North Carolina inspection with LCE header
Discussion in '1st Gen. Tacomas (1995-2004)' started by medikirk, Sep 23, 2014.
  1. Sep 23, 2014 at 9:18 AM
    medikirk
    medikirk [OP] Active Member
    Caleb
    North Carolina
    02 SR5 2.7l 4x4
    3" lift Deck Plate Mod Dynomax Super Turbo Muffler
    I was wondering if anyone is from NC on here and if you had the lce header with the 2.7l dual cat. it states that i will need to remove the front CAT to install them. Just curious what others have done about this problem.
  2. Sep 25, 2014 at 8:43 AM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    NC doesn't actually check emissions. They just use a scanner to check for any codes your truck is throwing relating to emissions. As long as you don't have a CEL, you won't have a problem.
    FWIW, I only have one cat on my '96 2.7, and it passes with no problems.
  3. Sep 25, 2014 at 9:59 AM
    medikirk
    Caleb
    North Carolina
    02 SR5 2.7l 4x4
    Great. Thanks for the help.
