Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Aug 8, 2017 at 7:16 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Makes sense about some needs...still though it does leave a good amount of room to debate what you are willing to throw on it.
    Sombretaco[QUOTED] likes this.
  2. Aug 8, 2017 at 7:17 AM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    I doubt it's responsible for your wobble man. that could be tie rods / ball joints / alignment / tires out of balance or wearing uneven
    but from what youre describing... I'd go OME lift, Dakar leaf pack, w/ LR UCAs and take the rest of the money you would have spent on Icons and put all new ball joints / tie rods / wheel bearings in
  3. Aug 8, 2017 at 7:18 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    guilty :wave:
    ready6delta likes this.
  4. Aug 8, 2017 at 7:18 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Wheel bearings do go out quite fast...replaced mine at 80k.
    Mr. Projekt[QUOTED] likes this.
  5. Aug 8, 2017 at 7:25 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    yep he only have 45k ish miles on his.... so it might not be ALL of those things mentioned... but he's likely not getting death wobble from a 2.5" spacer lift and a 2" block in the rear....
  6. Aug 8, 2017 at 7:27 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Could it be the needle bearing? I know as you get close to three inches of lift you start to push that component, although it does sound like wheel bearings are in order. He could always try to remove the wheel and the hub cover and see if there is any milky residue around it. Might see something, or might not.
  7. Aug 8, 2017 at 7:31 AM
    Sombretaco
    Sombretaco Yours might go fast but mine goes anywhere
    Cole
    DC
    2013 Grey Tacoma 4x4
    Leer Cap Prinsu Cabrac Ultra gauge
    but dont i have to go to the stealership to get those replaced or can i go to my local garage?
  8. Aug 8, 2017 at 7:32 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    yep... I'm sure we can look it over and probably have a little better idea about where it's coming from
  9. Aug 8, 2017 at 7:33 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    @DOUBLLD can help you out and has the shop and his prices are virtually nothing compared to a dealership
  10. Aug 8, 2017 at 7:37 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Agreed. I would recommend spending the extra coin to get them new with the prepressed assemblies. They cost more, but the whole assembly is fresh and should make for install pretty straight forward. @nj636 is who I got my stuff from. He is in jersey, so it gets here pretty fast.
  11. Aug 8, 2017 at 7:39 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    yea that's a solid idea.... especially if it makes for an easy bolt on and youre done!
    Coot83[QUOTED] likes this.
  12. Aug 8, 2017 at 7:41 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    True, only issue is there is no easy way around getting that hub out first. You have to take a pry bar and very slowly shim it out by constantly pressing all sides. Its something worth paying someone for even with the assembly. Once it is off though, its just a simple bolt on process, but you have to once again be very careful in installing the hub assembly and ensure that the bolts are tightened down very evenly.
  13. Aug 8, 2017 at 7:47 AM
    HCJ
    HCJ Well-Known Member
    Virginia --> Texas
    '05 Taco with not enough miles
    I second that.
  14. Aug 8, 2017 at 7:50 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    and that's where Dan would come in handy
    I parked next to a TRD Pro Tundra in cement the other day at work...... had to flip my boner up into my wasteband. haha
    ready6delta and HCJ[QUOTED] like this.
  15. Aug 8, 2017 at 7:52 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Yep, just stating that there are still challenges with a full hub assembly.
  16. Aug 8, 2017 at 7:52 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Since we all seem to be on TW all day long while at work, why don't we all just open an off-road park/Tacoma garage around here somewhere and quit our jobs?
    ready6delta, Braves95 and fatfurious2 like this.
  17. Aug 8, 2017 at 7:55 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I wont quit, but Im interested in renting out a garage space
  18. Aug 8, 2017 at 7:56 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    bleh.... I've only done a few hub assemblies.... they still haunt my dreams. haha
    hours w/ a blow torch and dead blow hammer.....
    because we would have zero money to mod our own Tacomas haha
    ready6delta and Coot83[QUOTED] like this.
  19. Aug 8, 2017 at 7:58 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Lol I meant let's start a business!
    Braves95 likes this.
  20. Aug 8, 2017 at 8:10 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    can I be an investor? and keep working my current, steady, decent paying job??? haha
