noises, I wonder if they are normal.
    The 1st: When I have my system on defrost, at times it has a whistle to it. The intensity varies, sometimes barley there, other times its very noticeable. Toyota dealer says that is comparable to other Tacomas
    2nd: the engine makes a ticking sound, that I liken to an old school lifter or exhaust leak. Normal?
    Thank you.
  2. Nov 10, 2015 at 4:44 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    As Rock Lobster mentioned, the ticking sound is normal. Adding a supercharger helped cover it up.
  3. Nov 10, 2015 at 4:46 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Or just remove your muffler. Cheaper
  4. Nov 10, 2015 at 4:52 PM
    stombs
    stombs Well-Known Member
    Scott
    New Jersey
    2013 Tacoma V6 4x4 Access Cab TRD sport
    weather techs, westin grille guard, cb radio
    engine noise is normal and that whistling could be stuff in your cabin air filter which is i believe located behind the glove box
  5. Nov 10, 2015 at 4:56 PM
    JoeK
    JoeK Well-Known Member
    NC
    15 MGM TRD Sport DCLB
    The noise I've never understood is the noise when you turn the engine off. Always reminds me of a starter Bendix kinda noise...
    SCochran likes this.
