North East CraigsList finds
Discussion in 'North East' started by Texoma, Oct 15, 2011.
  1. Jan 7, 2020 at 5:53 AM
    Rexfordian13
    Rexfordian13 Well-Known Member
    J
    Albany/NY Capital District
    2015 TRD Sport DCSB MT
  2. Jan 7, 2020 at 5:54 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
  3. Jan 7, 2020 at 5:56 AM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
  4. Jan 7, 2020 at 5:56 AM
    Armyhater458
    Armyhater458 Well-Known Member
    Clarion, PA
    2012 TX Pro
    OME 887, LR UCA, Dakar 095 (medium duty), Dick Cepek Extreme Country 255/85/16
    That is what I'm looking for, and for the savings over new i would drive that far. The issue is I don't have a rack or any way to mount to bring home. I am working on commissioning a build for one. Great work and appreciated. That trailer doesn't look that bad, and would be a good starter. It appeals that I could drop it and go wheel. I wish there was a better description of the tent.
    fatfurious2[QUOTED] likes this.
  5. Jan 7, 2020 at 5:58 AM
    Rexfordian13
    J
    Thanks Guys, appreciate it!
    RobP62 and Cativelense[QUOTED] like this.
  6. Jan 7, 2020 at 6:03 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    You can put the tent in the bed on some wood for transport. Then keep it stored until you get the rack built?
    or see if someone down that way can start a TW express
    RobP62 likes this.
  7. Jan 7, 2020 at 7:01 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
  8. Jan 7, 2020 at 7:10 AM
    Armyhater458
    Clarion, PA
    2012 TX Pro
    hmmmm, didn't think of that. I just assumed it wouldn't go between the wheel wells. I guess I'll have to see if i can find a thread with bed width dimensions. I can't measure at the moment.
    RobP62 likes this.
  9. Jan 7, 2020 at 7:12 AM
    fatfurious2
    David
    Ashburn, VA
    Or lean it on the side? Its gotta be able to fit without a rack
    RobP62 likes this.
  10. Jan 7, 2020 at 7:36 AM
    Armyhater458
    Clarion, PA
    2012 TX Pro
    wasn't sure if that would damage it traveling that distance with all the bumps. I'll get a trailer or something borrow bed bars, there has to be an option if it works out.
    JanBoothius and RobP62 like this.
  11. Jan 7, 2020 at 7:38 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    LivinLoud likes this.
  12. Jan 7, 2020 at 8:32 AM
    Armyhater458
    Clarion, PA
    2012 TX Pro
    Not going to lie, that was what I was thinking. I just don't have the cross bars on the rack. Something i wanted to add eventually anyhow.
    RobP62 likes this.
  13. Jan 7, 2020 at 8:42 AM
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    @jowybyo Are we still good with that DeWalt light?
    RobP62 likes this.
  14. Jan 7, 2020 at 8:48 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Yup.
    RobP62 likes this.
  15. Jan 7, 2020 at 8:52 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    https://www.tacomaworld.com/threads/2nd-gen-to-3rd-gen-bed-dimensions.586910/#post-19578337
    Dimensions are below in the quote Mike.
    Bastek and Armyhater458[QUOTED] like this.
  16. Jan 7, 2020 at 10:51 AM
    Armyhater458
    Clarion, PA
    2012 TX Pro
    There is 56.7" at c channel, and the tent is 56". It would/should fit above wheel wells correct?
    Bastek, Redmann and RobP62 like this.
  17. Jan 7, 2020 at 11:07 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Here's a great diagram for the 3rd Gen. Not sure if we can find this for the 2nd Gen but if most of everything else is the same we should be able to figure it out.
    Sand Dog and SR-71A like this.
  18. Jan 7, 2020 at 11:10 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    But to answer your question Mike, Yes, if the space is 3/4" of an inch wider than the tent, it will sit right on top of the wheel wells. It will be snug, but that's a good thing. You should be able to drop in some lumber in the slots in your bed sides to help support it as well.
  19. Jan 7, 2020 at 11:11 AM
    Armyhater458
    Clarion, PA
    2012 TX Pro
    Man did someone do everyone with a 3rd gen a solid. Everything you need to know in one diagram. Pretty sure the width and everything are the same, it was more of a height difference between the gens, but who knows.
    RobP62[QUOTED] likes this.
  20. Jan 7, 2020 at 11:15 AM
    Armyhater458
    Clarion, PA
    2012 TX Pro
    no slots, but could build a wooden platform support cheap and easy enough. Now to see if i get a response. I have zero faith in CL, and facebook marketplace has yet to produce for me. Pretty much my entire build is left over TW members stuff. I've never been burnt that way and prices are always reasonable.
    RobP62[QUOTED] and fatfurious2 like this.
