Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Aug 13, 2017 at 12:15 PM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Been doing the same now for about 10 years. Especially if you are ok with really short hair, its worth learning on. Worst case you cut it short and try again next time.
  2. Aug 13, 2017 at 12:17 PM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I dont use a mirror, but I keep the hair on the side of my head pretty short...in the upper 1 region. I do fade it though with three sections of height on the side of my head, just use my fingers as a guide as I go around. No one seems to notice so I assume it works.
    ready6delta and boogie3478 like this.
  3. Aug 13, 2017 at 12:20 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    I used to do a different length for the top/sides. Now I'm just lazy and do it all at one length. I use a 4 guard during the winter and a 1 guard the rest of the year.
    TacoCat likes this.
  4. Aug 13, 2017 at 12:48 PM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Not me man, I used a long 6 for the front, fade to a low 5 in back. Get the sides to a 3 on the very edges and then at the apex between the side and the top I get to a 2. After that I fade the whole side of my head with a 1 from high to low. Im sure it sounds confusing, but this takes me like 10 min to do.
    ready6delta likes this.
  5. Aug 13, 2017 at 12:51 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    number 1 all the way. Easiest, and saves on shampoo
    TacoCat, JWROSE4, jschona1 and 3 others like this.
  6. Aug 13, 2017 at 12:55 PM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    That's definitely a benefit. I spend a lot of time outside for work all year. I like the longer hair in the winter for a little extra insulation and shorter in the summer is a little cooler.
  7. Aug 13, 2017 at 1:18 PM
    fatfurious2
    David
    Ashburn, VA
    I really want to get my truck weighed.
    Im browsing these :drool:
  8. Aug 13, 2017 at 1:21 PM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Check out your city/county dump. They've usually got a scale.
  9. Aug 13, 2017 at 1:45 PM
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    What's the main difference between these and dakars?
  10. Aug 13, 2017 at 1:50 PM
    JWROSE4
    JWROSE4 Well-Known Member
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    The SR5 has the LSD as well
  11. Aug 13, 2017 at 1:55 PM
    fatfurious2
    David
    Ashburn, VA
    ready6delta[QUOTED] likes this.
  12. Aug 13, 2017 at 1:58 PM
    JWROSE4
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    Me too...maybe not 20 years but since I was 18, so 15 years. It involves some shaving cream and the same razor you shave your face with. Just keep on shaving, not everyone can pull of the bald look though.
  13. Aug 13, 2017 at 2:00 PM
    fatfurious2
    David
    Ashburn, VA
    the straight razor? I barely trust the barber with that, let alone myself to cut my hair
    JWROSE4[QUOTED] likes this.
  14. Aug 13, 2017 at 2:06 PM
    JWROSE4
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    No not a straight razor, I use the mach turbo does a good job. When I was in Iraq I had a guy that was trying to get his barber license to open his own barber shop and he was cutting everyones hair. He wanted practice with his straight razor so I figured saves on my shaving cream and razor blades and a free hair cut why not. It does a pretty good job but don't know if I would trust just anyone to do it with a straight razor.
  15. Aug 13, 2017 at 2:07 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I know from 05 to 08, only the sport had a real LSD. I think 09+, they all came with the simulated LSD.
  16. Aug 13, 2017 at 2:17 PM
    quis23
    quis23 Well-Known Member
    Duan
    good ole' Manassas VA
    wait.... I thought you were firefighter?
    boogie3478[QUOTED] and JWROSE4 like this.
  17. Aug 13, 2017 at 2:32 PM
    fatfurious2
    David
    Ashburn, VA
    oh, I dont have to shave, so I dont know what Mach razors are...
  18. Aug 13, 2017 at 2:32 PM
    fatfurious2
    David
    Ashburn, VA
    that is @chiefcrunchy
  19. Aug 13, 2017 at 2:40 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Lol I WAS like 15 years ago for a little while. Sadly never got close to a fire though. It was all paramedic duties.
    JWROSE4 and quis23[QUOTED] like this.
  20. Aug 13, 2017 at 2:53 PM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
