Northern Virginia/DC Shop recommendations
Discussion in 'Virginia' started by misterkay, Nov 7, 2018.
  1. Nov 7, 2018 at 3:16 AM
    misterkay
    misterkay [OP] Well-Known Member
    Ed
    Frankfurt, Germany
    2002 Double Cab 2.7 Pre runner
    Good Morning TW,
    I will be moving in the upcoming days to the Northern Virginia/DC area. As much as I would love to work on my 1st gen DC pre-runner, I am completely incompetent when it comes to working on cars and I have no time or space to do it. I'm trying to resolve a vibration issue that starts around 60 mph and stops at 70 mph. I've taken her to a few shops where I live in central PA, but none have been able to completely resolve the issue and I've come to the conclusion that the majority of the shops where I currently live are completely useless. I'm going to be going back and forth from DC to central PA every weekend until the summer when my kids finish the school year and I can find permanent housing in the DC area, so I'm going to be using her quite a bit. I want to keep this truck as long as possible as my dad gave it to me and he's not doing well lately, so its likely the last thing he gives me. I'd like to give the truck to my son in 3 years. Thanks for any recommendations.
    DOUBLLD likes this.
  2. Nov 7, 2018 at 3:19 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    @DOUBLLD can take care of your truck. He is in Sterling VA
    ready6delta likes this.
  3. Nov 7, 2018 at 3:46 AM
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    We also have several 1st gen guys who might be able to chime in. Plus a lot of the guys who own 2nd and 3rd gens owned 1st gen previously or have experience. Welcome to Nova jump in our thread when you get a chance and introduce yourself.
  4. Nov 7, 2018 at 4:18 AM
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    Hit me up for anything you need done.
  5. Nov 7, 2018 at 5:32 AM
    misterkay
    Ed
    Frankfurt, Germany
    Thanks DOUBLLD. I will hit you up when I move down there in the next few weeks. I will be introducing myself on the thread as soon as I find stable housing down there.
    DOUBLLD likes this.
  6. Nov 9, 2018 at 6:41 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Is the vibration just when you're on the gas? Or when coasting as well? Where do you feel the vibration? Through the steering wheel or through the seat/floor? I would guess it's tires or driveline, so I'd start by balancing the tires and check for play in the u-joints and center support bearing. I had a bad u-joint earlier this year. It started as a high speed vibration and progressed into lower speeds as the u-joint got worse.
  7. Nov 11, 2018 at 7:10 AM
    TheDad
    TheDad Well-Known Member
    Northern Virginia
    2006 Tacoma TRD Off-Road
    Waiting on new frame to be installed
    Hey @DOUBLLD I'm getting a p0705 code on my 06 Tacoma. I'm going to attempt to remove the kick panel and check junction block and connector but if they're ok I may need to seek some advice. I really don't want a shop pulling something and trying to charge for a new wire harness if it's not needed.
    DOUBLLD likes this.
  8. Nov 13, 2018 at 3:31 AM
    misterkay
    Ed
    Frankfurt, Germany
    I'm feeling the vibration through the seat. I've taken the tacoma to 3 different shops to have the wheels balanced and each time one shop says the other shop didn't do it correctly. I just haven't had any good luck with the shops in my area in general, which is why I started buying new cars. I only have the tacoma because my dad gave it to me. I would love to be able to do this myself but I have zero mechanic skills. I'll be checking with DOUBLLD when I get to Northern VA.
    DOUBLLD likes this.
