Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Jul 18, 2017 at 7:04 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Will do!
    fatfurious2[QUOTED] likes this.
  2. Jul 18, 2017 at 7:05 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I just realized this...would I have any issues with a third brake light if the RTT is covering it?
    EatSleepTacos likes this.
  3. Jul 18, 2017 at 7:11 AM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    that would be SWEET
    Firestik Firefly antenna and going to be mounted on a tab on the bed stiffener
    boogie3478[QUOTED] likes this.
  4. Jul 18, 2017 at 7:13 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Worst case you fail because of that, then just take off your RTT, go back, pay your $1 to reinspect, and problem solved. Or get a small red LED strip to mount to your bed rack so you have a 3rd brake light.
  5. Jul 18, 2017 at 7:17 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Sure make sure the inspector can't see it at all. ;)
  6. Jul 18, 2017 at 7:18 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Im tempted to make some sort of remote light on the same brake light circuit. Might need to look more into this...
  7. Jul 18, 2017 at 7:30 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Boom. New 3rd brake light, and can also be wired to be constantly amber for an off road rear light to cut through dust.
    https://www.amazon.com/Purishion-Un...rd_wg=5lliE&psc=1&refRID=1HK1D79DPDBV7E3KAAT6
    ready6delta and Coot83[QUOTED] like this.
  8. Jul 18, 2017 at 7:54 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
  9. Jul 18, 2017 at 8:02 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    So after digging through 32 pages on the VooDoo bed rack thread, I'm 99.8% certain I'm getting one of those things. Someone please buy my bedbars first though!
    ready6delta likes this.
  10. Jul 18, 2017 at 8:06 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    yea those things look SUPER good.... I say go for it man! it'll look great!
  11. Jul 18, 2017 at 8:28 AM
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    is your tab gonna be inside or outside the besttop?
  12. Jul 18, 2017 at 8:30 AM
    ready6delta
    JACOB
    You looking at the mid or tall?
  13. Jul 18, 2017 at 8:30 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    hmm. I didnt even think about that.....
    it's inside... since it's on the bed reinforcements...
    ready6delta[QUOTED] likes this.
  14. Jul 18, 2017 at 8:31 AM
    ready6delta
    JACOB
    If I ever decide to ditch the shell it will kbvoodoo or CBI bedrack.
  15. Jul 18, 2017 at 8:33 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    TALL!
  16. Jul 18, 2017 at 8:38 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    You think so this happens quite a bit
    https://www.youtube.com/watch?v=ZdeNz4ybF34
  17. Jul 18, 2017 at 8:38 AM
    ready6delta
    JACOB
    so your antenna will be inside sticking out the topper rear window zipper? I never thought about it either until I got the shell and then got the @Shmellmopwho CB mount it sticks out of shell off the two bolt tabs just inside tailgate and fits perfect. ran coax up out of rear driver brake light and up into mount with firestick hd mount and spring coil with quick disconnect and it worked great and got good readings when tuned. Get the 18 ft cable to reach your cb and run it like david did unto the driver side grommet near door and front seat up into cab. @Superman910 and @Coot83 helped me. I retuned it a few weeks back in an open area after I ordered a cheap swr meter and relay. Quick disconnect is great because I can leave it on mount and no water gets into it and leave the antenna in shell secured and out of sight until I need to use it on trail or trips.
  18. Jul 18, 2017 at 8:40 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    I might have to do something similar to that... Thanks for the tips man! I am mad at myself for not even thinking about that haha
    ready6delta[QUOTED] and Coot83 like this.
  19. Jul 18, 2017 at 8:41 AM
    jschona1
    jschona1 Well-Known Member
    Jeff
    Loudoun County
    A Corolla...
    I wonder if that can be wired into my current plug that my Leer used to use for its brake light.
  20. Jul 18, 2017 at 8:43 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Im def thinking when I get my new bed rack made to have this attached to the bed rack and have a disconnect at the bottom of the bed rack so I can remove it when not in use.
    ready6delta and Casper66 like this.
