NORMAL, SPORT, ECO?
Discussion in '4th Gen. Tacomas (2024+)' started by Johnnybv, Sep 20, 2024.
  1. Oct 2, 2024 at 10:35 AM
    #61
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    It has to be. I'm sure the shift points changed too. I only ran it for five miles or so and decided it was too zippy.
  2. Oct 2, 2024 at 6:25 PM
    #62
    Chriswhaaaat
    Chriswhaaaat Well-Known Member
    Alberta, Canada
    2024 Tacoma Trailhunter, 2018 4runner, 1977 FJ45
    Haha.. man isn’t it an outstanding difference though? I’m not saying it’s too much, but I’m saying I’d be happy even if it had less. I only drove a gas job before buying the hybrid and I was satisfied that It was already good, I figured it was a safe bet… the hybrid drives really nice and yeah, all sorts of power.
    Hahaha… I also take off slow enough to piss off everyone if there are people around… thankfully it’s pretty quiet out this way. Your right, its not totally consistent, and I can’t quite put a finger on it yet. It seems like yeah, it ‘saves’ power for when it thinks it might need it… I wish (or wonder?) if it could be possible to add some sort of gyro inputs to the hybrid delivery calculation/decision, such that it knows when you are going up a hill vs on flat ground vs decline, to help decide when to use or not to use the motor.
    Gmtech is probably right, same amount of power just less responsive. And yeah, depending on how much juice you give, it may not even use the electric motor. I’ve been trying something lately where I take off slowly in electric only, and then once the engine insists on kicking on, I jam it such that I am utilizing the full torque from the electric motor, getting up closer to speed quickly. As soon as it suggests the electric motor is backing off (once the turbo has spooled), I back off on the throttle, and just slowly finish getting to the speed I need. I figure I’m utilizing more electric torque to get moving and minimizing the fuel used since this only lasts a couple seconds of extra fuel use (but also full electric contribution) whereas if I just accelerate slowly with the engine, it burns fuel the entire time with no contribution from the motor.
    gmtech likes this.
  3. Oct 2, 2024 at 6:37 PM
    #63
    TacoRancher
    TacoRancher Well-Known Member
    Houston
    2024 Trail Hunter, 2022 Lime PRO (RIP)
    lol.. our driving patterns are so similar .. and yes the power is glorious and I enjoy it every day!
    Chriswhaaaat[QUOTED] likes this.
  4. Oct 2, 2024 at 6:41 PM
    #64
    Chriswhaaaat
    Alberta, Canada
    Does it seem like the throttle pedal is more sensitive to you? (Rather… quite sensitive, not so much ‘more’) I travel a lot of bumpy roads and try to keep my foot quite steady, but the smallest of bumps can trigger ‘surging’ in the throttle demand, often kicking the engine on when on motor only. Seems like that threshold on the ‘MAX’ gauge is about 33-40%, maybe? But I find that if im at ~25% and get a little bump, even without passing the magic line, it might think I’m asking for too much and bumps on the engine
  5. Oct 2, 2024 at 6:51 PM
    #65
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    I agree. Tip in throttle too sensitive. My brain still hasn't made the adjustment.
  6. Oct 4, 2024 at 6:05 AM
    #66
    TacoRancher
    Houston
    IMG_5242.jpg Ok guys - I drove in a mix of normal and eco mode for 78.1 miles; truck reported 20MGP, which means I used 3.905 gallons in theory. I just filled up and it was almost dead on accurate at 3.939. See below. Will continue to accrue data.
    note: I think I reset the trip meter about 0.5 miles in, which would account for it being a tiny bit off, so in this run it seems super accurate - What I am noticing is that when I fuck around and spin wheels or drive over 80, it doesn’t quite register how much gas is being used and it gets less accurate. If I drive more normally it seems more accurate. But I’ll keep gathering data.
    Chriswhaaaat likes this.
  7. Oct 30, 2024 at 5:05 AM
    #67
    TacoRancher
    Houston
    Somehow I’m crushing it in eco. 265 miles with over 1/4 tank left. Will report final numbers but it will be impressive. Maybe because engine is broken in fully at 2,400 miles.
  8. Oct 31, 2024 at 5:29 AM
    #68
    TacoRancher
    Houston
    UPDATE: Eco plus 89 Octane gets you high mileage - 21.5 on a full tank
    JB_TN likes this.
  9. Oct 31, 2024 at 8:01 AM
    #69
    taco_mtb24
    taco_mtb24 Active Member
    2024 Bronze Oxide Tacoma TRD Offroad
    What the ready light for?
  10. Oct 31, 2024 at 8:12 AM
    #70
    TacoRancher
    Houston
    because hybrids can be silent when the engine is off, it just means the truck is on and ready to drive
  11. Nov 17, 2024 at 7:20 AM
    #71
    TacoRancher
    Houston
    So I switched to Falken AT4W E load 275/70/18s and my gas mileage shit the bed. About 17 it seems, but not enough data to confirm. But I am running 31 PSI because they are kinda hard tires. I may up the PSI to improve it.
  12. Nov 17, 2024 at 11:36 PM
    #72
    bctaco21
    bctaco21 Well-Known Member
    You feel the 89 gets you better mileage or it's just your standard fill?
    All this tank is giving me hybrid envy...
  13. Nov 18, 2024 at 5:00 AM
    #73
    TacoRancher
    Houston
    I’m not sure. I’m going to refill with regular today to test it. Also after putting bigger tires my mileage is definitely down. Need more data to report it reliably.
  14. Nov 20, 2024 at 3:37 PM
    #74
    thefinalstraw
    thefinalstraw Well-Known Member
    2024 Underground TRD Sport 4x4 Premium
    you think you lost over 4MPG from those tires? yikes.
  15. Nov 20, 2024 at 3:41 PM
    #75
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    That's about $375 a year more in fuel alone driving 12k miles/yr.
  16. Nov 20, 2024 at 3:41 PM
    #76
    TacoRancher
    Houston
    No definitely did not lose that much. I had some bad data. It’s much higher now. Will report out later.
    thefinalstraw[QUOTED] likes this.
  17. Nov 20, 2024 at 3:42 PM
    #77
    TacoRancher
    Houston
    Except it’s not that bad at all. My PSI was too low and I was driving up hills. It’s much better now. Will report later with good data.
  18. Nov 20, 2024 at 3:44 PM
    #78
    thefinalstraw
    phew! looking forward to some good data lol. im getting AT4Ws installed on Monday. though just in SL, so they should be significantly lighter than the E loads anyway.
  19. Nov 20, 2024 at 4:13 PM
    #79
    TacoRancher
    Houston
    SL? Come on you’ll be fine.
  20. Nov 20, 2024 at 5:02 PM
    #80
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    I’m using Sport mode the next few tanks full. Getting ready to hit 2000 miles. Liking it so far.
