Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Jun 17, 2017 at 6:05 AM
    Superman910
    Superman910 Epic Dirty
    Eric
    Northern Virginia
    2009 Tacoma TRD Sport DCLB 4x4
    Stock as Fuck or Not Fucking Stock
    I looked there first.
    @JWROSE4 does that thing kick on when you are in there or do you keep it off through a breaker? Any heat issues behind there? Guessing you used like 6 or 8 gauge wire for that kind of run and amp draw?
  2. Jun 17, 2017 at 6:38 AM
    JWROSE4
    JWROSE4 Well-Known Member
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    I used the wiring harness that it came with just had to lengthen it. I believe I added about 5-6 ft. The 2 reds are 10 and the black ground is 8. I have it on a switch and only turn it on when I need it. Because I have the tank it will shut off when the tank gets full. I dont run it for long periods at a time so no heat issues so far. I just keep stuff that is behind the seat away from it so there is air flow. If I know Im gonna use it for a while I figure I will just put the seat forward. Down the road when I get lockers the tank should be enough to keep it from coming on.
  3. Jun 17, 2017 at 6:51 AM
    Superman910
    Eric
    Northern Virginia
    you have it running through the firewall or out the air gap in the back wall? I was debating on the tank.
  4. Jun 17, 2017 at 6:55 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    the tank is necessary if you want to run air tools. If not, its not really needed. Right @Arcticelf ?
  5. Jun 17, 2017 at 7:10 AM
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    Yeh David told me where you live…:spy:
    chiefcrunchy[QUOTED] likes this.
  6. Jun 17, 2017 at 7:21 AM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    Damn dawg...fancy
  7. Jun 17, 2017 at 7:22 AM
    Superman910
    Eric
    Northern Virginia
    trying to be like you...sadly I still look stock though.
  8. Jun 17, 2017 at 7:37 AM
    fatfurious2
    David
    Ashburn, VA
    Stock dented truck
    ready6delta and JWROSE4 like this.
  9. Jun 17, 2017 at 7:38 AM
    Superman910
    Eric
    Northern Virginia
    fixed that for you cause I fixed it for me
    fatfurious2[QUOTED] likes this.
  10. Jun 17, 2017 at 9:10 AM
    Superman910
    Eric
    Northern Virginia
  11. Jun 17, 2017 at 9:10 AM
    fatfurious2
    David
    Ashburn, VA
  12. Jun 17, 2017 at 9:12 AM
    Superman910
    Eric
    Northern Virginia
    Had to go look at my alerts. for some reason it didn't show up
  13. Jun 17, 2017 at 9:12 AM
    fatfurious2
    David
    Ashburn, VA
  14. Jun 17, 2017 at 9:12 AM
    fatfurious2
    David
    Ashburn, VA
    NE craigslist finds. @Lots2Learn58 and I might go on monday.. not sure yet though
  15. Jun 17, 2017 at 9:13 AM
    Superman910
    Eric
    Northern Virginia
    I liked it you filthy Animal
  16. Jun 17, 2017 at 9:15 AM
    fatfurious2
    David
    Ashburn, VA
    i turned off like notifications. So when @ready6delta logs in and likes stuff from 27 pages ago, I dont see notifications :D
  17. Jun 17, 2017 at 9:16 AM
    Superman910
    Eric
    Northern Virginia
    ready6delta and boogie3478 like this.
  18. Jun 17, 2017 at 9:29 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
  19. Jun 17, 2017 at 10:24 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    @LSC15 how do i fix my drooping shroud? I assume the adhesive failed? My truck looks sad, i think it knows i mean to part ways with it soon...
    Please dont say take the headlight apart...
    EatSleepTacos and boogie3478 like this.
  20. Jun 17, 2017 at 10:28 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    I can imagine.
    I have been called up a handful of times and its definitely an experience. First time i ever went up they told me to raise my right hand and i raised my left, i was that nervous :facepalm:
    EatSleepTacos likes this.
