Northeast TW Express Thread!
Discussion in 'North East' started by Nimble9, Nov 22, 2016.
  1. Apr 23, 2020 at 3:53 PM
    #6281
    pmstoy10
    pmstoy10 Well-Known Member
    hudson valley, ny
    2010 Tacoma DCLB TRD Sport
    Weathertech Floor Liners, UWS Toolbox, Seatbelt Chime Mod, Coverking Covers, Window Guards, Wheeler's 1.5" Single Leaf AAL, Rear Spring TSB, Front Bilstein 5100's @ 2.5", Rear Extended Travel Bilstein 5100's, removed front mud flaps, Lifetime LED Headlights, Firestone RideRite Air Bags with Daystar Cradles, Light Racing UCA's, ECGS Front Diff Bushing
    That's way out east by Boston/RI. Almost 4 hours away from me depending on his route. However there could be done possible handoffs through @Cativelense?
    Cativelense likes this.
  2. Apr 23, 2020 at 3:53 PM
    #6282
    FIRE74
    FIRE74 Well-Known Member
    Corey
    St.Leonard, MD
    2012 DCSB
    I’ll be leaving St. Leonard and traveling north on 4/2, then 301 to Delaware, 95 Jersey turnpike, and 93
  3. Apr 23, 2020 at 5:06 PM
    #6283
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    You rang???????!!!!!!!!!!??????????!!!!!!!!!!!
    LOL
    RobP62 and pmstoy10[QUOTED] like this.
  4. Apr 23, 2020 at 5:34 PM
    #6284
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Well, we're scratching our heads right now but @pmstoy10 has a shorty exhaust (from the flange to before the axle on a SB) he's holding for me, and some recovery gear for @fatfurious2 (not sure what exactly) and a Maryland member is hauling a boat to Mass next Tuesday morning. Thing is, he's taking the coastal route way east of @pmstoy10 up I-95. So we thought maybe if you could help out either on the way up or the way back it would be awesome.
    Cativelense[QUOTED] likes this.
  5. Apr 23, 2020 at 5:40 PM
    #6285
    Cativelense
    Nuno
    CT
    I'm on 84, but 95 isn't too far down from me... 95 runs through Stamford CT and Norwalk CT, and I'm sure there are some commuter parking lots or rest stops around that area that could serve as a meet up spot, and still abide by the social distancing guidelines.
    pmstoy10 and RobP62[QUOTED] like this.
  6. Apr 23, 2020 at 5:40 PM
    #6286
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    traction boards, snatch block, and a tow strap/tree saver (which I am going to sell)
  7. Apr 23, 2020 at 5:41 PM
    #6287
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Selling all of it?
  8. Apr 23, 2020 at 5:42 PM
    #6288
    fatfurious2
    David
    Ashburn, VA
  9. Apr 23, 2020 at 5:46 PM
    #6289
    pmstoy10
    hudson valley, ny
    I'm Poughkeepsie/Newburgh area so relatively near 84 and can run out your way to make the hand off. Just need to figure out timelines
  10. Apr 23, 2020 at 5:48 PM
    #6290
    pmstoy10
    hudson valley, ny
  11. Apr 23, 2020 at 5:49 PM
    #6291
    fatfurious2
    David
    Ashburn, VA
    also, sorry for the delay, but thank you so much for floating me the doll hairs. I will compensate you on the 8th if thats ok?
  12. Apr 23, 2020 at 5:50 PM
    #6292
    Cativelense
    Nuno
    CT
    So you have something that you would hand off to me, and then I would hand off to someone else?
    RobP62 likes this.
  13. Apr 23, 2020 at 5:51 PM
    #6293
    pmstoy10
    hudson valley, ny
    Pretty sure you're good for it.
    Otherwise I'll just have to send @RobP62 after you
  14. Apr 23, 2020 at 5:52 PM
    #6294
    pmstoy10
    hudson valley, ny
    Yup. All the stuff @RobP62 And @fatfurious2 mentioned above
  15. Apr 23, 2020 at 5:52 PM
    #6295
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Very interesting. Let's see..............
    @FIRE74 Corey, are you coming back the same way? @Cativelense aka Nuno could possibly snag the items from @pmstoy10 and meet up.
    Then you and I could meet at Cabela's at the Christiana Mall, then you could head south down 1 to 301?
    FIRE74 and Cativelense[QUOTED] like this.
  16. Apr 23, 2020 at 5:53 PM
    #6296
    Cativelense
    Nuno
    CT
    Cool. Just making sure that I didn't miss anything.
    I'm working from home until TBD, so anytime you can or want to swing by is fine with me. My schedule is wide open. LOL
    RobP62 and fatfurious2 like this.
  17. Apr 23, 2020 at 5:55 PM
    #6297
    fatfurious2
    David
    Ashburn, VA
    I believe its an exhaust, pair of traction boards, and a snatch block
    RobP62 and Cativelense[QUOTED] like this.
  18. Apr 23, 2020 at 5:58 PM
    #6298
    Cativelense
    Nuno
    CT
    Cool. Should all fit in my SB then with the cap.
    RobP62 and fatfurious2[QUOTED] like this.
  19. Apr 23, 2020 at 5:59 PM
    #6299
    pmstoy10
    hudson valley, ny
    Pretty much me too, although I'm home schooling while working, so....
    Anyway - PM inbound
  20. Apr 23, 2020 at 6:01 PM
    #6300
    Cativelense
    Nuno
    CT
    I lucked out with that. My oldest is in K, and the Mrs is a K teacher, so she's handling all of that, between him and her Google Classroom for her kids.
    Fun times...
    RobP62, pmstoy10[QUOTED] and Bastek like this.
