Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. May 21, 2017 at 8:58 AM
    HCJ
    HCJ Well-Known Member
    Virginia --> Texas
    '05 Taco with not enough miles
    Sounds about right to me!
  2. May 21, 2017 at 9:07 AM
    Ryan.orr87
    Ryan.orr87 Well-Known Member
    It was a blast. I don't have a bike personally but I want one now
    ready6delta[QUOTED] likes this.
  3. May 21, 2017 at 9:16 AM
    Superman910
    Superman910 Epic Dirty
    Eric
    Northern Virginia
    2009 Tacoma TRD Sport DCLB 4x4
    Stock as Fuck or Not Fucking Stock
    Not perfect...but good enough for government work as they say
    TacoCat, ready6delta and At The Helm like this.
  4. May 21, 2017 at 9:16 AM
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    I left the d ring off and just put all the regular bolts back in and installed the new ones.
  5. May 21, 2017 at 9:17 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    as they what????
    EDIT: also make sure to blow the metal shavings away. I didnt, and now have small rust spots
    At The Helm likes this.
  6. May 21, 2017 at 9:21 AM
    Superman910
    Eric
    Northern Virginia
    Fixed it and I used the @fatfurious2 famous blower to blow it all away.
  7. May 21, 2017 at 9:25 AM
    At The Helm
    At The Helm ATH Fab Vendor
    Morgan
    Gardnerville, NV
    2015 AC 4x4 TRD OR & 2019 T4R
    Kings, TC UCAS, SCS SR8's, ATH bumpers
    Did you get it figured out? I build them square so in theory they should be plumb and vertical but the plastic beds seem to have some variances... Just thumb it over so it sits plumb and mark your holes :thumbsup:
    ready6delta and TACOVRD like this.
  8. May 21, 2017 at 9:27 AM
    Superman910
    Eric
    Northern Virginia
    Ahhhhhhhhh shit @At The Helm is in the house...finally installing these bitches. My driver side had just a bit of warping passenger side looks good thankfully.
  9. May 21, 2017 at 9:28 AM
    Superman910
    Eric
    Northern Virginia
    I figured it out as best I could. Looks square enough. Driver side was a little more fucked up but I managed. I was lazy and just drilled the last two bolts while the bracket was still on...and then just resprayed it.
    At The Helm[QUOTED] likes this.
  10. May 21, 2017 at 9:33 AM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    What are the benefits of these bed supports?
  11. May 21, 2017 at 9:36 AM
    Superman910
    Eric
    Northern Virginia
    Fix the warping flaw in Tacoma s and more anchor points....also help when you go hogging.
  12. May 21, 2017 at 9:36 AM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Prevent bed from splaying outward if you put a canopy / bed rack / RTT on it. Also probably minimizes bed flex if you wheel even without any weight on top.
    At The Helm and Superman910 like this.
  13. May 21, 2017 at 9:37 AM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    Warping flaw?
  14. May 21, 2017 at 9:38 AM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    It's a light duty truck with a light duty bed.
    Superman910 likes this.
  15. May 21, 2017 at 9:42 AM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    I typically run a cap on my truck. Is this something I need? (And by "need" i mean something i may potentially see some sort of improvement from and its another mod) At this rate I'm gonna be living in a cardboard box.
  16. May 21, 2017 at 9:44 AM
    fatfurious2
    David
    Ashburn, VA
    I put on Total Chaos bed stiffeners. It was where my CB antenna was mounted to
    ready6delta and 90yota like this.
  17. May 21, 2017 at 9:45 AM
    fatfurious2
    David
    Ashburn, VA
    @ready6delta has a cap, and has the stiffeners.
    as seen in @boogie3478 video.. you will go broke. Or stay stock like @Superman910
    boogie3478 and ready6delta like this.
  18. May 21, 2017 at 9:48 AM
    Superman910
    Eric
    Northern Virginia
    Remember everyone I am stock until I do a suspension. What are the other qualifiers @fatfurious2 ?
  19. May 21, 2017 at 9:49 AM
    fatfurious2
    David
    Ashburn, VA
    dont ask me the rules! Make the rules for yourself!
    I go by.. can someone see a difference if I park next to a similar vehicle in a lot?
    ready6delta likes this.
  20. May 21, 2017 at 9:51 AM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    Sounds like you'll be more nodded than me by next week at this rate
    ready6delta and fatfurious2 like this.
