North Phoenix Mod Day!
Discussion in 'Arizona' started by llibrm, Aug 5, 2015.
  1. Sep 13, 2015 at 11:25 AM
    #41
    llibrm
    llibrm [OP] OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    That's not bad. I've had a buddy take his to AZ axle and they booted his with his parts for that.
  2. Sep 14, 2015 at 10:03 AM
    #42
    llibrm
    Bill
    PM sent out during my class break today. If anyone has questions, just holler at me :cheers:
    The Fluffer and snowtank like this.
  3. Sep 14, 2015 at 10:10 AM
    #43
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    Did you get the fully assembled front coil overs or are we putting them together?
  4. Sep 14, 2015 at 10:14 AM
    #44
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    Send me the addy... if my truck is here... I'll be there!
    snowtank likes this.
  5. Sep 14, 2015 at 10:18 AM
    #45
    llibrm
    Bill
    Theyre suppose to be direct bolt in. The box is huge. Ill look tonight and double check
    TaylorU likes this.
  6. Sep 14, 2015 at 10:20 AM
    #46
    llibrm
    Bill
    added to the list. Let me know if you didnt get the message
  7. Sep 14, 2015 at 10:25 AM
    #47
    snowtank
    Andrew
    Arizona
    Ok sweet. That will make life allot easier. Are they set for a lift or are we leaving It stock height just better ride?
  8. Sep 14, 2015 at 10:26 AM
    #48
    llibrm
    Bill
    that Im not sure off. I told DSM what I wanted and what I was doing... So I'm not sure just how much settle there will be from the initial setup.
  9. Sep 14, 2015 at 10:34 AM
    #49
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    they will be assembled, and set to the standard. you'll definitely be adjusting them. you can compare to mine when I get there to get a rough idea of how much you want to crank them.
  10. Sep 14, 2015 at 11:24 AM
    #50
    Rextinkleton93
    Rextinkleton93 Well-Known Member
    Kyle
    Phoenix, AZ
    2018 Superwhite Tundra Crewmax 4x4
    Want to pm me your address and times? May stop by and say what's up
  11. Sep 14, 2015 at 12:36 PM
    #51
    llibrm
    Bill
    Just opened the box and they're fully assembled. The preload is backed off the whole way
  12. Sep 14, 2015 at 12:38 PM
    #52
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    Looks like I'm going to have Saturday off
    So as long as my shifter gets back in time I'll be there!
    The Fluffer likes this.
  13. Sep 14, 2015 at 12:38 PM
    #53
    llibrm
    Bill
    Done
  14. Sep 14, 2015 at 12:41 PM
    #54
    The Fluffer
    The Fluffer Keepin dick's hard and pussie's wet since 1990
    Andrew
    Scottsdale, AZ
    07 SWB X-runner /// 01 Jade Mica Tundra
    boughten
    Wooooo! That's badass
    llibrm[OP] likes this.
  15. Sep 14, 2015 at 12:42 PM
    #55
    llibrm
    Bill
    Sweet.
    Its starting to look like much modding will be happening
  16. Sep 14, 2015 at 12:42 PM
    #56
    StOrMyThEtAcO
    Cody
    CO
    All of them
    I'm stoked
    I'm thinking I'll come even if the shifter isn't there just to bs
    snowtank and The Fluffer[QUOTED] like this.
  17. Sep 14, 2015 at 12:43 PM
    #57
    snowtank
    Andrew
    Arizona
    Ok cool. The preload Is easy to do with a spring compressor. I have the spanner wrenches in my truck. And the compressor we can rent from autozone
  18. Sep 14, 2015 at 12:44 PM
    #58
    The Fluffer
    Andrew
    Scottsdale, AZ
    boughten
    Lost a bushing when I did mine so I kinda have to take it all apart and put it in lol so at least we can go over how to do it if anything.
  19. Sep 14, 2015 at 12:45 PM
    #59
    The Fluffer
    Andrew
    Scottsdale, AZ
    boughten
    I have spring compressors!
    snowtank[QUOTED] likes this.
  20. Sep 14, 2015 at 12:45 PM
    #60
    llibrm
    Bill
    SWEET!
