Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Sep 27, 2017 at 9:15 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Of course! Are you off on Saturday?
    ChadsPride likes this.
  2. Sep 27, 2017 at 9:18 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I am off. Ill be at AOAA for the Mobtown event
    ChadsPride and Mr. Projekt like this.
  3. Sep 27, 2017 at 9:27 AM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    Hey guys,i want to run a thin wheel spacer in the front of my truck to get some of my tire stickout back after the extra lift. Any idea how long the stock wheel studs are? I think im gonna run a 10 mil spacer and feel likei need the extra stud length.
  4. Sep 27, 2017 at 9:33 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    They're short as shit. At the very least, run extended thread lug nuts. To be safe though extended studs are your best bet.
    ChadsPride and Arcticelf like this.
  5. Sep 27, 2017 at 9:34 AM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    agreed... I've seen horror stories posted about lugs being short on this forum
  6. Sep 27, 2017 at 9:34 AM
    jschona1
    jschona1 Well-Known Member
    Jeff
    Loudoun County
    A Corolla...
    I can hold onto it if you'd like to pick it up since I am nearby.
  7. Sep 27, 2017 at 9:43 AM
    fatfurious2
    David
    Ashburn, VA
    if you want. Im leaving Friday afternoon. But there is no real rush. I was just checking with Brian..
  8. Sep 27, 2017 at 10:21 AM
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    anyone with a non manual or offroad on here willing to let me test my wilwood adapter on your truck? i will just need your truck for a few hours to be honest. i will do all the work and put it back to stock when done unless you want to buy the master and adapter at cost.
  9. Sep 27, 2017 at 10:22 AM
    fatfurious2
    David
    Ashburn, VA
    @Superman910
  10. Sep 27, 2017 at 10:24 AM
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    good look im gonna text him and see.
  11. Sep 27, 2017 at 10:28 AM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    What's it do?
  12. Sep 27, 2017 at 10:34 AM
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    this will improve the performance of the brakes. better feel stopping power etc. it is a adapter to use a much better master cylinder the wilwood. has more fluid capacity, shorter throw with a better ratio over stock
  13. Sep 27, 2017 at 10:34 AM
    Cody23
    Cody23 Well-Known Member
    Cody
    probably hunting or camping
    2022 TRDOR 6MT
    6112/5160 SCS 285s GFC
    anybody ever heard any bad stuff about the cobra 75w CB radio?
  14. Sep 27, 2017 at 10:36 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    nope, I ran it... no problems... just make sure and get a solid ground on it otherwise it will be "staticy"
    ready6delta and ChadsPride like this.
  15. Sep 27, 2017 at 10:38 AM
    Cody23
    Cody
    2022 TRDOR 6MT
    do u still have one on your truck?
  16. Sep 27, 2017 at 10:44 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    oh no I had the Cobra in an old Jeep..... I ONLY Run the Midland 75-822 in my last 4 trucks
    it's small and compact, easy to use, and if I get stuck and I'm in a search and rescue scenario (as I was in Colorado 3 years ago) I can unplug it, plug the battery pack in and it's a portable CB as well w/ a little mini antenna that screws onto it
    so it's dual purpose: in truck and portable enough to clip on my belt
  17. Sep 27, 2017 at 11:00 AM
    Cody23
    Cody
    2022 TRDOR 6MT
    what kind of antenna did u use for it on ur truck?
  18. Sep 27, 2017 at 11:02 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    4ft firestik antenna,
    firestik spring
    firestik cb antenna mount kit
    and I mounted it to the At the Helm Bed Stiffener
  19. Sep 27, 2017 at 11:21 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    @ChadsPride is baaaaacckkkkkkkkk!!!!
  20. Sep 27, 2017 at 11:22 AM
    ChadsPride
    Sponsored by TacomaWorld.com
