Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. May 17, 2017 at 6:40 AM
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    Don't have a set in particular. Looking to do an HID conversion, assuming @Darkgoatracer actually trades them to me for a 40. Steel reserve ok bud?
    Don't really need a reflective surface for HIDs right? What effect will painting the bezels red have on light output?
    Coot83[QUOTED] likes this.
  2. May 17, 2017 at 6:45 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    If you are going HID then yea man whatever lights you get will likely need a good projector which is pretty much non-existent from a premade aftermarket light assembly. I would research to see what is out there for your gen and see what appeals to you. Theretrofitsource has kits made to swap halogen housing to convert to a projector. We could get a kit of and then paint it up. If you go projector for your headlights, then yes the reflective backing of the halogens can be painted as they wont be useful at all for a projector. Painting in any color shouldn't affect the projector as it operates solely by a concentrated lens and the bulb itself while the halogen uses a "mirror reflection" to achieve its output if that makes sense.
    ready6delta likes this.
  3. May 17, 2017 at 6:45 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    fatfurious2 and Coot83[QUOTED] like this.
  4. May 17, 2017 at 6:47 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Just realized that he is a 2012...will be different light assembly for you since you fit the 2005-2011 era unfortunately.
  5. May 17, 2017 at 6:54 AM
    LocoLocal
    Large American
    Damn I didn't realize the kits would be different. I figured it was just swapping the bulbs, didn't know it was gen specific! Well, never mind then. Might just buy cheap blacked out ebay lights and reseal them.
  6. May 17, 2017 at 6:55 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    The nice thing is, I think your gen is a little cheaper to get lights for than mine which should help.
  7. May 17, 2017 at 6:56 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Oh wait did you mean from a hardware standpoint or from the light assembly itself? The hardware should be the same regardless, its the actual light housing that will obviously not work with your hood and grill.
  8. May 17, 2017 at 6:57 AM
    LocoLocal
    Large American
    Yeh I was just thinking hardware. I know the lights will be different.
    EDIT: Maybe I should clarify, I know the light housings will be different.
  9. May 17, 2017 at 6:58 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I think so
  10. May 17, 2017 at 7:16 AM
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    that's gonna look good man cant wait to see it!
    boogie3478[QUOTED] and Coot83 like this.
  11. May 17, 2017 at 7:21 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Thanks man, it's going to be a long wait for sure.
  12. May 17, 2017 at 8:06 AM
    ready6delta
    JACOB
    looking good man!
  13. May 17, 2017 at 8:07 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Thanks man!
  14. May 17, 2017 at 8:33 AM
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    i cant keep up with yall. its like 5 pages every hour it seems
  15. May 17, 2017 at 8:56 AM
    LocoLocal
    Large American
    So will Moriomoto H1s fit my second gen lights? Or will I need an adapter plate? Looks like second gen light housings are H4/9003.
  16. May 17, 2017 at 8:57 AM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    I dont know if I have the balls to take apart my headlights....
    but I know I dont have the wallet to buy a set of donor headlights for an extra $300-$400... and no one makes 3rd gen aftermarket headlights yet to my knowledge
    after I get settled in the new house, I might rummage around in Karen's purse, find my balls, and take the headlights apart.
    what's the worst that can happen??? also, does anyone know what size halo I would order for the 3rd gen?
    ready6delta, boogie3478 and Coot83 like this.
  17. May 17, 2017 at 9:01 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I think so and then you can get the coordinating bulbs for it. Just to be sure though, I highly recommend calling up theretrofitsource guys as they are very familiar with tacomas and can tell you exactly what set ups will work and any additional info. They even have an IM system on their site if you don't want to chat on the phone.
  18. May 17, 2017 at 9:02 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Nothing wrong in getting your feet wet. At a minimum, might be handy to know how to remove the headlight from the truck.
  19. May 17, 2017 at 9:04 AM
    LocoLocal
    Large American
    I have been reviewing their website pretty thoroughly but up to this point I have found it all a little confusing. I will give them a shout.
  20. May 17, 2017 at 9:06 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I agree man, when you convert you have to start thinking about the bulb changes and stuff. Def will be easier when talking to them, especially since you have stock Tacoma headlights unlike me where I had aftermarket so the conversion required much more thought.
