NORTH TEXAS MISFIT TACOS: BBNP trip April 6-9 2017
Discussion in 'Texas' started by Zac of all trades, Feb 20, 2017.
All I want to know is... who is coming with me???
  1. I will!
    25.8%
  2. Nope!
    6.5%
  3. just here to check it out
    67.7%
  1. Mar 14, 2017 at 4:48 PM
    #361
    ETXTacoma
    ETXTacoma Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
    I have foil in the kitchen box always. Will be sure to double check it though.
    Usually keep quarters in my truck but will double check it as well.
  2. Mar 15, 2017 at 8:55 AM
    #362
    Zac of all trades
    Zac of all trades [OP] FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    Hahaha. Man that was back in 2007 when i was still skinny and in the military. Also the beard makes a huge difference!
    I have a tarp that i will be bringing along with some 550 cord. So we can use it for shade or a wind block, what ever the situation calls for.
  3. Mar 15, 2017 at 8:57 AM
    #363
    ETXTacoma
    Steven
    Tyler, Texas
    Ha. Still going to call you Mr. Cuddles though...
    That reminds me that I need to build my Luminoodle line to hang it between trucks or something...
  4. Mar 15, 2017 at 9:14 AM
    #364
    Zac of all trades
    Zac
    fwpfab.com
    buy some 550 cord from walmart, something that will wrap around your luminoodle and clip to the string...
    I am thinking about running a 12v outlet to the rear of my truck, put it on a switch and be able to charge stuff in the back of the truck. Would also make getting power into the tent much easier also.
  5. Mar 15, 2017 at 9:16 AM
    #365
    thedrewsifer
    thedrewsifer Sorta Kinda Known Member
    Drew
    Republic of Texas
    2016 TRD Sport 4x4 Barcelona Red Overland Bound
    Way to much...but not enough.
    Pretty sure i have a long (20ft?) 12v cord you can have if you want. Or just pick up a portable batter pack to run the light in the tent and charge phones etc.
  6. Mar 15, 2017 at 9:21 AM
    #366
    Zac of all trades
    Zac
    fwpfab.com
    Yeah i guess i could do that but i am going to need at least a 50kmAh battery... I will see what Amazon and ebay have to offer!
  7. Mar 15, 2017 at 9:23 AM
    #367
    ETXTacoma
    Steven
    Tyler, Texas
    I have a ton of 550 cord at the house.
    Yep, will be installing a Blue Sea Systems 12v outlet in the back of the truck in the coming weeks as well as a always on dual USB plug inside the truck. Just have to run the wiring for it. Will be able to run the Luminoodle and charge phones and so forth.
  8. Mar 15, 2017 at 9:23 AM
    #368
    thedrewsifer
    Drew
    Republic of Texas
    Wait you should have a long 12v cord also if you got the smittybilt tent, its in the bag with your light.
  9. Mar 15, 2017 at 9:49 AM
    #369
    Zac of all trades
    Zac
    fwpfab.com
    Should be pretty easy, in case you dont already know, below your front seats, there is a rubber grommet that you can feed wires through to the back of your truck. I ran my power wires through the engine firewall, down my door stills, under the carpet, through the hole, down the frame, to the rear.
    I saw a bag full of stuff but i wasnt going to mess with it till i get the tent mounted. I guess i will have to mess with it now...
  10. Mar 15, 2017 at 9:59 AM
    #370
    ETXTacoma
    Steven
    Tyler, Texas
    Yea, that is what I heard, was planning on using that grommet. Just not sure what gauge wire to run back there.
  11. Mar 15, 2017 at 10:30 AM
    #371
    Zac of all trades
    Zac
    fwpfab.com
    Honestly you would be fine running some 16 gauge speaker wire back there! Haha. I would recommend that you get real power wire though as it has better heat shielding! And 16 gauge should be plenty thick for a 12v plug.
    I bet that if you were to look at the wires behind your factory 12v plug you would see 18 or 20 gauge wire.
  12. Mar 15, 2017 at 10:36 AM
    #372
    ETXTacoma
    Steven
    Tyler, Texas
    Heck, I was going to do either 12 or 14 gauge wire as I was thinking about getting a small fuse block and have some other things ran off that wire.
    Went ahead and ordered a National Luna Single Battery Monitor to hook up as well. Don't want to drain the battery somehow.
  13. Mar 15, 2017 at 11:28 AM
    #373
    Zac of all trades
    Zac
    fwpfab.com
    You could get a bussmann and run the wire off one of the constant power terminals to the rear of the truck that would have a bluesea block installed! but it would have to be very small and draw low power, depending on the size of the fuse you are running on the Bussmann. Maybe run a few small 12v items, luminoodle, phone charger, 12v water pump...
  14. Mar 15, 2017 at 12:09 PM
    #374
    ETXTacoma
    Steven
    Tyler, Texas
    Yea, it would only be small 12V stuff, mainly LEDs and such.
    I just need to order the bluesea block so I can do it all at once instead of in stages.
    I also got a $50.00 coupon for Mobtown Offroad, so trying to decide which locking bed thing I want to get...
  15. Mar 15, 2017 at 8:31 PM
    #375
    ETXTacoma
    Steven
    Tyler, Texas
    Did a test run of the Cheese steaks tonight. 2 Ribeye and a big piece of just flank steak was enough to make 6 pretty good size cheese steaks.
    I need to cut the meat a lot thinner and will have to cook the meat with the onions after the onions have gotten nice and caramelized to really get the best outcome though. Also need better bread that is not fully sliced in half and two slices of provolone cheese per cheese steak.
  16. Mar 16, 2017 at 10:55 AM
    #376
    Zac of all trades
    Zac
    fwpfab.com
    Shit looks BOMB!!!!
    ETXTacoma[QUOTED] likes this.
  17. Mar 16, 2017 at 11:26 AM
    #377
    ETXTacoma
    Steven
    Tyler, Texas
    It was! Just need to figure out how much I need to buy to be able to feed everyone!
  18. Mar 16, 2017 at 12:11 PM
    #378
    Zac of all trades
    Zac
    fwpfab.com
    I think the head count is 11 right now. I know my GF doesnt eat much so i can eat what she doesnt.
  19. Mar 16, 2017 at 7:57 PM
    #379
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Just got back from BBNP and we had a blast hope you guys and gals do to. Little taste for y'all.
    Oh and make sure you get to the permit office early if you want to road side camp. The rangers said that they are have a record year.
  20. Mar 17, 2017 at 7:44 AM
    #380
    Zac of all trades
    Zac
    fwpfab.com
    Thanks man! What time did you get there? Its about 5.5 hrs from San Antonio so if i leave at 5am i can be there Thursday by around 11am.
    @thedrewsifer haha you changed your profile picture...
    Hey man, Red is saying that they are having a lot of people this year. Did you say you were getting there Wednesday night?
