Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Jun 6, 2017 at 7:56 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Ah that is true too.
    Mr. Projekt[QUOTED] likes this.
  2. Jun 6, 2017 at 7:56 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Yeah the only time I rubbed (after trimming the cheap plastic fender lining) on the cab mount before the chop was at full lock.
  3. Jun 6, 2017 at 7:56 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I would rub whenever hitting concrete thresholds going into parking lots.
    boogie3478[QUOTED] likes this.
  4. Jun 6, 2017 at 7:57 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    When turning or going straight too?
  5. Jun 6, 2017 at 7:58 AM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    yea I didnt even trim my plastics (which only needed a little bit) but since I put it up for sale, I figured I'd just let the new owner decide what he wanted to do....
    not my concern any more
  6. Jun 6, 2017 at 7:59 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Intended!
    ready6delta and TacoCat[QUOTED] like this.
  7. Jun 6, 2017 at 7:59 AM
    CaliDevilDoc
    CaliDevilDoc Well-Known Member
    San Diego, CA
    2016 Barcelona Red TRD Off-Road 4x4. 1995 FZJ80
    OME nitrochargers, 886, and Dakars
    For lift, why not just do full ome springs, Dakar, nitrochargers? The ome nitrochargers are designed to go with one springs right?
    boogie3478 likes this.
  8. Jun 6, 2017 at 8:00 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Mr. Projekt likes this.
  9. Jun 6, 2017 at 8:00 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Turning...at 45 degree angles would be enough to cycle my suspension for a rub. Granted my front was only about 2.25 inches at the time with 285s.
  10. Jun 6, 2017 at 8:00 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Yes but the nitros limit the rear flex you can get with the dakars versus running an extended travel shock.
    CaliDevilDoc[QUOTED] likes this.
  11. Jun 6, 2017 at 8:05 AM
    CaliDevilDoc
    San Diego, CA
    Oh I see. I have Dakar's and nitrochargers front and rear, and I've definitely seen my rear flex limited.
    Well you can get some extended goodness in the rear and nitrochargers in the front. If on a budget then skip ome in the front and just stock springs on Bilstein 5100 for the lift.
    Also, give me more info on what extended travel rear shocks work well with Dakar's (I am going to do shackle flip and will need it in the future).
  12. Jun 6, 2017 at 8:08 AM
    Superman910
    Superman910 Epic Dirty
    Eric
    Northern Virginia
    2009 Tacoma TRD Sport DCLB 4x4
    Stock as Fuck or Not Fucking Stock
    @boogie3478 exact setup :
    5100s + 887s + LR UCAs up front & extended travel 5100s + dakars + extended brake lines in the back
    Yep I saved it so I could price it.
    ready6delta and boogie3478 like this.
  13. Jun 6, 2017 at 8:08 AM
    jschona1
    jschona1 Well-Known Member
    Jeff
    Loudoun County
    A Corolla...
    I suppose I could nip it all in the bud and get the CMC brackets now and have @DOUBLLD install them when I get them.
  14. Jun 6, 2017 at 8:12 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    You could also knock out the CMC now before the install. You wont notice the difference of them not being there.
  15. Jun 6, 2017 at 8:15 AM
    Superman910
    Eric
    Northern Virginia
    I think I am going 255's and then I don't have to worry about shit
  16. Jun 6, 2017 at 8:16 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    I like the Bilstein 5100 extended travel rear shocks. There are "better" extended travel shocks out there, but the Bilstein's give you more travel than even the Icons.
    ready6delta likes this.
  17. Jun 6, 2017 at 8:16 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    @HeadStrong Off-Road
  18. Jun 6, 2017 at 8:17 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Ah ok cool, I think I remember @fatfurious2 say that you might still need to trim a little at full lock and cycled though?
  19. Jun 6, 2017 at 8:17 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    If I had to do it over again I would go this route. But you never really know if you'll need the CMC.
  20. Jun 6, 2017 at 8:18 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
