Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Jun 15, 2017 at 12:23 PM
    jacoblb
    jacoblb Well-Known Member
    MD
    2010 AC 2.7L
    "Shouldn't need any chopping or grinding" being the key words haha
  2. Jun 15, 2017 at 12:29 PM
    CaliDevilDoc
    CaliDevilDoc Well-Known Member
    San Diego, CA
    2016 Barcelona Red TRD Off-Road 4x4. 1995 FZJ80
    OME nitrochargers, 886, and Dakars
  3. Jun 15, 2017 at 12:29 PM
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    Yes shouldn't being the operative word and we all know what the means...
    jacoblb[QUOTED] likes this.
  4. Jun 15, 2017 at 12:30 PM
    CaliDevilDoc
    San Diego, CA
    @fatfurious2 Look at the AC Drain, see the pool of water on the ground. Success!
    ready6delta, TacoCat and fatfurious2 like this.
  5. Jun 15, 2017 at 12:31 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Looking great! To to use that tent!
  6. Jun 15, 2017 at 12:31 PM
    CaliDevilDoc
    San Diego, CA
    Yall know what this is. Thanks @fatfurious2 for help installing!
  7. Jun 15, 2017 at 12:32 PM
    CaliDevilDoc
    San Diego, CA
    More pornography for you sickos:
  8. Jun 15, 2017 at 12:33 PM
    fatfurious2
    David
    Ashburn, VA
    Went to grease my zerks.. only found 2. Side note, aftermarket driveshaft only has 1.
    ready6delta likes this.
  9. Jun 15, 2017 at 12:38 PM
    jacoblb
    MD
    2010 AC 2.7L
    Zerk fittings aka rust nipples. I hate greasing on an aircraft where we replace the fittings relatively often.
    fatfurious2[QUOTED] likes this.
  10. Jun 15, 2017 at 12:40 PM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    you should have three on your rear shaft, two on the front. unless access cabs are different.
  11. Jun 15, 2017 at 12:41 PM
    TacoCat
    Johnny-5
    Chantilly, VA
    Nice. I put mine in the bed cubby. Also I did my ac drain long ago too. Why toyota chooses to let the tube drip right on top of the frame is beyond me.
    CaliDevilDoc[QUOTED] likes this.
  12. Jun 15, 2017 at 12:44 PM
    CaliDevilDoc
    San Diego, CA
  13. Jun 15, 2017 at 12:46 PM
    fatfurious2
    David
    Ashburn, VA
    2 on the front. Couldn't find the second one. I need to spray off the gunk in there. The rear driveshaft is aftermarket. Only one on it.
    Here is the OEM one
    TacoCat[QUOTED] and CaliDevilDoc like this.
  14. Jun 15, 2017 at 1:04 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Are you wanting to leave your overload leaf in? That takes a little modification.
    Installing an AAL can be a bitch. Getting enough room between the leafs and the axle to get the new centering pin in is a PITA. May be easier to just pull the leafs out again.
    The second one on the front driveshaft is hiding behind a small heat shield. Two 12mm bolts to remove it ( I just greased mine a couple days ago)
    It's the same on the access cabs for future reference
  15. Jun 15, 2017 at 1:05 PM
    fatfurious2
    David
    Ashburn, VA
    Ill look on Monday. Im just too tired now. Tired of doing nothing all day
    ready6delta, HCJ, jacoblb and 2 others like this.
  16. Jun 15, 2017 at 1:17 PM
    HCJ
    HCJ Well-Known Member
    Virginia --> Texas
    '05 Taco with not enough miles
    I have never greased the front drive shaft because I can't reach with my skids in the way, guess I should do that next time they come off.
  17. Jun 15, 2017 at 1:20 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Just greased my recently purchased 05's shafts. I guarantee they've never been done, and the old grease was BLACK. Replaced with some synthetic Mobil 1 grease.
  18. Jun 15, 2017 at 1:22 PM
    HCJ
    Virginia --> Texas
    I have the Mobil one grease in my grease gun, I just need to get in there and do it. You pump until the old grease starts getting pushed out, correct?
    fatfurious2 likes this.
  19. Jun 15, 2017 at 1:23 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yep. It took me a lot of pumping. I just kept going until mostly clean grease was coming out. Wear gloves and have some rags handy. Otherwise you'll fling grease all around your under carriage.
    TacoCat, ready6delta and HCJ[QUOTED] like this.
  20. Jun 15, 2017 at 1:26 PM
    fatfurious2
    David
    Ashburn, VA
    Oh i left it on the zerk. You can see where the grease is the next time
