North East Skiing Thread!!
Discussion in 'North East' started by teneighty, Nov 24, 2013.
  1. Mar 27, 2015 at 5:43 AM
    #321
    BRUIN8124
    BRUIN8124 Well-Known Member
    Mark
    2020 TRD 4X4 OFF ROAD DCSB
    You should give it another go. That place has come a long way!
  2. Mar 27, 2015 at 6:41 AM
    #322
    rattlewagon
    rattlewagon Well-Known Member
    Caleb
    Northfield, Vermont
    92 pickup fun machine
    cut grind weld
    Pond skimming time of the year is coming!
  3. Apr 6, 2015 at 6:07 AM
    #323
    murderedtaco23
    murderedtaco23 Well-Known Member
    Jesse
    Campton NH
    09 dbl cab trd sport
    OME 3 inch lift all the way around, 285 75 16s, fog light any time, HID, Rock sliders, 30 inch bumbper LED, LED pod ditch lights
    Well was at killington this weekend, was nothing to right home about, kind of expected it with the insane weather there friday night. Think I am going to get on the bike before things get ugly on the mountains this year
  4. Apr 6, 2015 at 7:46 AM
    #324
    teneighty
    teneighty [OP] I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    That sucks man, I can imagine with this warm to cold crap it's petty crappy.
    I hope to be able to ski maybe in May, really bummed I missed the season :pout:
    Crazy about the west and lack of snow :eek:
  5. Apr 6, 2015 at 4:31 PM
    #325
    Rsoxfan1
    Rsoxfan1 Well-Known Member
    Mass
    2012 DCSB TRD Sport 4x4
    I wanted to go 1 more time this year but I can't seem to muster up the motivation...
  6. May 3, 2015 at 3:01 AM
    #326
    bubagump74
    bubagump74 SkiFreak
    Fred
    Montreal,Quebec
    2013 Trd OR
    NSA Pnl,US OFF ROAD winch mount bumper,Sirrius pods,Clazzio covers,Wheathertech mats, Pro Comp wheels,Image dynamics audio,leer cover,lights,bed mat,anti dark light...
  7. May 3, 2015 at 3:10 AM
    #327
    DrFunker
    DrFunker Well-Known Member
    until next season......
  8. Jun 5, 2015 at 2:42 AM
    #328
    DrFunker
    It's never to early to think about sliding on the snow. :D
    Will be working on a storage system for my gear, now that I have a shell on.
    Thinking some sort of tube storage for skis and poles that will serve as a muti-functional purpose for the off-season too.
    Got a Reese conduit carrier plug set for a 6" ABS/PVC pipe. Going to try that out.
  9. Jun 5, 2015 at 4:46 PM
    #329
    Edgeplay
    Edgeplay Well-Known Member
    Sean
    Connecticut
    13 DCLB MGM
    -Leather Seats -Weathertechs -LED map and dome -6K HID head lights, -Glove and Center Consol organizer -30" LED bar in lower valence
    You think bindings and all will fit into 6" pvc pipe? Would think bigger. Also you just going to put a screw top with a lock and then drill holes on the bottom for water to run out?
  10. Jun 5, 2015 at 4:50 PM
    #330
    DrFunker
    6" is the biggest (from what I could find) that I can go with a locking mechanism.
    The skis going in will have 3 pins or bc/xc. I think it will work with them. Won't be able to get the splitboard in there. But that's okay. That will fit easily in the bed.
    Yeah, thought about the water issue too. Was thinking small drain holes.
  11. Jun 5, 2015 at 5:07 PM
    #331
    Edgeplay
    Sean
    Connecticut
    13 DCLB MGM
    Gotcha. Didn't know how big you could go with PVC with locking mechanism. I would just put the tube on a slight angle and put holes at the bottom so it can run out. Maybe a hole in the middle also just to make sure.
  12. Jun 5, 2015 at 5:07 PM
    #332
    DrFunker
    Good idea. :thumbsup: Thanks.
  13. Jun 5, 2015 at 5:09 PM
    #333
    Edgeplay
    Sean
    Connecticut
    13 DCLB MGM
    Was thinking of doing this and trying to mount to the rails but never got around to do it or even look into it.
  14. Jun 5, 2015 at 5:09 PM
    #334
    DrFunker
    When I get it done I will post up what I did.
  15. Jun 5, 2015 at 5:10 PM
    #335
    Edgeplay
    Sean
    Connecticut
    13 DCLB MGM
    Looking forward to it. Good luck.
  16. Jun 5, 2015 at 5:12 PM
    #336
    DrFunker
    Thanks. Have to wait for the pipe to come from a distribution center. Wanted to work on it tonight. Oh well...
  17. Jun 14, 2015 at 3:21 AM
    #337
    DrFunker
    Roof Rack Ski Carrier Tube (conduit carrier).
    Reasoning - to keep as much (wet) stuff out of the bed as possible and free up room for sleeping..
    * The evolution for this project grew out of seeing Crom's idea for his tent pole carrier.
    Items:
    - 6" Reese conduit carrier from Amazon:
    http://www.amazon.com/Reese-7054900-TransRack-Conduit-Carrier/dp/B00B2HP1A4
    Comes with the brackets that I needed too.
    - 6" diameter ABS pipe. Got this from my local plumbing supply place.
    http://www.usqualitysupplyinc.com/wp-content/uploads/2012/09/pipe-3.jpg
    Cut the pipe to about 5'7". I chose this length due to it being the length of the longest item going in there (skis).
    Plasti-dipped the u-bolt brackets, which would give a bit more grip and match the pipe.
    Then sprayed a coat of black satin Fusion "rattle can" on the pipe mainly to hide the lettering.
    Once dried, the caps would go on each end. Instead of using the provided wood screws, I opted for pop rivets for the added security benefit.
    To keep the caps in place on the pipe while being drilled, I used a very strong double-sided sticky tape that was thin enough for the space between the cap and the pipe.
    Drilled the holes, popped the rivets and time for the placement on the racks.:thumbsup:
    * To keep it better in place, I did added worm clamps to it with a bit of rubber drawer liner wrapped around the Yakima bars. Probably overkill, but piece of mind.
    Pipe came in beginning of last week and I chipped away at this mini-project through the week (can you say "3 y.o. boy"? :))
    I didn't take any pics of the process, sorry. Once I get going on something I like to keep momentum.
    Kinda like floating through those deep sections of powder on a flat section. You know what I'm talkin' about. :D
    Thanks for reading.
    DrF
    Crom likes this.
  18. Jun 14, 2015 at 1:33 PM
    #338
    bubagump74
    bubagump74 SkiFreak
    Fred
    Montreal,Quebec
    2013 Trd OR
    Nice !:thumbsup:
    how many pairs of fat twins can you put in there
  19. Jun 14, 2015 at 2:03 PM
    #339
    DrFunker
    I can fit a pair of Alpina BC 3-pins in there. :thumbsup:
    oh...and poles.
    I will get a pic of the "stash" in there, when I get a chance.
  20. Sep 3, 2015 at 11:31 AM
    #340
    bubagump74
    bubagump74 SkiFreak
    Fred
    Montreal,Quebec
    2013 Trd OR
