Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Mar 3, 2018 at 4:11 PM
    JWROSE4
    JWROSE4 Well-Known Member
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    So what your saying is that by adjusting the balljoint setting on the LR UCA to the +1 setting it actually moved the wheel back to the cab? Reading the instructions it looked like it moved the wheel towards the front. I was thinking they should have put the balljoint setting to the nuetral position and see what they could get with the cams. However my knowledge on alignments leaves a lot to be desired. On my truck I left the setting in the nuetral position and they got me good numbers. I also am running 255's though.
    ready6delta likes this.
  2. Mar 3, 2018 at 4:13 PM
    JWROSE4
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    No it was not that much. Which is why he is frustrated. He has been to multiple shops and cant get good numbers. He even went to the shop that has gotten him good numbers before.
  3. Mar 3, 2018 at 4:23 PM
    Jcash
    Jcash Well-Known Member
    Jeremiah
    Va
    2015 silver Tacoma Trd sport
    What you mean
  4. Mar 3, 2018 at 4:39 PM
    PyritePirateBill
    PyritePirateBill Well-Known Member
    Bill
    North Myrtle Beach, SC
    2014 pyrite mica TRD Sport 4x4 AC
    OME 886 Nitrocharger lift, Dakar HD leaf pack, u-bolt flip kit, Bilstein b110 rear shocks, Wheeler's super bumps,18x9 Worx Havoc, 35/12.50/18 Nitto Ridge Grapplers, ENVE Grille with LED lightbar & raptor leds, ditch lights, 6k hid, tinted tails, AtTheHelm bed stiffeners, SOS Concepts rear bumper, Demello baja front bumper, Smittybuilt 9.5k winch, Mobtown weld-on sliders, AllPro IFS & transm. skid, Mobtown transfer case skid, led fogs, led lights in rear bumper, 54" Bulldog hi-lift jack, Razorback shovel & axe on Quickfist mounts, Cobra CB w/Firestik antenna, Yellow wire mod for 4Lo, URD y-pipe, 2.5" custom exhaust w/ Borla muffler, Viair portable air compressor, Kryptek Typhon seat covers, AJT dash knobs
    Yes, exactly.
    Think of caster this way: stand a yardstick straight up and down at the side of your drivers side front tire. That is zero caster. Slide the bottom of the yardstick forward. The angle of the yardstick is now positive caster. If you slide the bottom of the tire, with the LCA, forward, you have moved it away from the cab mount.
    That may get you only 2° caster, but you want 4? Well the only way to make that angle slant more is by moving the top of the yardstick/tire rearward. Yeah, it gives you more caster, but your moving the tire rearward again, back towards the cab mount again.
  5. Mar 3, 2018 at 4:54 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    Just picked up my liscense plates from the dealer.
    Is that a mod? Lol
  6. Mar 3, 2018 at 5:00 PM
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    Yes and a necessary one!
    PyritePirateBill and TacoCat like this.
  7. Mar 3, 2018 at 5:13 PM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Yeah they leave a little to be desired looks wise. Hopefully function will be worth it. If not, theyll be easy to remove.
  8. Mar 3, 2018 at 5:16 PM
    TacoCat
    Johnny-5
    Chantilly, VA
    Thats a good explanation. I have never understood the caster/camber/toe stuff very well but using the yardstick makes it easier to picture.
  9. Mar 3, 2018 at 5:17 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Meaning minor variations between the items is common.
  10. Mar 3, 2018 at 5:18 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Try 0* toe, 0* camber, 2.5 - 3* caster
  11. Mar 3, 2018 at 5:19 PM
    JWROSE4
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    Starting to make sense...thanks
  12. Mar 3, 2018 at 5:20 PM
    JWROSE4
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    Thats what was told to the tech and the numbers that ended up with were the ones above.
    CanisLupus[QUOTED] likes this.
  13. Mar 3, 2018 at 6:10 PM
    PyritePirateBill
    Bill
    Caps are playing great tonight outside!
    LocoLocal likes this.
  14. Mar 3, 2018 at 6:50 PM
    CanisLupus
    Stokesdale | NC
    High Tech Auto in Chantilly charges a lot for alignments but they always got mine right the first time whereas other places couldn’t get it right no matter how many times they tried
  15. Mar 3, 2018 at 7:09 PM
    PyritePirateBill
    Bill
    What's happened in the past 20 years is that most vehicles have the alignment specs built in to the suspension with no adjustment for caster or camber. Only adjustment is for toe. Yet shops are charging $100+ for alignments and all they are doing is setting the toe. Some of their alignment techs don't even know how to set camber and caster when they DO get a vehicle on the rack that has those adjustments...Sad!
  16. Mar 3, 2018 at 8:48 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Shoot me a pm about what youre looking for (lights or otherwise) and we'll get you hooked up!
  17. Mar 3, 2018 at 9:00 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I had those RallyArmor on my Element ! Loved them
    TacoCat[QUOTED] and HCJ like this.
  18. Mar 4, 2018 at 3:36 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    Yours looked like they sat farther out. Although i dont think mine are adjusted all the way out, i dont think they would go that far. Did theyhelp with rain/snow/rocks being thrown up from the tires onto the car?
  19. Mar 4, 2018 at 3:36 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Morning boys and girls. :pccoffee:
  20. Mar 4, 2018 at 3:37 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    Need food. And caffeine.
