Northern Colorado
Discussion in 'Colorado' started by odomandr, Aug 10, 2019.
  1. Apr 13, 2021 at 10:33 AM
    #441
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    This company was good. Not sure if they go as far as FoCo, but worth checking:
    https://precisionautoglass.biz/
    alee891[QUOTED] likes this.
  2. Apr 13, 2021 at 12:01 PM
    #442
    Wackyhacky
    Wackyhacky A Well Known Troublemaker
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    I used Gerber Collision & Glass, which is all over the place up here. Got an online quote from their website, but the actual company that showed up (they did it in my driveway) and invoice was from a company called Glass America. Cost me $265 on my 2nd Gen Tacoma, and zero issues since installed in August.
  3. Apr 13, 2021 at 12:08 PM
    #443
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    That's a number I can get onboard with! Safelite has quoted me nearly $400. It's going on a 1st gen Tundra, but it isn't ~$145 more in glass.
  4. Apr 13, 2021 at 4:24 PM
    #444
    RecklessTLS
    RecklessTLS Well-Known Member
    Rowdy
    Ft Collins, Colorado / Texas Native
    2009 Tacoma DCSB TRD Offroad 4.0
    TRD CAI and Exhaust,ECGS bushing, Blistien 6112 Fronts at 2.5, SPC upper arms, Bilstien 5160 Rear with 2in AAL, Interior light mod, Back up camera anytime Mod, Overhead Console Temp/Compass Fix. Leather Interior with heated seats, Weathertech floor liners, Ultraguage, Oil catch can, Smart Tap, More to come
    I'm not sure if they do mobile, but Anders Glass in Windsor does a damn good job and a very reasonable cost. I'm wanting to say my 2nd gen windshield was around 175-200 2 years ago.
  5. Apr 13, 2021 at 4:35 PM
    #445
    alee891
    Austin
    Black Hills
    Tacomaless
    Appreciate it. I'm in Windsor/Severance and will definitely look into them.
  6. Apr 13, 2021 at 7:02 PM
    #446
    RecklessTLS
    Rowdy
    They are at the Windsor exit on I25
  7. Apr 15, 2021 at 9:42 AM
    #447
    Wackyhacky
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    For those of you who have done one or multiple suspension lifts to your truck, how important is moving to a bigger bump stop in the front? At this point, I have only gained about 2" (if I remember correctly) though I may crank them up a bit more depending on where the ass end sits fully loaded. I had my cab mounts chopped, but I have noticed a rub still going into a left hand turn/front wheel compression and was wondering if this may be why.
  8. Apr 15, 2021 at 9:45 AM
    #448
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Not the solution, although there are performance benefits to be had out of nicer bumpstops.
    Either try to get more caster out of your LCA cams, or get to cutting and hammering.
  9. Apr 15, 2021 at 9:53 AM
    #449
    literallynothing
    literallynothing I tow my new truck around with my old truck
    Noah
    2017 DCSB
    Steel and 37s
    The only way to truly fit a tire is to cut/hammer for clearance at bump and lock. One thing that can help is what @Squeaky Penguin said about adjusting your rear lower control arm cams
    Wackyhacky[QUOTED] likes this.
  10. Apr 15, 2021 at 10:14 AM
    #450
    Wackyhacky
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    Right on..thx. I should have known it's never the simple fix! ha
  11. Apr 15, 2021 at 11:18 AM
    #451
    JWILL10
    JWILL10 Well-Known Member
    Jonathan
    Austin, TX
    2013 Toyota Tacoma SR5 4X4
    Snug Top Super Sport, SCS SR8's 17 X 8.5 -10mm offset, Nitto Terra Grappler G2 (295/70-17), BAMF Hybrid Bumper.
    New to lifts here, what are the performance advantage's of other bump stops vs OEM. I have a 2.5/3 inch lift being installed in the near future. Would like to know if I need them or not? (New ones that is)
  12. Apr 15, 2021 at 12:04 PM
    #452
    literallynothing
    Noah
    2017 DCSB
    Steel and 37s
    Just changes the severity of the impact when your suspension bottoms out
  13. Apr 15, 2021 at 12:12 PM
    #453
    JasonLee
    15 TRD OffRoad
    TMFF likes this.
  14. Apr 15, 2021 at 4:20 PM
    #454
    RecklessTLS
    Rowdy
    I did a CMC with my 2.5in lift with 285 tires and I still rub a little bit when the front end is at full stuff. Where is it rubbing?
  15. Apr 16, 2021 at 6:56 AM
    #455
    Wackyhacky
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    To be honest, I need to do a little more research/observation. It's only happened on a left hand turn into one of those concrete "drainage dips" entering a parking lot and both times I immediately checked for evidence on the CMC areas and they don't look like they have been touched (still dirty). Basically I need to make the wife (or someone) watch while I pull some maneuvers.
  16. Apr 16, 2021 at 6:40 PM
    #456
    RecklessTLS
    Rowdy
    I did the same thing for a few weeks. Its just enough rub to be an annoying. Did you also hammer back the pinch welds in the wheel wheel?
  17. Apr 17, 2021 at 7:48 AM
    #457
    Wackyhacky
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    Yeah. Chopped & Hammered nicely by @YamaDirtrider after I did some decent chopping of plastic & fender liners myself in preparation. Like you said though, still becomes trial & error.
    RecklessTLS[QUOTED] likes this.
  18. Apr 24, 2021 at 8:47 AM
    #458
    Cobrado
    Cobrado Member
    Longmont, CO
    17OR
    Asking for shop recommendations in/near Longmont. Wanting the following done:
    Install JBA UCAs: Have parts, new in box
    Install ECGS Bushing: Have part, tool & x-tra fluid
    Raise Eibachs to second notch: Currently installed on lowest setting
    Alignment
    Spark Plugs: Have plugs
    Work travel picked up overninght to pre-COVID levels and DIY time is scarce. Any input is appreciated.
  19. Apr 25, 2021 at 8:02 PM
    #459
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    2009 Silver DCSB TRD OR
    What haven’t I changed?
    Give these guys a call and see what they can do: https://www.knottsautotech.com/
    For alignments, call Les Schwab Tires in Longmont. They were pretty cool about letting me specify certain alignment specs (caster) when I brought my truck to them.
  20. Apr 26, 2021 at 6:22 AM
    #460
    Wackyhacky
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    I can also recommend Stonum Automotive in Longmont as far as a good shop for alignment after suspension lift.
