Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. May 21, 2017 at 7:37 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  2. May 21, 2017 at 7:38 AM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    The oriental flavor...
  3. May 21, 2017 at 7:40 AM
    Superman910
    Superman910 Epic Dirty
    Eric
    Northern Virginia
    2009 Tacoma TRD Sport DCLB 4x4
    Stock as Fuck or Not Fucking Stock
    Be careful....high in sodium....
  4. May 21, 2017 at 7:41 AM
    fatfurious2
    David
    Ashburn, VA
    Darkgoatracer likes this.
  5. May 21, 2017 at 7:50 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Well shit. I was going to pull the bolt out of the top rear part of my shackle to trim it a bit since it's rubbing the frame, and sure enough the rear bushing part of the dakar popped out of alignment. Short of taking everything apart, does anyone know a creative fix to this shitstorm to get the bushing lined back up so I can slip the bolt back through?
  6. May 21, 2017 at 7:50 AM
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    If you don't want it I will Grab it from you I was just gonna order some?
  7. May 21, 2017 at 7:52 AM
    fatfurious2
    David
    Ashburn, VA
    I am not sure. @DOUBLLD
    boogie3478[QUOTED] likes this.
  8. May 21, 2017 at 7:53 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    I might try placing my OEM bottle jack ABOVE the dakar bushing to hold it in place, and use my floor jack under the shackle to try to push them together.
  9. May 21, 2017 at 7:53 AM
    ready6delta
    JACOB
    Looks fun man I need to get a bike to get where my truck can't and just some exploring fun.
    fatfurious2 likes this.
  10. May 21, 2017 at 7:55 AM
    Superman910
    Eric
    Northern Virginia
    I don't need two more than welcome. I need to pick up damn fuel line to I can do it.
  11. May 21, 2017 at 8:15 AM
    ready6delta
    JACOB
    Lmao!
  12. May 21, 2017 at 8:15 AM
    ready6delta
    JACOB
    And they look good on his truck!
    TacoFMS, HCJ[QUOTED] and fatfurious2 like this.
  13. May 21, 2017 at 8:16 AM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    Oh guys I just remembered Exotic Vehicle Wraps is doing their 1 year anniversary party at the shop. Cars, wrap demonstrations etc. You guys should swing by. June 25th 10-2. Here's a video of last year's thing.
    https://youtu.be/UBQ_alDaonI
    ready6delta likes this.
  14. May 21, 2017 at 8:19 AM
    ready6delta
    JACOB
    Sweet I will hit you up this week. Yeah I need to grab the fuel line as well. Sometimes Amazon is just easier cus I order and it shows up. I don't have to Go anywhere lol.
    90yota likes this.
  15. May 21, 2017 at 8:27 AM
    Superman910
    Eric
    Northern Virginia
    Hey when you installed the bedside supports for the d ring what did you put back on. Installing these bitches now
    ready6delta[QUOTED] likes this.
  16. May 21, 2017 at 8:30 AM
    HCJ
    HCJ Well-Known Member
    Virginia --> Texas
    '05 Taco with not enough miles
    I didn't put all the shit that's under the D ring back, just the D ring and bolt
  17. May 21, 2017 at 8:30 AM
    HCJ
    Virginia --> Texas
  18. May 21, 2017 at 8:39 AM
    Superman910
    Eric
    Northern Virginia
    @Lots2Learn58 and @ready6delta
    Both sides seem to go up at an angle, I tightened the bed bolts down. Bottom is flush with bed but this is what it looks vertical. Driver side then passenger side
    Is this fine. Or should I push a little on driver side and drill holes that waywhere it is a little more aligned.
  19. May 21, 2017 at 8:41 AM
    HCJ
    Virginia --> Texas
    I pushed mine over so it was aligned. I drilled the top hole then bolted that down to hold it and drilled the rest
    ready6delta and TACOVRD like this.
  20. May 21, 2017 at 8:43 AM
    Superman910
    Eric
    Northern Virginia
    So keep bottom tight, push over a little so it is flushed and even top to bottom. Then drill hole at top, put in bolt push bottom and drill in hole? Sound about right?
